1999 Fog Lights
dakotafixer
04-21-2004, 12:03 PM
I have a 1999 Dakota Sport. I has factory installed fog lights, but they no longer work. I've replaced the bulbs, checked the voltage at the light connectors, the relays, even the switch itself. I checked the grounds and all connections, and still, no fog lights. Anyone else had this problem?
bobhathp
12-14-2004, 07:04 PM
I have the same problem. All other lights work except the fog lights.
My buddy who is a mechanic told me to replace the switch, which i havent done yet. Did you solve the problem with yours?
nfaber
01-07-2005, 12:11 AM
The factory fog lights on my 2002 Dakota recently quit working. I haven't trouble shot it other than to verify that the lamps are good, but I think I know what's going on.
I used to drive a 96 Intrepid that had the exact same headlight switch, and this intrepid had the exact same thing happen. I replaced the switch and the fog lights then worked until the day I sold it.
So I suspect that they simply don't have a very robust switch there. I'm thinking of just putting another switch on the dashboard to control the fog lights independently.
jreed3
03-23-2005, 11:14 AM
Probably too late for this, but I had the same problem and was able to fix it. On my switch the metal contact had broken off. I took a very small drill bit and a tiny screw and screwed it back on. The screw was from my remote control car.
It has been working for about 2 years now. Im too cheap to buy a new switch.
rod4bama1966
03-23-2005, 08:25 PM
i'm not sure, but could be a short from the bright light and fog light sensor.. the one that kills the fogs when you hit the brights
tah45
04-11-2005, 02:30 PM
Jreed3 was right...fixed mine yesterday. If you take the switch apart, becareful so you don't lose the tiny springs and contacts(look like little dumbells). There is a tiny contact in an S-shape that came off. I was able to put it back on the white plastic post(you'll see when you have it apart). the S-shape metal contact has two tiny holes in the center that fit on tiny post on end of white plastic post. I then melted the end to keep it on. Heat the end of flat screwdriver to accomplish that. Beats buying new switch, didn't price one but looked more expensive than fixing.
