Grand Future Human-Grade Air-Dried Beef Dog Food
Automotive Forums Car Chat
Honda
> JDM Motor & Parts info/chat
View Full Version :
Pages :
1
2
3
4
5
6
7
Hatch Swap
d16y8 help!!!!
D16Z6 surging at idle
91 prelude motor mounts
engine swap
Hey guys this is yet another ecu question
Swap for a "'07 Fit?
temperature tweeking need help
how do i know the difference between a h22a and h22a type s
d15b7/rebuild
Which swap is best 4 87 crx
LS in a Del Sol??
1995 Honda Civic 1.6 VTec swap into 1989 Honda
HI guys just need a little help please
03 civic si questions
Need an engine for the Demon Honda, looking for b16b
My car idles at 2000rpm when first started
Best swap for my 93 automatic civic?
Whats the best B-series intake manifold?
Jdm motor madness
trouble starting?
thinking of a DOHC
B18C1 Engine Swap ECU Question
need honda crx info....
ITR intake manifold vs. GSR intake manifold
Racing Spark Plugs
what engines will fit 87 crx
how do i know what cylinder head has Vtec?
P28 Chipped ECU
Gsr or Ls vtec?
exhaust questions..
hey
93 direct bolt on swap
engine swap ?
93 Civic Computer
crx swap
engine swap ?
EK Clutch
Valve Lash Specs for 99 B16b head
anyone with a D16Z6 help with distributer
tranny choices
b18c1 big problems
wire harness
difference between D15B2 to D16Z6 Vtec
88 crx si w/b16. having problems. PLEASE HELP!
Need help with VTEC
cv axels
Tuning
B16A Reving & Heating up Need Help
Ls Vtec or B20Vtec?
Po6 ecu d16z6 VTEC engine
91 crx si w/ b16 swap, having problems. PLEASE HELP
gsr block
B16 motor?
mugen spoon ect... web sites?
need help with 1990 integra b20b swap
geoff raicer b series
Got 160whp.
91 CRX Main Relay trouble
new engine
civic type r cams
Need help with my H22 swap...
i need this!!!
which ECU Chip for my p28 ecu
b20 complete block needed
Gas Milages on a h22a?
D15B7 swap to D16Z6 Help!!!
long block vs short block
jdm prelude piston/rod
89 crx swap question
CR-X: ZC JDM Junkies
zc headbolts
zc dohc long block
91 civic dx swap
H22A & Standard Swaps
F22B 92 Prelude - I need parts help
japanese sir-II and sir-s specs
info on ctr itr camshafts!!!!!
h22a into a 91 civic dx
my friend howie's civic
89 accord A20A1
Engine Q?
A20A1 Intake
Need help with swap(d15b)
spark plug oil.
HELP! H22a swap in my 94 accord
Need help with my H22A...
exhaust help
JDM H22A questions...
JDM H22A issues
1997 Civic LX Sedan swap...
Part No. for 1999 Honda Saber/Inspire water pump
Manual Tranny fluid change intervals?
Wiring JDM EL gauges
WTK 200BHP from a stock b16
Skunk 2 Intake Mani problems
What intake should i buy for 98 civic???
Help with swap problem....
ls/vtec
what is my jdm zc
How to remove a B16 cable tranny??
2005 TL Intake Manifold?
f22a4 swap into a 94 del sol s
crx dx to a zc
JDM H22A fuel rail help
do i really have a jdm motor?
headers?
how do i choose a clutch!
How do I know what motor I have?
how do i wire vtec?
what will fit the y1 tranny
H22/23 Starter Help????
Making an H23 Vtech. Is it hard?
I know I'm new around here..but..
wondering if it'll fit...
how hard is it?
Blown Gasket Need Help!!!
swapping an H22a into a 94 accord ex
is it possible...?
Need more torque
Advice on modding out my hb
ECU for B18C1 question, Dizzy question - search failed
motor swap for 1990 prelude
which is better
02 accord coupe is K series possible????
Stock '85 Civic, Stay stock, or swap?
wich camshaft to buy for d15b?
h22a into 90 accord help
Loud Metal pinging noise at idle.
Question on CVT
Rough idle, not TPS plug, car doesn't have aftermarket cams
Big Problem
weird oil leek
ticking noise???motor shifting????? need help
d16z6 performance rebuild kits?
Header info
questions
H22A and F22B
Suggestions on clutch preference.
1983 Civic swap?
engine code 15
89 Prelude si engine? 100?
spoon headers-accord
H22A is only running on 3 cylinders help!!!
Ls/vtec Or B20/vtec?
JDM vs. USDM
engine light at high rpms
smoke
Accord SIR H22A Distributor
rmf header
can anyone help?...engine q's
Engine compatibility question
Ecu Pin Out Question- Cant locate some questions
Curious
Fuel injector question
Newb Civic swap questions
motor swap in the sol
In desperate need!!
99 Ek 2door hatch h22a-s swap
turbo the b16?
What car did this come from?
cv replacement problem crx w/ b16 swap
B21A1 mini swap
tranny splines b series
1.9 sohc vtec
zc civic motor help with timing
Type-r Gsr Head Confusion
95 accord engine swap
H22 headers
another b16 axle question..please help
Is it possible to swap an H22 into an 89 crx?
Question !!!
exhaust ?
radiator big enough
d15b into 86 CRX SI
Motor swap on my 91 CRX Dx
Parts For My Swap?
82 prelude Question inside
EURO-R manifold on a H22
B20 block w/ b16 head. Thoughts?
swap questions
need axles for jdm b16a
f1 clutch
best b series tranny for h22
h series motor, to a b series tranny!
compression numbers?
97 Civic Engine Swap
97 accord se
Engines for a 05 Civic
Spoon engine!
hey anyone know will a d16z6 transmission fit in a d17a2 vtec-e motor
important
Need Some Info... 95 Civic-90 Integra Gs
k20
B16a Fuelling Problem
Difference Between UK Civic VTI & SIR?
after act clutch and flywheel install
H22 vs F22 transmission
B18C5 Swap questions
Newbie to a Honda... looking into buying a 92' hatch w/ JDM H22
84 crx needs new motor
4 door engine swap question
DOHC ZC no start. Really need help
Skunk2 Throttle Body
Skunk2 Intake Manifold and Throttle Body
tranny problems
F22A to H22A motor mounts??
s2000 vs. audi TT
Civic Type R Or Integra Type R
JDM P73 ecu problem
Crx Power Steering Conversion
Jdm H23a
Engine Swap Question
Skunk2 Manifold.
H22 Help, Yet Again!
b16 or b18?
b20a
ZC Head........
LS vs GSR head.....question!
looking for a built 2.0
91 Accord Motor Swap
Are 310cc too big?
got a block but not sure what it is
k24
d15 vtec SOHC jdm swap help
building a gsr
tranny question??
Y1 JDM Tranny Parts - where to get?
accord/ridgeline motor swap
intake ?
intake ?
BSE for h22a?
B16/LS Hybrid Tranny: Have u done it??
Cam springs and retainers
WANTED b16 for cheap
Performance parts..help
jdm b16a bogging please help...
2000 engine swap
b16 wiring question
Need New Engine Help
Header Heat Tape
Im going NA what should i get?
difference between blocks
B20 pistons. what's best?
what engine is this h22 or h22a?
Best ECU for SOHC 1.6L ZC???
Quality Real Meat Nutrition for Dogs:
Best Air Dried Dog Food
Real Beef Dog Food
Best Beef Dog Food
