Shuddering between 1st and 2nd
kidfam
07-02-2007, 01:21 PM
My 1998 Olds Silhouette has developed the following problem and I am not sure it is transmission related.
1. If I slowly pull away from a dead stop, keep the pedal constant and there is a load (like going up a hill) the van tends to shudder. I have also noticed this condition while traveling at highway speeds and a load in put on the van while maintaining a slight constant pedal.
I need help with this. Anyone had this similar problem? I can't figure out if it is Transmission, Ignition or Fuel related.
rockwood84
07-12-2007, 12:48 AM
could be dirty injectors, bad plugs and plug wires. try big bottle of a good fuel injector cleaner .if its been a while since the plugs have been changed
the factory plugs and wires are supposed to last 100,000 miles and the replacement ones same miles[100,000] also a plug wire too close to the exhaust manifold. try the simple and cheapest fixes first . get autozone to scan it and see if any codes come up good luck
kidfam
07-14-2007, 10:56 AM
Well the shuddering is from the torque converter being burned up. It is costing me $1800. Geez I really wish I could get rid of this van. It has cost me some much money and I still owe $2300 on it to the bank.
When I get it back I got to deal with the leaking intake manifold gasket too.:banghead: :shakehead
rockwood84
07-14-2007, 12:55 PM
sorry to hear that. sounds like another nightmare i'll probably run head-on into.did the filter get stopped up or did the mechanic bother to show you what happened to it?
rockwood84
07-14-2007, 07:49 PM
intake job will be $600.00 to $1000.00 depends where you get it done.
kidfam
07-29-2007, 06:46 PM
Torque Converter was gone. $1875 dollars
Woof
rockwood84
07-30-2007, 12:11 AM
i guess anything is possible with these vans. did the mechanic show you the torgue convertor he replaced?
