View Full Version : '97+
Pages : 1 [2] 3 4
  1. Strange radio behavior 2002 Passat
  2. Passat help
  3. POWER STEERING BELT TOO BIG HELP! 98 passat
  4. Turn signal turns off/won't work 2001 Passat
  5. Do 97 passat glx vr6's have sai?
  6. Vexing Electrical Problems - '02 Passat
  7. Passat SW 2001.5 Vacuum hoses
  8. Replacing a Passat battery?
  9. performance help
  10. 1999 Passat GLX 6 cyl.
  11. 1.8t sport passat 2001 mass air flow sensor problem
  12. code reader location
  13. 98 passat window regulator plastic piece
  14. 02 Passat - Passenger front/rear floor boards are wet!
  15. 02' Error code P0171
  16. Passat TDI
  17. Lower control arm
  18. 98 Passat random no start
  19. idling
  20. Oil pressure issue...Sludge, sensor or other?
  21. dump valve and boost gauge.....
  22. AC/Heater Fan dead except for fastest speed.
  23. Door lock problems
  24. 98 Passat 4cyl 1.8 not start Ple Help
  25. Turn signal, persistant clicking after signal is off
  26. 99 Passat Headlight Reminder
  27. Have a multifunction range switch for 99 1.8t if anyone is interested.
  28. how to fit a cam position sensor
  29. Thermostat housing
  30. Airbag fault
  31. 1999 1.8t passat start and clock problems
  32. Auto shifts hard like a manual
  33. 99 Passat Won't Start
  34. Coolant leak on 1.9 tdi
  35. Rings or Turbo?
  36. Power Output Stage or Ignition Control Module - which is it?
  37. lights
  38. 99 Passat GLS V6 -Will Not Start
  39. Reliable Mechanic
  40. rear drivers side window wont roll down. not motor.
  41. 2001 PASSAT suddenly will not start
  42. I Am Crying (really) Help.
  43. 1.8t Intercooler piping
  44. My engine dont start Help!!!
  45. What does this light mean?
  46. Ford Explorer Seat
  47. change front o2 sensor 2000 passat
  48. Gunk in interior light
  49. Headlight assembly replacement
  50. 2003 Sedan (GL vs. GLS vs. GLX)
  51. fuse index card??HELP
  52. Passat seatbelt
  53. 2001 Passat Timing Belt and Electrical Help Please
  54. 97 Passat Body Control Module (BCM)
  55. cruise control engaged by itself
  56. Windshield Wiper Fluid Alarm
  57. Engine speed sensor
  58. top speed
  59. 2001 Passat Instrument Cluster
  60. 99 Passat blown fuse short circuit, WONT START!!
  61. 01 passat
  62. how do i remove a radio/cass from a passat
  63. 2006 passat seat problem
  64. Cruise control issues
  65. premium gas
  66. VW Passat 3BG 2.8V6 Tuning
  67. 01 Passat v6 Secondary Air System
  68. VW Passat 1.9 TDi Oil Pressure & Turbo
  69. Oil Change Woes...
  70. Oil leak
  71. 2002 Passat Water in jack Well
  72. Coolant temperature
  73. 2002 B5.5 v6 starting problems - throttle body?
  74. How to clear the "Service" notice on display
  75. 3k passat 190047826032
  76. 2001.5 speed sensitive door locks overactive, help!
  77. 97 Passat GLX Electrical Problem
  78. 97 Passat GLX Electrical Problem
  79. V6 ICM and triptronic advantage
  80. Headlight Adjustment Passat 2002
  81. Troubleshooting Passat Cruise Control
  82. passat 2002 rattling noise when heating
  83. 2000 Passat - heater core
  84. 02 Passat Electrical Bug
  85. 2003 Passat Rear Brakes
  86. VW Passat stumbles while driving
  87. Transmission "Clunk" 2004 GLX V6
  88. 97 VW Passat fog lights
  89. Driver side headlamp.
  90. coolant leak
  91. Where are you people???
  92. resetting locks and alarm - '99 Passat
  93. Radiator Issues
  94. 2000 passat rear calipers?
  95. Power doesn't come from battery to eny part of the car
  96. Where are the spark plugs?
  97. alternator light
  98. Volkswagen Passat, Secondary Air System
  99. Help! Headlights & Daytime Running Lights Do Not Work
  100. 1999 Passat ABS fuses
  101. 97 GLX, opinions
  102. Passat Relaibility?
  103. 2002 GLX won't start!
  104. 2004 Passat Information display wrong country/language
  105. 1999 Passat Auto door lock
  106. 2003 Passat auto trans indicator lights
  107. battery
  108. 2005 engine light intermittent
  109. Confort Module & Plug
  110. Obtaining XM Radio ID number
  111. Timing Belt and Controll Arms.
  112. Looking at a 2000 1.8L turbo -your opinion please
  113. Where to buy parts for european '00 passat?
  114. gas smell
  115. Need help in making a decision.,,,PLEASE
  116. Keyless Remote Lock only unlocks Driver door.
  117. Check Engine and Coolant Lights
  118. 1.8t hessitation
  119. oil in coolant reservoir
  120. Good Mechanic Here?
  121. '97 Passat. Would 2003 headlamps fit?
  122. Dead Radio 2002 GLX
  123. Trade in water damaged 2001 Passat
  124. 2002 Passat up and ran hot! Help!!!!!
  125. 2002 Passat Alternator Install Bosch 120A
  126. HELP! Hazards not working
  127. How to remove the head lamp assembly?
  128. Minimum Volume Control '00 Passat GLS
  129. Jerky Acceleration '00 Passat GLS - Dangerous
  130. Gearboot+Knob
  131. 97' passat 2.0 in a 90' corrado
  132. turbo ?
  133. How do you change the Bulb on the rightside passenger Air Vent
  134. High-octane gasoline for 1.8T
  135. Clock, milometer keeps resetting
  136. Help! - 99 Passat won't start because Fuse #14 keeps blowing
  137. 1998 VW Passat Tranny Jerks! Problem with Tranny? or Engine?
  138. where I can buy purge valve
  139. Changing Spark Plugs VW Passat 2002
  140. air conditioning problem
  141. 2002 Passat GLX Wagon Crisis
  142. 2001 passat wagon can't open back latch
  143. 2000 Burning Crazy amounts of oil!
  144. Passat will not start.
  145. Lock doors - Windows go down!
  146. 2003 keys
  147. Passat Hitch....Advice?
  148. passat 99 windows problems
  149. Replacing passenger-side brake light bulb
  150. help please!!!
  151. 1999 Passat Instrumentation Cluster
  152. Shaky (Scary)
  153. 2000 Passat power window, locks don't work
  154. New 01 passat v6 Navigation
  155. 2002 passat won't start
  156. 1999 V6 Passat ABS/Brake Light
  157. About to do my brakes on my '99 Passat....
  158. Vag-com information
  159. 99 1.8t small coolant leak by oil filter
  160. 03 Passat dash keeps rattling, how can it be fixed?
  161. 99 Passat Warm Weather starting problem
  162. 02 Passat check engine light/sometimes wont' start
  163. Fog Lamps
  164. Molding
  165. 1.8L AEB Timing Issues..Timing Belt Off??? sorry post is a little lengthy
  166. Leaking Valve Covers ('99....2.8L V6)
  167. Need some help here.
  168. 2003 Passat 1.9TDI oil leak
  169. Upgrades
  170. 99 Passat 1.8t Tranny Oil
  171. Happy New Owner 99 1.8t GTL Passat ???
  172. 99 Passat Check Engine/Won't start
  173. Cam position sensor
  174. Front speakers
  175. 2001 Passat for Sale
  176. 1.8t AEB T-belt set points.
  177. Gamma multichanger wiring???
  178. 1997 PASSAT GLX VR6 - Headlamp Off, Foglights Off - 3.29.06
  179. steering rack id
  180. 97 passat glx steering whine
  181. 97 VW Passat Electrical Issue
  182. Just upgraded Intake
  183. Auto & tip shifts n gear, but car won't move
  184. ABS fault
  185. 1999 Passat V6 - Brake pulsation
  186. 1999 Passat V6 - 114,000 mi.
  187. 2005 Passat Alarm Disable Question
  188. 2005 Passat Alarm System Disabling
  189. tail lights(revisited)
  190. ABS/Break light off
  191. OBDII scanner
  192. Keyless Entry Question
  193. turbo doesn't work
  194. air intake
  195. tail lights??
  196. VW Passat engine siezure
  197. Airbag light
  198. Stuck Gear shift?
  199. Buzzing sound in dash and clock reset
  200. Gas smell, decreased mileage, check engine light
  201. changing brake calipers on a 98 passat
  202. anyone want to buy my 03 passat?
  203. 98"passat climate control, electric problem. PLS HELP
  204. Radio Problems - Blaupunkt Bolgna C50
  205. Aircon clicking sound
  206. Problem with Remote opening passenger/back doors
  207. Car sputters on acceleration
  208. Type of oil
  209. P1338
  210. 97 Passat wont take gas!
  211. 2000 passat fire issues?
  212. 2000 Passat ccomfort module
  213. 2004 Passat - Both Break lights go out but no fuse manual
  214. '98 passat 1.8t swap for '02?
  215. car shakes!! help!
  216. 2002 Passat crankshaft actuator sensor
  217. won't start after every fill up
  218. Help, Red spot on display
  219. passanger door wont open on 98 passat
  220. warm start problem
  221. Looking for performance shop in Orange County CA
  222. horsepower question
  223. 2002 Passat owner seeking advice
  224. ARE PASSAT ENGINES INTERFERENCE OR NON-iNTERFERENCE
  225. 01 Passat crashed, bought the 06 no questions
  226. 99 passat won't start
  227. Passat downshift bump
  228. 99 VW Passat With Factory Alarm Won,t Start
  229. 99 Passat Wgn Battery Dead
  230. Various problems 01 Passat - Which are Priority?
  231. Seeping Oil Seals
  232. 00 Passat V6(ATQ) 2.8l
  233. Brake 1999 passat
  234. Back door window
  235. 2000 passat wet floor board
  236. 2001 Passat and a Cupped Tire
  237. Updated Timing Belt Kit Questions...1.8L
  238. 01' Passat driver side door wont open from the inside
  239. 98 1.8 passat clicking engine
  240. Someone help me before I explode!
  241. 99 Passat 1.8T Oil Pan Change
  242. 99' Passat Warning lights no tach
  243. 99 1.8 wagon interior light stays on
  244. Urgent help needed, 98 Passat pass door window
  245. 1999 Passat V6 - Full Antenna Replacement
  246. turbo on on 03' passat?
  247. brake job cost?
  248. Extended Warranties?
  249. Fuel Door Release
  250. 98 Passat loosing power
