View Full Version : Pick-Up
Pages : 1 2 [3] 4 5 6
  1. 89 hard starting?
  2. 1989 rearend
  3. Toyota pickup won't turn over, just whirring noise
  4. 1989 In Dier need of HELP!!!!
  5. Fair Estimate Suspenion/Steering Work???
  6. what is a fair price for clutch work.
  7. 1986 Toyota Truck Dual Rear Wheels Brake Drum Removal
  8. Carbs: TO remove or not to remove is the ?
  9. engine code 21 and 51
  10. 22RE using oil
  11. im new to the truck game.
  12. strange chirping noise
  13. 86' starting & running problem, carberator
  14. 93 starting problem
  15. Just a wild hair!!!
  16. Idle Problem
  17. Room to drill?
  18. PCV Hose
  19. muffler horsepower
  20. noob with questions
  21. Turbo boost fuel cut off
  22. 22RE Emissions Removal ?
  23. power upgrade on 22re!!
  24. 1987 4x4 toy turbo pickup problem
  25. 22re serpentine conversion
  26. Enging noise, one last resort
  27. 22RE 20 Miles per Gallon
  28. 84 Toyo Pickup with no brakes
  29. swap out 22re
  30. "Turbo-lag" on a 22RE
  31. 87 Spits and sputters
  32. radiator question for 86 pickup
  33. Mechanical Fuel Pump
  34. Mustang Rims
  35. Different Valve Covers??
  36. 1994 pickup making loud noise
  37. tips on 4x4 front brakes!
  38. '94 toyota pickup gauges not working
  39. Toyota Pickup Desiccant Dryer Replacement
  40. 1980 pickup upgrades
  41. 22R rebuild kit
  42. Newbie here with some questions....
  43. my brake light on the dash wont turn off
  44. 22R vs.22RE Engine
  45. would 35's fit my 84 yota with 5inches of lift
  46. 1985 4x4 22r running rough please help!
  47. 1987 Pickup Intermittent starting problem
  48. surges badly when floored
  49. my air and heater switches done light up
  50. how would i sawp a 22r for a 302 into my 84 yota 4by4
  51. 1989 toyo4x4 how much?
  52. Ignition Question?
  53. 86 22rte turbo 2.4
  54. 93 5 speed 2wd?
  55. custom intake
  56. Multiple electrical failure
  57. oil gauge pressures
  58. making my truck louder
  59. Overheat causes valve damage?
  60. Vacuum line diagram
  61. How Do I get a title?
  62. dumb question but i need to know
  63. 1991 power steering
  64. Idle, exhaust, oil pressure: Is my engine dying?
  65. I have an egr system question
  66. loss of ignition power on a 81 4x4
  67. smoky emission smelled like coolant....
  68. 1982 22R vs 1989 22RE
  69. Clicking Sound
  70. Rear disc brake conversion
  71. EGR: Is it really necessary?
  72. 20r to 22r swap question
  73. Replacing front brake pads...
  74. looking for helpful links
  75. 93 22re auto trans shift points
  76. rough idle
  77. windshield question
  78. recurring exhaust leak- any ideas?
  79. is it possible..
  80. Towing my 1993 SR-5 4x4 Manual 5 Sp.
  81. Adjusting rear brakes, 1984 pickup
  82. tire size
  83. building 85 trail rigg
  84. Which is the Better Auto Trans?
  85. 1984 2WD pickup, adjusting the choke...rivets???
  86. stereo problems
  87. o/d solenoid death
  88. 1992 Toyota 4x4 V6 wont' start, need help.
  89. v-8 conversion
  90. Almost done with mine. Need help
  91. need help
  92. stereo problems
  93. canopie size
  94. Crankshaft bolt removal
  95. Crankshaft bolt removal
  96. Spark plug gap for 87 pickup - 22R
  97. Soft brake pedal - no fluid loss
  98. Brakes Nitemare!!
  99. injector wire identification question
  100. first tym buyer air bags
  101. Jet chip ???
  102. Need a fuse diagram for an 88 toy
  103. 1980 4X4 Dies After Restart
  104. 1977 Toyota SR5
  105. New here: '86 SR5 (Help?)
  106. brake & battery light coming on???
  107. in-destructible '91 toyota
  108. 90 p/u shock absorber recommendations
  109. 1989 Toyota 4x2 - missing out
  110. Spark situation ideas Welcome.
  111. 1986 Toyota poor accelaration good compresion
  112. transfer case leaking, can't shift all the gears..
  113. Clutch Problem
  114. '92 - dash lights on right side out
  115. Pinging like crazy
  116. toy p/u wont start in the rain
  117. Four wheel drive not good
  118. Emissions Problems of Carb 83 22r
  119. 83 Tranny Problem
  120. Gas pedal dies around 55mph; returns at 50
  121. high oil pressure 85+psi
  122. starting problems
  123. Oil Pan Leaking
  124. 22re rebuild/hole identification
  125. please help 89 toyota trouble
  126. 22re engine swap questions
  127. Back in the GAME !
  128. Transport
  129. noobie toyota owner
  130. bucking / hopping forward intermitently
  131. head gasket or what? water disappearing
  132. i want to take the EGR off my 22re
  133. Lower my Toyota Pickup
  134. Starter problems
  135. Weird overheating issues
  136. My p/u won't start
  137. Lowering a 93
  138. lokking for advice
  139. Need a little help cause I'm a tool.
  140. Engine and trans Identification
  141. Lifting a 91 22RE
  142. S-AFC possibilities?
  143. strang idle/stalling when cold
  144. Video you guy's might like (high speed only)
  145. really stiff suspension
  146. Heating cat? or need timing adjust?
  147. how many miles do you have on your yota?
  148. 1994 4x4 pickup Rattle/Growling noise
  149. Motor Swap!!
  150. 92' pick-up leak.
  151. Need advice for a 3.0 motor swap
  152. 1984 Toyota 22R not Charging
  153. 88 shift on the fly?
  154. codes need help
  155. 1985 22r running bad on low rpm... help please
  156. 85 or 88 pickup
  157. Exhaust help
  158. Combined Toyota Factory Truck Maintenance Manuals
  159. Help 1985 toyota 4x4 pickup electrical prob!
  160. 91 22re wont idle after its warmed up
  161. 20r trannie
  162. Still no overdrive
  163. Any suggestions on crate engines?
  164. 93 4x4 fuel relay problem
  165. Starter keeps turning after the ignition is turned off
  166. pickup not running
  167. 1993 Toyota P/U problem.........
  168. New Bed
  169. which tires for my rims
  170. Please Help
  171. eratic idleing
  172. Timing problem??
  173. Intermittent no start problem
  174. road shake
  175. Wheels and Tires question
  176. slow acceleration, poor fuel mileage, erratic Scanner readings
  177. Loud tap/ping noise
  178. 1990 pick-up 4x4 won't shift
  179. 87 Toy parts
  180. 1993 toyota idleling problem
  181. 81 truck 4x4 electrical problems help!
  182. idleing problem
  183. parts for a NA street 22RE engine
  184. Overdrive
  185. what parts should i get for a NA street engine?
  186. crashed my 89 toyota 2wd pickup - help
  187. GM radiator????
  188. cleaning coolant out of engine/oil
  189. starter
  190. I turn the brake off but its light still stays on...
  191. 94 Pick-up wont idle, backfires
  192. where to get rims
  193. banging sound 90 4X4
  194. 1982 pickup starting problems
  195. wiring for clock on 86 pickup
  196. Cup Holder!!!!!!
  197. O2 sensor issues
  198. coverting transmissions
  199. transmission problems
  200. Replace Head Gasget
  201. Where to buy antenna?
  202. matching heads
  203. No heat in pickup?
  204. matching heads
  205. Engine swap 92 22re to 88 22rte
  206. 91 Toyota 4x4 3.0 liter idle problems
  207. 22re top end rebuild
  208. looking for head
  209. head
  210. timing chain getting frusterated.
  211. 21R Rebuild
  212. vaccum diagrams?
  213. spark plug will not stay in head
  214. more bang for the buck
  215. Rebuild or rebuilt 22RE?
  216. What size bolts? My starter just fell off....
  217. 93 2wd Tire Size
  218. muffler and tailpipe replacement?
  219. Head gasket replacement, 22R. Any quirks???
  220. 93 Toy P/u 22re Vacuum Hose Diagram
  221. Diesel Forums?
  222. Best headers?
  223. Best plugs and wires for 22RE
  224. Spark Plug Gap 22R 1986 4x4 PU
  225. no electricity to fuel pump
  226. tranny snag
  227. looking for a little help with the 22re
  228. will it hold?
  229. tacoma engine swap
  230. 87 pick-up stalls after engine warms up
  231. wheel travel and gear ratio?
  232. toyota wiring diagram
  233. is there any 22r drag racers out there
  234. Anyone ever done a 3.4 swap???
  235. Where is my O2 sensor?
  236. tranny fluid
  237. seafoam, seafoam, seafoam, seafoam
  238. what engine??????????
  239. Does any one have any ideas?
  240. 88 22RE spark plug gap
  241. how do i install a ct26 turbo to a 1991 22re
  242. $8 Subscription to Car & Driver, Motor Trend, and Road & Track
  243. 86 pickup heater parts
  244. 92 3.0L getting bad gas milage
  245. 85 pickup engine swap
  246. what years are the same?
  247. truck
  248. Interior bucket seats???
  249. engine diesles (keeps running
  250. water in my oil, engine running hot
