View Full Version : Cougar
Pages : 1 2 3 4 [5] 6
  1. Remote Starter for 2000 Cougar
  2. battery not charging
  3. 1994 Check Engine Light
  4. Looking for Cougar restoration parts
  5. cougar 2000 service light
  6. '68 restoration manual(s)???
  7. 97 4.6L O2 sensor(?)s
  8. Fuel tank sending unit
  9. keyless programming
  10. early models and air bags
  11. need help finding aftermarket parts for my cougar
  12. 97 3.8 cougar bad prob
  13. No Manual
  14. 2001 Cougar
  15. shifting pointers
  16. Thinking about buying a cougar
  17. NEW POSTING 1990 xr7 BRAKE PROBLEM PLEASE HELP
  18. 99 cougar misses in high gear, help?
  19. Eclipse GSX for a Cougar?
  20. 94 Mercury Cougarhelp please
  21. Remote starter for 99
  22. Digital Dash
  23. 2000 cougar wont start
  24. Help anyone have 99 cougar 4 cyl.????????
  25. cold start dying...
  26. cold start dying...
  27. 92 Cougar Light Problem
  28. 2000 Cougar Lots of Problems
  29. 2000 Cougar codes
  30. Catalytic converter
  31. Free Upgrades
  32. 1981 Cougar, Can someone help?
  33. emission test ontario
  34. 92 Cougar Radiator Leaking
  35. Upgrading to 96 Cougar specs
  36. Transmission help PPPlllleeeaaassseee!!!
  37. FS: Mercury Cougar
  38. 99 Headlights
  39. Performance
  40. cougar computer
  41. New Cougar Sidemarkers
  42. 1999 Cougar window wind/rain deflectors
  43. parting out a 93 Cougar V6
  44. Make my 99 Cougar Faster!!!!
  45. Removing Computer on a 95 Cougar
  46. help!
  47. Stop Underestimating Domestics
  48. A little help here please...
  49. cool fan issues
  50. My '00 Cougar needs to get faster.
  51. '00 Cougar security help. PLEASE!!
  52. ?? cold air intake for '00 Cougar ??
  53. 1968 cougar 428 CJ
  54. front suspension identification
  55. Engine Swap:351w to a 460
  56. 83 - 92 Cougar/Thunderbird Manual 4 Sale
  57. Selling my 1990 Cougar
  58. 99 cougar hesitating while accelerating
  59. Transmission on 1996 Mercury Cougar
  60. 1995 Grease fitting location
  61. need help with my car!!!
  62. digtal dash not working
  63. What is this worth?
  64. fixing top
  65. customcougars.com
  66. Tire Size Clearance
  67. Jammed door lock
  68. Replacing an Alternator for an '01 Cougar
  69. Starting
  70. Good car or not?
  71. 1996 MErcury Cougar Fuse Panel
  72. sreetflight turbo
  73. Remove The Cat All Together????????
  74. 1990- fuel pump whining/dead battery
  75. i need parts for my stray cat
  76. 1968 cougar
  77. Thinking about getting a 99-02 cougar
  78. SO..whats it worth (1969 cougar)
  79. 2000 Cougar Check Engine/Anti-Theft
  80. High Flow Cat
  81. Break Hoses 99 Cougar
  82. EGR Valve replacement
  83. key stuck in ignition
  84. 94 XR7 Intake
  85. Catalytic Converter
  86. Cougar Transmission
  87. Exhaust and Computer ?'s on 95 Cougar
  88. 01 Questions...
  89. 99 cougar engine light
  90. Check out my website!!!
  91. 94 XR7 question
  92. Specs for 89' 3.8 N/A
  93. how do you remove fuse panel on 00 cougar?
  94. How Much is my '68 Cougar shell worth
  95. 1990 cougar XR7 for sale!!
  96. anyone know
  97. where do i refill transaxel fluid HELP for 01 cougar
  98. Help Plz!!!!
  99. 99-02 Mercury Cougar Challenge
  100. 99 cougar questions?......help
  101. 2000 Cougar Coil Overs
  102. 99-02 Cougar Lambo Kit Out NOW!
  103. fuel sensor replacement
  104. '05 Cougar Eliminator
  105. Classic owners
  106. Parting a '92 Cat
  107. 1997 cougar - how to remove booster
  108. 1996. xr7. installing radio help.
  109. help. removing panel for radio installation.
  110. 4.6L NO START!! plz HELP!
  111. Instrument Panel wont Light up anymore
  112. Cougar Engine Swap
  113. 99 Cougar alarm problem
  114. 2001 Cougar Fog Light
  115. Sound System
  116. 1999 cougar tensioner problem
  117. Factory Keyless on 2001?
  118. Changing Gauges
  119. '67 289 beef-up ?
  120. 2001 Cougar won't start
  121. 96 Premium Sound question
  122. fuel lines on '99 Cougar
  123. I hope someone can answer this question
  124. 96 cougar check engine light
  125. 2001 Cougar Gas Gauge problem
  126. 2001 Cougar CD Changer Problems
  127. 90 Cougar Windows
  128. Warning lights (above on headliner) 1999 Cougar
  129. 97 engine in a 91
  130. 99 cougar transmission slipping , blinking indicator
  131. change oil pump
  132. 73 Cougar electrical problem
  133. How about a bad TPS sensor that causes braking problems?
  134. Lcd Illumination Relay
  135. 1985 having partial acceleration problems please help
  136. Lookin to sell
  137. Trunk lid torsion bars
  138. Front and back speakers question
  139. Key Broke off in ignition 94 Cougar XR7
  140. 99 cougar air
  141. LED Scrambled on CD Player-'00 Cougar
  142. 1978 Cougar for sale in Michigan
  143. ATTN: COUGAR OWNERS, fuel pump recall
  144. 94 XR7 O/D light is flashing
  145. For Sale: 1996 Mercury Cougar XR7
  146. 94 cougar
  147. Fuse panel?
  148. Alarm System Snafu
  149. starting problems
  150. Exhaust System
  151. '87 XR7 5.0 boost
  152. Boost me...
  153. Need a radiator fan for a 96 cougar
  154. 2000 Cougar clutch
  155. Anti Freeze in the EXHAUST
  156. My Rods are Knocking and Transmission is slipping
  157. 89 cougar alarm
  158. Wtb:svt Uim
  159. Door sags
  160. Euro Tail lights for 99 Cougar
  161. Keyless Entry instructions
  162. oxygen sensors (cat conv)
  163. 1996 Cougar 4.6 Code # 1443
  164. i need to find the stereo wiring diagram for a 1990 mercury cougar
  165. 4.6l ENGINE SHAKING(HELP!!!!)
  166. Instrument cluster gone out
  167. questions about "moosing"
  168. Brake Problem
  169. How to remove Governor.
  170. 2002 Cougar Problem...Please Help
  171. 2000 mercury cougar - NO BRAKE LIGHTS, WON'T SHIFT into gear
  172. OBDII location on 94 XR7?
  173. Wont take gas, any thoughts?
  174. 289/351W swap?
  175. XR7 3.8 Swap to a 5.0
  176. FS:99-02 Cougar parts
  177. Thoughts on 1999 Cougar.
  178. 77 Cougar performance package?
  179. Help!!
  180. 1975
  181. 97 Cougar brake pedal mushy
  182. 1/4 mile
  183. 2000 Cougar
  184. Anyone Else Own an '81-82 Cougar Sedan (Monarch replacement)?
  185. questions
  186. 94 XR7 O/D light
  187. Fuse Number?
  188. New Website!!!
  189. Brake Problem
  190. 1970 cougar
  191. my cougar
  192. check gauge light
  193. 99 Cougar for SALE!!!!
  194. Wiring/Heat
  195. '92 3.8 Odometer problem - strange
  196. Vertical Doors On Cougar 99-02
  197. 96 Catalytic Converter, New Owner
  198. 1996 Cougar 4.6 rough idle
  199. Installing cluster with tach
  200. new cougar on the board
  201. heating coil
  202. Help!
  203. Cougar kickdown cable
  204. No Heat!
  205. New Cougar Body Kit !
  206. 2000 mercury cougar alternator
  207. !!!!Spoiler Desperately Needed!!!!
  208. How to install speakers in a 1994 Cougar XR7
  209. '91 Cougar switching from base instrument cluster to XR7
  210. 1997 XR7 Drive belt squeak and rear clunking
  211. 99 cougar having issues
  212. 90 XR7 won't start in the cold
  213. Humming noise
  214. 99-02 fuel lines
  215. 1990 XR7 Needs Parts
  216. No Heat
  217. 2000 cougar brake problems
  218. Makin My 93 3.8 XR7 Go reallly Fast
  219. Keyless Entry!
  220. Help
  221. TURBO KIT DUE OUT DEC 19th!!!!!
  222. 1990 Cougar Wiring for Stereo
  223. Electronic Flashers?
  224. Keyless Entry
  225. seatbelts in 1990 cougar
  226. Must Sell Cougar
  227. 88 XR7 parts needed
  228. Fog light question
  229. Odometer Reset
  230. Ffs?
  231. 94 XR-7 refuses to Start when hot
  232. 1999 Cougar Part Question
  233. Odometer stopped
  234. 1995 Cougar XR7 4.6L
  235. Water pump removal
  236. My cougar making loud noise, some one help
  237. clear taillight upgrade
  238. 1993 Tune-Up Info Needed
  239. 1993 Cougar
  240. tail light or back up lens
  241. cougar tranny help
  242. Button on Mercury Cougar 2000
  243. New member: 93 Cougar owner with painted dash and white gauges
  244. Selling my 71 Cougar Convertible
  245. Question with Cougar!
  246. Newbie.
  247. Do you guys have problems with your coug?
  248. Early Cougar Tail lamps
  249. 2000 cougar won't start
  250. dumb question
