View Full Version : Cavalier Problem Diagnosis
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19
  1. fuel pump
  2. 03 Cavalier Check Engine Emisiions Warning?
  3. Help Oil Smells Like Gas???????
  4. 2000 Z24 spark plugs?
  5. 99 Cavalier surges (reverse surges)
  6. Cavalier Low Fluid Light
  7. Car wont turn on.
  8. 93 Cavailier RS Car cutting off an on.
  9. 94 Cavalier Possible Tranny Overheat
  10. Can Someone Explain This
  11. How do I go about doing this...
  12. Oil? '00 Sunfire Removing engine part.
  13. No lowbeams & a ticking noise?
  14. Confused Help
  15. Noises
  16. Air lock in cooling system
  17. 1995 sunfire speedometer quit working
  18. Omg WTF HELP!!!
  19. Stereo Issue
  20. http://www.automotiveforums.com/vbulletin/showthread.php?t=698762
  21. Front End Clunk
  22. 2002 Sunfire 2.4 High idle Problem
  23. anoying and maybe harmfull noise plz help
  24. Confused.....01 cavalier
  25. Speedometer issue
  26. steering column removal
  27. Went to change my oil today and almost cried...
  28. Hid xeon headlights in 05 Cavalier
  29. 95 cavalier
  30. No power to fuel pump 2002 Cavalier
  31. Engine blown?? Video posted.....
  32. Check Engine? Can I do this myself?
  33. Can't Find the Coolant Leak? HELP Please
  34. Can't Find the Coolant Leak HELP Please
  35. igntion key cylinder lockup
  36. DTC P0335 and P0341
  37. 99 cavalier dash warning lights stay on all the time
  38. why does my cavalier jerk around 35mph
  39. Car chugging/stalling/poor acceleration
  40. rattling/squeaking noise
  41. wheel humming
  42. ABS Light...
  43. another z24 that won't start...this one's different though
  44. Fuel pump problems
  45. ??97 Cavalier Overheating/Died, Now won't start??
  46. whats not wrong with my kia?
  47. 97 cavalier a/c problem
  48. Hard time starting my car.
  49. lock out selinoid
  50. DTC P0440 update
  51. Subtle Vibration in 03 Cav
  52. Can anyone help????
  53. Anyway to fix a noisy Lifter?
  54. oil?!?!
  55. Whats wrong now?!!?
  56. headlight, cruise and fog light problem in 2003 nsunfire
  57. Blown Engine?
  58. My parking and tail lights stays on after car is off, HELP!
  59. CanOBD2 Reader and my Cavalier
  60. Vibrations at high speeds
  61. Help!!!
  62. Oil plug
  63. 05 Rear Seat came unlatched?!
  64. spark plug denting
  65. Limp Mode? I've searched
  66. beam lights 1996 chevrolet cavalier
  67. 2002 a/c problems
  68. Uhhh something bad is wrong, I need help fast!
  69. How to remove the dipstick in a 99 cavalier
  70. couple of problems
  71. 98 sunfire surges
  72. 95 cavalier buzzing noise in dash
  73. help
  74. no spark
  75. Engine light and traction coontrol light on
  76. 199 cavalier brake bleed issue
  77. 3.1 motor ?
  78. 2004 Cavalier misfire and stalling
  79. 1990 2.2 5sp
  80. where is vss located
  81. 1996 sunfire trans won't shift
  82. 2000 Cavalier intermittent light problem
  83. 1998 Cavalier LS headlight issue
  84. 2004 Cav Oil change
  85. 97 Sunfire Transmission Problems
  86. 2002 Cavalier Z24 rattling??
  87. Sunfire '97 Estimate Diagnostic Costs
  88. 2001 z24 lil input
  89. Hesitation During Acceleration
  90. 97 Z24 almost stalling during cold starts
  91. power window problem
  92. 96 sunfire 2.2 frustratedbouttagagiveup
  93. 95 Cavalier, 2.2L Intermittent Starting Issues
  94. 97 sunfire abs light
  95. auto tranny
  96. Leaky IAC Valve and DTC P0440.
  97. B&M Shiftplus stopped working.....
  98. compression problems 1997 2.2
  99. 10mm plug wires and coil pack question.
  100. Battery getting drained/alternator is fine
  101. 2000 Sunfire - Monsoon CD player no longer working
  102. Extremely Stumped...Please Help Me!!!
  103. 92 Cav. overheated replaced thermostat now dies for no reason
  104. 96 Cavilier Clutch Question
  105. 96 Cavilier Clutch Question
  106. Speedometer replacement - sticking
  107. what can kill the charging system
  108. passlock or something else?
  109. 1994 Cavalier Rs Air Conditioner issue!
  110. Front end thumping
  111. 96 cavalier transmission woes
  112. 96 cavalier front wheel noise
  113. lights aint goin off.........
  114. 03 Cavalier won't start - Please help...
  115. acceleration noise & excessive fuel consumption
  116. 2000 Idle stumbles
  117. Strut mount problem??
  118. Doing a running vacuum test 95 cavalier
  119. 91 Cavalier 2.2l Heater issue?
  120. hey guys i'm back.... and i need a new Alternator
  121. cooling fan relay
  122. Wheel locked up
  123. 1994 Cavalier trouble codes
  124. 1993 cav acting stupid
  125. Bad miss
  126. Rebuilt Transmission Vs. Used
  127. code 32 EGR diagnosticSw ..Signaling incorrect
  128. 01 Cav code P0440
  129. Problems with my 89' Cavalier
  130. Looking for expert advice...
  131. Rear defrost and rear speakers dont work when its cold outsi
  132. 97 Cavalier thermostat ?
  133. sunfire theft system and service light on with dying battery
  134. 2.2l rs 97 Cavalier missfire
  135. need help!!
  136. A/C leak in 2000 model
  137. How do I fix the Vents?
  138. Theft light stays on, key will not start car?
  139. Emissions problem?
  140. hole in air intake
  141. Idiling Problems?
  142. surging idle and stalling
  143. Turn signal shuts off headlights???
  144. 94 Cavalier Signals
  145. 03 Cavalier 2.2L loud clicking under valve cover.
  146. New computer? help please
  147. 95 2.2L, A/C and heat only work on HIGH!
  148. 98 Cavalier Thermostat Problem?
  149. sunfire misfiring
  150. 95 cavalier 2.2L running rough
  151. idle problem
  152. intentifing engine size
  153. Car loosing coolant after over heat.
  154. Where is the Blower Motor Relay / Blower Resistor located
  155. Heater is going on and off ???
  156. 02 sensors and your miles
  157. exaust manifold/pipe
  158. sunfire temp gauge
  159. sunfire gt 96 wont start
  160. 1995 sunfire--2.2...no heat and speedo is not working...HMMM??
  161. 2001 Sunfire cooling system
  162. Now car won't start because I can't dearm alarm
  163. Died in the middle of the road.
  164. 350K...might be toasted
  165. 90 Cav stalls/hesitates from idle
  166. location of 95 cavalier Horn relay
  167. No fan/heater
  168. I Smell gas when idelling
  169. 99 cavalier trunk lock problem
  170. idle problem
  171. 89 z24 bad torque converter questions
  172. 96 Chevy Cavalier NO HEAT HELP!
  173. 98 Cavalier Front Speakers
  174. 94 z24 cavalier tranny problem
  175. Another Engine Boging question
  176. 2000 Sunfire electrical
  177. Trip odometer quit working
  178. Fuel Problem 2000 Cavalier
  179. '93 Cavalier, revs on turns and quick stops
  180. fuel injector replacement
  181. Engine bogging?! Need HELP!!!
  182. Engine bogging?! Need HELP!!!
  183. Strange noise when turning wheel
  184. Question about my cavalier shaking
  185. 95 water pump gasket leak after change
  186. dim headlights
  187. Speedometer not working and smell antifreeze
  188. 97 2.2L ODB Error code p0440
  189. 97 Z24 Power Window problem....
  190. 04 Sunfire gauges
  191. electrical problems????
  192. '90 Cav, bogging, hesitating.
  193. Overheating/Leaking Anti-freeze
  194. 1991 Z24 manual stalls
  195. 1999 Cavalier Mis Fire
  196. Fuel filter+ABS
  197. tack help....
  198. car is rev limiting at 3800
  199. Cavalier Charcoal Box
  200. 97 Cavalier Drum Brake Drag
  201. 1991 cavalier wagon issues
  202. 96 2.2L Cavy transmission....
  203. Could it be the timing belt?
  204. My car jumps
  205. Electric Windows Problems 96 Sunfire
  206. 97 Cavalier cold start problem
  207. Z24 2.4L engine swap
  208. 99 Cavalier Fuse Box
  209. 92 Electrical Problem..
  210. loss of power
  211. Bucking Cavalier
  212. 96 Cavalier wierd problem
  213. Cavalier RS 1992, accumulator battery type
  214. Belt problem...i think
  215. 97 Chevy Cavalier will turn over but will not start
  216. Checking/Adding Tranny Fluid, 97 Z24
  217. fuel/spark probs?
  218. adding new turn signal
  219. coolant river!?!?!?!?!
  220. 97 Sunfire skipping need help
  221. 95 cavalier timing chain
  222. 97 Sunfire - Starts runs for 2 sec, dies
  223. 89 Z24 Loss Of Oil Pressure
  224. still won't start...what next?
  225. front O2 sensor problem.
  226. Cruise control
  227. Many Problems...97 Z24...need help.
  228. How to remove the master cylinder.
  229. Temp Fluctuation while driving
  230. 96 Cavalier - Cranks, won't turn over unless with starter fluid
  231. Please help me Huge problem!!!
  232. Ideas
  233. Winter or Tinkerage?
  234. Engine Problem
  235. almost stalling, but not?
  236. PCM/ Engine Control Computer?
  237. How to tell if you have a head gasket problem
  238. slipping clutch/transmission?
  239. Blinker sound, no blinker on
  240. 91 cavalier
  241. new problem
  242. High pitched squeal
  243. Car wont turn over, and no power at all
  244. Now its just getting old
  245. Power Steering Pump
  246. Waterpump - Sunfire GT - anyone have manual?
  247. 98 Cav. Running Real Hot
  248. 98 Cav just died what could it be?
  249. trunk light not working
  250. Gas Leak
