2000 Sillhouette AC Issues
blueshirt
08-06-2008, 06:06 PM
I just bought a 2000 Sillhouette and the AC issues have been non stop. First rear ac was warm. A crimped expansion tube was the culprit. Then the front ac gets warm... first the left side then right then the back I am assuming because the freon was slowly leaking. They replaced the bottom side port 3 times then dye tested everything then said that the compressor was the only thing they could see leaking. replaced the compressor... same thing... works for a day then the front gets warm, again, starting from the drivers side then the passenger then the back. Any suggestions?
irgmfan
08-24-2008, 08:36 PM
Are you charging it with the rear AC fan off? On my 2000 the pressures were reading to high if I checked it with the rear on and I wasn't getting enough freon in it.
