Front End Clunk
TerryG80
04-28-2007, 01:24 PM
My wifes car, a 1991 Cavalier, makes a clunking noise in the front end. It usually happens when we hit a bump and occasionally while turning, but not every time. I grabbed ahold of the tie rods and wiggled them and they have a bit of play up and down. Is this normal, or could this be the cause of the clunk?
Thanks
Terry
Thanks
Terry
muff34
04-28-2007, 03:05 PM
Likely the front struts and or strut mounts looking at the age of it . However tie rods should not be loose either . Do you notice any steering wheel shake/vibration when driving down the highway? How are the tires any unusal wear on them . Does it run straight down the highway. Cv joints will clunk when you are turning a corner as well, as in turning in a parking lot /street corner etc
TerryG80
04-28-2007, 03:52 PM
I was thinking struts myself, but bouncing the front end up and down by hand doesn't cause the noise. After looking at it a little closer, it's not just the tie rods, but the whole steering assembly that seems to move. I haven't notice any shaking or vibration, nor does it seem to pull to one side. There's a little wear on the inside of the drivers side tire.
You can feel the clunk on the floorboard, especially on the passenger side.
Thanks for your help.
Terry
Edit:
I uploaded a video to youtube.
http://www.youtube.com/watch?v=X7utqajEb38
About 25 seconds in gives the best shot of what I'm trying to describe, and you can hear the noise it's making when I move it.
Terry
Edit:
