View Full Version : Cavalier
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. 92 cavalier ignition control module interchange
  2. what would you guys recommend
  3. whats the stock horsepower?
  4. What's the best place to
  5. So I want a new....
  6. All 00+ J-bodies, concerning aftermarket stereos
  7. 03+ LS Sport Front Bumper Question
  8. Wiring for Rear 6x9 Speakers
  9. Dex-Cool
  10. Starting on '08
  11. Thanks for your help guys, Check this out.
  12. 1994 Cav Convertible
  13. 96 Cavalier Conv?
  14. Parking on an angle?
  15. Quarter Mile Predictions
  16. Just wanted to say farewell, sort of
  17. Slug mobile
  18. Need advice re: replacing seized 2.2l engine - esp. price
  19. Sea Foam Question...
  20. Ohh boy...
  21. licence plate filler on front bumper
  22. Short RAM Cai.. winter friendly?
  23. 2001 cavalier
  24. Bad idea?
  25. Factory Sunroof, can it be done?
  26. Having Intake installed
  27. Post Pics of your Ride and selves. Pt. 2
  28. Inline fuse
  29. help on using an ohm meter
  30. F#&K! Blew my FORTH ENGINE!
  31. Suspension Swap
  32. 2 much bass,not enuff music?
  33. Im Selling My Car
  34. Side Mirrors
  35. im sooo pissed!!!
  36. Finally, Check it out.
  37. Amp Wiring Kit
  38. 1971 charger 500 2000 cavy z24 5 speed
  39. Auto trans vs. Manual- Manual much faster?
  40. My Body Kit!
  41. Parting ways...
  42. 2002 Gauge System - Gear Selection Lighting
  43. 2001 Cavalier
  44. Wire Loom
  45. 04 Cav and a 01 S-10-Will the radios swap?
  46. Ahahaha. John Deere's finest LOL.
  47. Front Door Speakers??
  48. headlight assembly
  49. how to disable a theft system 99 z24
  50. where is trunk button???
  51. Lookin for performance parts 96 cavalier 2.4l
  52. Will this parts warranty transfer???
  53. Fog light trouble
  54. What's Your MPG?
  55. Wheel Lock
  56. Interior L.E.D's
  57. 92 2.2l fuel injector o rings
  58. Windshield washer pump-Pumping but no fluid
  59. 99 cavalier wont start
  60. windshield wipers get stuck, help!
  61. 98 Power Loss
  62. Is anyone else wondering
  63. Buzzing sound
  64. Coolant problem
  65. ABS light only comes on over 100km
  66. 2.2l valve noise when cold
  67. Check engine light -- what if it DOESNT come on?
  68. What do you think about lucas oil stabilizer?
  69. Thermostat
  70. Transmission trouble?
  71. Motor mount
  72. 97 cavalier overheating
  73. Haven't been here in awhile...
  74. Christmas present and need help!!!
  75. Under drive pully
  76. 1990 headlight problems
  77. Just a couple questions any help/insight wanted (Stereo+Body Kit)
  78. 2000 cavalier no fuel pump
  79. 4-gauge power wire?
  80. What you need for Neon Rear Disc Swap.
  81. knock
  82. Possible Solution for the 89 Z24 random stall
  83. In need of a sig!
  84. 97 Cavalier Idle Air Control?
  85. Tranny Swap
  86. 2002 chevy cavalier stereo install
  87. temp gauge and more...please help
  88. ABS brakes sensitive
  89. Which is better?
  90. '93 Cavalier Z24 3.1
  91. blue cold cathode lights
  92. Cold Air Intake
  93. Newbie question here
  94. What's up you clowns
  95. Cracked dash / seat belt
  96. Cavalier SS Ram Air Fiberglass Hood....
  97. backseat
  98. Front end swap?
  99. Headlight Bulbs
  100. need advice on subs/speakers
  101. Dual Exhaust Question?
  102. I need to put a tach in my 00' 2.2l ???
  103. 1993 Chevy Cavalier 2.2L 4 cyl
  104. Wiring CD DECK
  105. 1999 Cavalier Gauge Cluster
  106. freaking CD deck!!!
  107. 2004 cavalier dash
  108. windsheild
  109. drum to disc rear brakes
  110. Questions from a non sunfire/cav. guy
  111. 05 Cavalier Replace cluster bulbs with White or Colored bulbs
  112. Can anybody tell me what this is?
  113. 1991 Cavalier
  114. So I got this phone call...
  115. New Gauges. Whew.
  116. DRL's are gay
  117. Do Not Use B&m Shiftplus!
  118. Removing Quarter Panels
  119. Fast Car for sale
  120. 97 cavalier door dinger
  121. Trim question
  122. Subwoofers and Amp
  123. radio
  124. Loud knocking coming from engine
  125. Need key code for 99 cavalier
  126. cracked dash 2002 cavalier Z-24
  127. Headlight and High/Low Beams not coming on...daytime running lights on all the time
  128. Headlight Covers
  129. 2.2 l engine mount torque specs
  130. 1997 Cavalier ETC light
  131. blinkers question
  132. i need a turbo!!!
  133. parting out my cavalier...
  134. 99 z24 5 Speed shift linkage stuck
  135. New here
  136. Should I get these Rims
  137. Motor Swap
  138. 96 Caviler
  139. engine drop
  140. oil filter location 02 2.2 ecotech
  141. Updated Pics and a New Exhaust Clip
  142. BCM, what is it?
  143. Locktronics
  144. 2000 cavalier
  145. should i buy?
  146. any good
  147. 1998 cavalier
  148. 1996 Shifter
  149. '90 door panel
  150. Detailed Supercharger Instructions
  151. Cavalier series 1995 to ____?
  152. 1998 Cav vs 1994 Tercel
  153. Just recieved my HPTuners and Turbo Update!!!
  154. Fast Blinker Question
  155. dropping heat shield
  156. 1988 1994 strut compatibility?
  157. changing the auto transmission to manual
  158. tranny problem
  159. How to check clutch fluid level
  160. Replacing Clutch
  161. 97 Z24 - Airbag sensor (by Hood latch)
  162. Part Help
  163. Pulled Over by Police!
  164. 1989 Cavalier Z24 Vs. 1995 Honda Del Sol
  165. '99 Cavalier Dash Panel replacement
  166. Supercharger or Turbo?
  167. 1999 cavalier odd dash light?
  168. cobalt wing on cavalier???
  169. Change of weather.... noise
  170. Transmission oil
  171. The Midnight Blues
  172. looking for a 96 2.4L
  173. Catalytic converter
  174. suspension
  175. removed the side molding today!
  176. Installing wheel studs
  177. guess...
  178. Problem with automatic start
  179. what is the ABSOLUTE least i can expect to pay for a replacement radiator?
  180. Duplicolor vs. Krylon Paint
  181. What's the diffrence?
  182. passlock problem
  183. Installing a Bodykit
  184. CRJ's new ride...
  185. I painted the front end.Hows does it look
  186. subs
  187. Where should I stop?
  188. Maintenance
  189. hopeless
  190. Speakers..
  191. Da Beach!
  192. To buy or not to buy?
  193. Turbo Turbo...Im craving Turbo!
  194. 1992 Question
  195. $70 Cavy supercharger...pretty fishy.
  196. 02 cavalier w/4 wires on 6x9s
  197. Bought a Racing Wheel.....now what....confused?!
  198. Cavalier Fog Lights
  199. Cavalier Steering Wheel Removal
  200. Instrument cluster swap problem...
  201. HID Kit.......
  202. what the hell are u all doing with your cavaliers these days?
  203. 96 into a 92
  204. Steps to upgrade stock 2.2 Ecotec
  205. 94 engine vs 99 engine
  206. Cops, Go Suck A Lemon!!!! !@$#
  207. Will a 00-03 instument cluster work in a 99?
  208. Need a cylinder head for a 95 Cavalier z24
  209. 1989 -- 2.8 to 3.1 swap
  210. Mmmmm Wide body....
  211. Mandrel vs. Crimp piping
  212. Just to know ahead of time.
  213. Halossssssssssssssssssssssssssssss
  214. Having a hard time desiding...
  215. Interference motor or not?
  216. Shift Knob
  217. Neon Rear Disc swap outcome
  218. 1997 Chevrolet Cavalier
  219. where can i get parts??
  220. 88 wagon body kit???
  221. Car Chokin in Acceleration
  222. 94 a/c
  223. Didn't pass DEQ
  224. 97 Chevy Cavalier Coupe - Rear driver window pane
  225. Need help finding something.
  226. GUESS WHAT'S IN THE BOX and new manifold pics!!
  227. Muffler/Cat
  228. shocks/struts
  229. 2.2L to 2.4L swap - Can it be done?
  230. Thinking of Buying 2003 Cavalier
  231. Stoppers.... ;-P
  232. 1990 Z-24 timing chain
  233. need help 92 cavalier
  234. Boosting plan, tell me if im doing the right thing...
  235. running hot!!
  236. water pump in 3.1
  237. Life after J-Body...What Ive been up to
  238. 99 cavalier auto - anti-theft taking my time
  239. Cops, go suck a lemon.
  240. my new exhaust wOOt!
  241. intake for 2.4 L
  242. Mods for 02' z24 2.4L
  243. the what's in the box game
  244. Hmm
  245. tachometer to fit in this pod
  246. O2 Sensor
  247. nokya bulbs???
  248. Just did oil change-4 quart's?-5 quart's??
  249. StreetGlow( Optix ) Underbody Neon Lights
  250. 1994 Clutch
