View Full Version : JDM Motor & Parts info/chat
Pages : 1 2 3 4 5 6 [7]
  1. b16a (SIR II) JDM ?
  2. 2003 4cyl accord service manual pages available
  3. OK, I have a JET chiped ECU, But I also want an APEXI unit, Can I have both???
  4. will a bb1 h22 work in my 92 prelude
  5. GSR Block -B16 Head
  6. b17 swap questions please help
  7. sohc vtec
  8. d15b v-tec swap
  9. SWAPPIN' question for the guru!!!
  10. k 20 93' civic
  11. 96 integra
  12. b16 vs prelude
  13. What kind of lsd do i have??
  14. ! ! How Much ! ! ? ?
  15. Building Ls/vtec
  16. d15b2 mini me?
  17. What Has Honda Done To My Car!?!?
  18. clutch cables for jdm b16
  19. starting to 2nd guess myself on swap
  20. just bought used engine what to do before install?
  21. B16 tranny on LS teg.
  22. b16 vs gsr tranny
  23. Engine Swap Questions
  24. i need pistons
  25. Stock fuel pressure for a ZC
  26. NA set up????
  27. 99 civic ex cabin wiring harness
  28. More Power help
  29. Help b16b axles question!
  30. jdm h22a obd1
  31. D16a1 engine swap
  32. how to tell lsd from non lsd
  33. Transmision prelude 89si
  34. JDM Cluster Problems
  35. free mods
  36. engine swap idea...
  37. Keyless Entry
  38. need advice on rods and pistons
  39. Hondata
  40. F20b or h22a
  41. OBD0 B16a Distributor
  42. type r parts... for turbo?
  43. compression ratio's on h22a
  44. Jdm H22 (fs)
  45. I Need A Usdm H23 Head Not Worked
  46. ZC Motor?
  47. which head for ls or b20 vtec build
  48. valve spring intsall. help
  49. Turbo Muffler on N/A Car
  50. VTEC question
  51. GSR Tranny vs. LS Tranny
  52. ECU Upgrade
  53. ECU Upgrade
  54. Is this from japan or a ripoff?
  55. 90 Integra swap
  56. Ls Vtec Vs B20 Vtec
  57. B20/ Vtec
  58. mini me conversion, b16 or b18
  59. engine build-up, mini me conversion or b16/b18
  60. b16block with gsr head?
  61. vtec
  62. lsd tranny
  63. Is Engine Swapping Legal?
  64. b16 tranny w/ls 5th gear(gear ratio question)
  65. Vtec vs LS ignition wires
  66. MSD Super Conductor Wires vs Hotwires
  67. how to tell gsr cams from type-r or b16a?
  68. B18C1 or B16B
  69. Advice on paint for acura integra
  70. What HEADERS for LS VTEC
  71. ZC 20 cam lobes
  72. do i have a vtec?
  73. gsr cams
  74. no cat straight pipe..? WORTH IT?
  75. Cani swap a Nissan Sr20det motor into a 1995 Honda Civic?
  76. Can my H22a type-r v-tech handle a turbo?????
  77. b18c1 header on b16a?
  78. I need some major advice!!!
  79. vtech
  80. B18A1 Head Rebuild
  81. !!please help!! B18A1 Moto Mount Brackets
  82. what is the hp and torqu rating of a stock d16y7 and d16y8?
  83. Vtec always on d15b
  84. Wtb Damaged Dohc Vtec B Series Heads, I Need 2
  85. Wtb Damaged Dohc Vtec B Series Heads, I Need 2
  86. b16 block/gsr head ?
  87. skunk 2 manifold
  88. adding to a jdm 96-00 d15b dual vtec
  89. LS tranny on a D16?
  90. Spoon engine
  91. JDM Side Lights
  92. JDM TCU for an H22 in a 91 Accord
  93. JDM Authentic EG9 Wing Spoiler ??
  94. best way to title jdm cars?
  95. emissions for jdm h22a
  96. JDM Type R header/Cat
  97. JDM H22 + Accord
  98. JDM/Euro Bump Lights!
  99. Euro-R H22 vs. JDM H22A
  100. JDM Interior?
  101. JDM OBD1 Auto GSR
  102. zc question
  103. Brand New D16A Motor
  104. JDM all Honda Civic Motors?
  105. upgrading brakes on gsr
  106. Where To Go For A B18b
  107. best engine swap
  108. installing vafc2
  109. jdm b18c1 short block where to buy
  110. B16a jdm sir I, need DC sports header
  111. Spoon drain plugs
  112. JDM motor USDM parts
  113. JDM b16a sir2
  114. Broken Vtec
  115. JDM b18b
  116. Jdm D15b Swap Gone Wrong?
  117. integra jdm conversion
  118. jdm d15b vtec w/ hf tranny on 91 crx?
  119. Save up for a JDM Conversion or spend the money on engine mods?
  120. Best upgrade for money JDM B16A
  121. Speedo Gear For Quaife Lsd 94 Ls Teg
  122. JDM engine swap
  123. J-Spec or Euro-R Accord Parts
  124. LS Trans slowing my GSR down?
  125. JDM Parts, Spoon, Mugen
  126. JDM Engines
  127. Jdm ITR cat specs
  128. jdm smog question
  129. h22
  130. jdm b16a 1.6 vtec motor swap into 95 gsr has some problems
  131. JDM CTR style headlights--running bulb size???
  132. do i have a jdm itr header?
  133. New JDM RS*R Exhausts
  134. B series with an i-VTEC? Possible?
  135. speedometer/odometer do not work - '87 civic
  136. JDM Type-R Accord (2003-2004) Engine Parts
  137. JDM Motor Mounts
  138. ls block with a b20 head! read!!!
  139. JDM D15B motor swap help
  140. JDM clip/ JDM clips for sale
  141. jdm service manuals
  142. jdm interior
  143. USDM GSR vs. JDM
  144. Jdm B18c1 (gsr) Is There Such Motor?
  145. JDM B16A question.
  146. JDM Parts anyone?
  147. b16a high revs why not b18b?
  148. swapping a 96Ls motor into my 92 Civic
  149. JDM type-r LSD for sale or need gsr/type-r final drive gear set
  150. LS Integra
  151. JDM H22A in an EG Civic Hatch??
  152. JDM B18c5
  153. JDM B16A Civic vs JDM H22A Prelude
  154. jdm type r conversion
  155. Jdm
  156. Turbo JDM H22a??
  157. jdm c32a swap into '92 legend
  158. JDM B16A1 Exhaust Manifold (Need to Buy)
  159. Where to start? '97 civic JDM B16A
  160. JDM One piece Headlights
  161. LS/VTEC overheating
  162. JDM engines wanted and for sale
  163. best JDM site???
  164. b16a with mods question ?
  165. OEM JDM HID spec units (DC5)
  166. Difference between JDM b16 and USDM b16
  167. JDM B18c With LSD and 93 JDM HEAD????
  168. gas gauge and light
  169. jdm engine codes
  170. Accord JDM mirrors
  171. JDM B16a Spotting!!!!!
