ign. sys. fuzlink blowing '93 dakota 3.9
azkitch
04-18-2007, 05:50 PM
My 93 3.9 2wd is blowing the ignition system fusible link underhood. A friend re spliced and taped the red wire out of the + batt term., and it started 3X B4 the fuse went again. Batt term pretty rough. Could my ign. sw. be the problem? or more likely the starter? I got the truck w/69K mi., now @ 146K. It's my baby! Help me save it! Thanx in advance, guys. :banghead:
azkitch
04-19-2007, 07:10 PM
I'll answer you, azkitch! Check your ingition switch. Maybe you can find a schemo for it, and ohm out the connections.
Hey, I'm getting some sketchy readings w/switch in the "on" position...I wonder...
:banghead:
:banghead:
johnwads
07-09-2007, 08:20 PM
hey mine is doing the same thing blowing fuses out under the hood when the truck starts. do you think its the ignition switch? driving me crazy now how can i tell if the switch is good?
johnwads
07-09-2007, 08:34 PM
i found another question onhere that say s a wire maybe broken or burned thru from the o2 sensor touching the heat shield i guess i'll have to look tomorrow in the light to see if there is a bare wire.. i'll let ya know any thoughts?
azkitch
07-14-2007, 02:07 PM
'Twas my ignition switch assembly. Dodge dealer 1.5 miles away had the part for under a hundred...I don't even remember how much...$80? Now occasionally the truck won't start until ya dump about 1/4-1/2 oz of fuel into the TB. WTF??
Hope ya got yer truck running again, too...
rhandwor
08-11-2007, 08:50 PM
Pickup a haynes manual the ignition switch is on the column just below where it bolts on the column. Look on ebay for a picture so you know what it looks like. You can buy these at a parts store.Check for hot terminals,corroded or loose. Check for bad wires where it is burning. If you spilled any anti freeze check in these areas as it is an insulator. If replacing make sure it is on the same marks as they have some some adjustment.
