View Full Version : Silhouette
Pages : 1 [2] 3 4
  1. No power on windows and A/C blower
  2. 1999 Silhouette radio not working
  3. 2000 silhouette sputtering,dying,intermittently runs fine
  4. 2000 Olds MAF Clean/Replace
  5. Issue with traction control - 2000 Venture
  6. 2001 Rouch Idle and dies at low RPM.
  7. HELP!!! 2001 no pwr locks and windows. security sys, interior lights.
  8. Transmission Cooler Lines Leaking
  9. 95 van no power and low rough idle
  10. 2001 silouette gaskets
  11. How do you set the clock on the radio?
  12. New water pump and now overheating
  13. 2001 Silhouette starter always on
  14. Horn Not Working
  15. 2002 Silouette Premier AWD
  16. Rear Park Aid
  17. Load level suspension
  18. Rear window replacement
  19. P0141 Code
  20. Liftgate Rear Door
  21. front blinker works but doesnt
  22. 2001 silhouette transmission lines
  23. High Temp Light 02' silhouette
  24. 99 olds silho cranks but no run
  25. 2000 silhouette alternator regulator screw
  26. 97 silhouette power seats & door not working
  27. Radio system question
  28. Low Coolant Message
  29. ABS and TCS Light on Silhouette
  30. 2002 silhouette leaking
  31. 99 Olds mini van oil mixing with water
  32. 99 Premier gas smells and driver side window
  33. 1999 oldsmobile silhouette air bag light illuminating
  34. Low idle and going dead
  35. Headlights and Domelights Flicker?
  36. What is the coolant hose from Water Pump Bleed Connection?
  37. Overhead computer help
  38. New rebuilt, used engine, or repair
  39. modify the van
  40. Tail light elec. harness
  41. 97 Olds Silhouette power seats don't work.
  42. 97 Olds Silhouette power sliding door won't open
  43. P0141 & P0341
  44. 98 silhouette won't read the OBD II device
  45. coolant leak
  46. Full suspension replacement
  47. blower prob
  48. My Silhouette nightmare
  49. attempting head gasket replacement
  50. 2000 Premeire with VCP Radio Wiring Harness NEEDED
  51. 01' Silohouette VCR
  52. Interior lights always on
  53. '03 Silhouette accelerates on its own!
  54. Auto leveling problem, car is jacked up!
  55. 97 power door locks going crazy....
  56. 91 Olds Silhouette electrical issues
  57. 2000 Sillhouette AC Issues
  58. Transmission
  59. miss in engine
  60. Overhead Console computer not working
  61. 93 electrical gremlins
  62. Notice
  63. Shock and strut advise
  64. 2001 Silhouette Premier engine issues sputtering?
  65. Dexcool Litigation
  66. 99 Olds Silhouette 3.4L
  67. Glove Box Latch
  68. R134 capacity
  69. 2000 Olds Silhouette Front AC Warm
  70. 98 olds silhouette how to check fuel pump ?
  71. 98 Olds Silhouette Computer Problems ?
  72. Bad alternator? Autozone messing with my confidence...
  73. Park Aid inop
  74. O2 sensor
  75. break problem
  76. 1998 Olds Silo Gas guage question
  77. 2001 Silhouette Premiere
  78. Factory repair manual for 93 Olds Silhouette
  79. 2000 sihoutte transmission leak
  80. how to set the clock
  81. 99 Olds Silouhette Not Starting
  82. 2000 Olds Silhouette Heated Seats
  83. EGR Valve Location
  84. Big Red Battery
  85. Temp Guage Mistery
  86. Olds Silhouette BCM (Body Control Module)
  87. Hard Shifts, Slippage before lockup
  88. 2000 Sil. horn alarm intermittantly goes off.
  89. Tranny Problems
  90. 2003 silhouette PK3 key and keyless remote programming
  91. center roller on sliding door
  92. wont start
  93. Olds silhouette Heater core Replaced
  94. 1999 Dash Lights
  95. Electrical problem(s)
  96. AWD Disabled light
  97. 2000 Olds Silhouette - wipers
  98. Fan blower not working on level 3???
  99. 2002 Silouette Wipers Park Veritcally, Help!
  100. 98 silhouette rear leveling system not working
  101. 2000 Silhouette Rear leveling problem.
  102. 2001 Engine Problems
  103. 93 sil, no heat
  104. 97 Olds Silhouette-stuck in 2nd-trans problem?
  105. Whine/howl from rear end? Versatrak-AWD
  106. 2000 Silhouette rev limiter
  107. 2000 Silhouette Power Sliding Door Problem
  108. Rear fluid reservior
  109. Coolant Fans / Temp Guage
  110. need help on 3800
  111. engein problems
  112. saving money on heater hose replacement
  113. 3.4 engine intake gasket repair info.
  114. 98 Silhouette engine removal/rotation
  115. 99 silo heater and airshock problems
  116. 1999 Silhouette head removal ?
  117. Air bag sing on
  118. Low Oil Pressure light???
  119. olds 2000 van codepo171 lean burn bank 1
  120. Remote start on a 2000 Silhouette...........
  121. Cruise Control not working 98 Silhouette
  122. 2000 Silhouette Random start problem
  123. van problems, HELP!
  124. Wipers don't park in their place.
  125. 98 silhouette
  126. HELP!! Problems with a 2k Olds Silo..............
  127. 2003 Olds Silhouette AWD noise again
  128. class II hitch photo
  129. Broken triangle glass
  130. ABS/TRAC OFF light...I've tried about everything....
  131. 2000 Running Hot
  132. 99 Wiring Concerns
  133. 95 Oldsmobile
  134. Using my 1997 Silhouette in the Snow
  135. 2001 Silhouette sometimes won't start
  136. 04 Silhouette wipers on high only
  137. 99 Silhouette 3.4L Premiere edition stalls/wheezes/whistles
  138. 1999-2000 Code Sticker Location
  139. ABS & TCS lights on. Brake switch problem !?
  140. 2004 Oldsmobile Silhouette
  141. belt tensioner
  142. 2001 wipers won't park
  143. Fuel Filter Stud
  144. Fog Lights
  145. Crank sensor and Tachometer
  146. 3.4 l gm serpentine belt
  147. 3.4 liter engine
  148. 3.4 liter engine intake manifold
  149. 3.4 l gm engine
  150. 2001 Silhoette Coolant Leak
  151. HELP!! turn signals do not work!
  152. 3.4 intake leak
  153. Rear Window Wash Help
  154. 3.4 engine coolant path
  155. heating problems
  156. Foglights?
  157. 2004 Silhoutte Temp Gauge Problem
  158. 99 Olds Silhouette Van 3.8L engine
  159. 2001 breakes
  160. 99 silhouette Engine code PO101
  161. Small Coolant Leak
  162. 2000 Silhouette transmission, all of a sudden NOTHING
  163. 1999 olds silhouette alternator removal
  164. Bought a 98 Olds Silhouette
  165. terminal
  166. wont start, lights went out, error message on radio,
  167. Dimming Lights
  168. 95 Silhouette, Intermittent miss/stall then smooth HELP!!
  169. 95 Olds Silhouette ABS\Brake Light stuck on
  170. 98Oldsvan leaky roof
  171. Buying a used Silhouette...
  172. 97 Silhouette Driver Door Switch
  173. Codes for 2000 Silhouette
  174. Olds-2000-Silhoutte-Various lights come on like ABS, Air Bag
  175. OBD Connector Doesn't work
  176. 93 3.8ltr not charging
  177. Oil Pan Gasket Leak on 2000 Silhouette
  178. Changing out the radiator on the 2000 model
  179. Bleeding brakes
  180. EGR Cleaning
  181. Silhouette Cooling Fans
  182. HELP w/ CODE PO 441
  183. Resetting Oil Change Message
  184. 03 Silouette - rattle in left power sliding door
  185. 2003 Silouette - Park Assist not working!
  186. 2000 silhouette - transmission
  187. Silhouette Driver Side Window A Repeat Offender
  188. 93 Silhouette Dies after about 10 miles.
  189. no spark
  190. 97 Silhouette possible transmission problem?
  191. 98 Envoy keyfob work on a 98 Silhouette?
  192. 97 silhoutte gas gauge problem
  193. 98 Silhouette A/C not working
  194. 1998 Alarm goes off and shuts off engine
  195. 1999 Silhoutte
  196. 2001 silhouette a/c comp locked up
  197. Van Starts and Dies
  198. Finding a Valve spring for a 93 Silhouette 3.8??
  199. front wheel bearing
  200. AWD, changing the "Versatrak" fluid...
  201. 2001 Silhouette how to find and install powerdoor lock module
  202. Question About Aftermarket Stereo Install
  203. Replacement DVD unit
  204. Dexcool - New thread about a recurring problem
  205. 01Silho Suddenly No Function on Door Locks, Power Windows, Interior Lights, Alarm Sys
  206. Front wheel bearing
  207. elc blowing fuse on '99 silhouette
  208. 2000 Premeire with VCP Radio Wiring Harness Problem
  209. dead battery now radio is locked! HELP
  210. P1404, 0131, and 0137 Code Set
  211. Occasional miss, comes and goes 94 3.8
  212. Battery Check Light
  213. Shuddering between 1st and 2nd
  214. Code 420 Converter Efficiency below threshold
  215. rear a/c blows red hot
  216. jay2bears
  217. 2000 olds silhouette wipers
  218. Gas Cap Code
  219. Steering Failure... dire
  220. 99 Olds Silhouette firing order
  221. P0141 Code
  222. 1990 silohette steering popping
  223. 98 Silhouette power loss/rough idle
  224. Mysterious Coolent Drops
  225. 2000 Silhouette abs/traction lights on
  226. When It Rains It Pours
  227. Can't Lock
  228. 96 Silhoette suddenly sputtering, stalling, and surging
  229. 97 Silhouette ..power seats and power sliding door not working
  230. 2 questions on 02 Premiere: a/c Condenser replacement & Differential noise
  231. replacing head gasket in my 99 silhouette
  232. Low Coolant Sensor for 99 Olds Silhouette
  233. 97 Olds 3.4 Head gasket or Intake gasket which?
  234. replacing rear washer pump
  235. Power seat presets in a 2001 Silhouette
  236. 1997 oldsmobile AC/ HEATER problem
  237. 2000 Olds Silhouette POSSESSED!!!!!
  238. 1997 minivan codes P1870 and P0101
  239. Transmission
  240. 2000 Silhouette - A/C blows 15A fuse
  241. Engine Missing and causing hard shifts in Tranny on 2001 Silhouette
  242. 01 silhouette video player??
  243. Van Hubcap
  244. Won't Start 1999 Olds Silhouette
  245. how to check an OMRON 12088567
  246. 2002 Sihouette Foggy Headlamp
  247. motor swap
  248. Please Help!
  249. ABS/TCS light on...
  250. 2001 silhouette ac blows vent air
