View Full Version : 626/Capella/Capella Wagon
Pages : 1 [2] 3 4
  1. seat belt indicator light
  2. Timing belt contacts the front cover
  3. Can I tow a trailer?
  4. should i buy a 99 626? good car?
  5. Transmission fluid coming out of the transmission stick, Help??
  6. Weird Noise when I turn the steering wheel & Engine Light Woes
  7. ac problem
  8. 626 Tranny Problem?
  9. 1995 626 LX flashing o/d light
  10. Check Engine Light - jumper?
  11. possesed headlights 95'
  12. HELP...1997 v6cyl.....so many problems
  13. '91 lx 4 door body kit
  14. HELP...1997 v6cyl.....so many problems
  15. ProStart & New Transmission
  16. fuel filter location?
  17. 1996 626 Lx V6: P0170
  18. 87 626 conversion to manual
  19. radio
  20. 95 626 overdrive problem
  21. Rough Idle
  22. Radio unlock code
  23. 95 V6 626 Auto, runs bad after warmup
  24. i need a 2001 mazda 626 4 cyl engine... and help
  25. Check engine light is on & clicking noise from engine
  26. My Variable, pulsating, MAZDA 94 626 4-cylinder
  27. 1997 Maxda 626 4 Cyl. Manual!Check Engine Light is flashing!
  28. Help! How do i get the crank pully off?
  29. FS: Mazda 626 IHI RHB5 Turbo & Downpipe
  30. 626 in dash cd player
  31. how hard is it to swap 4 cyl to a v-6
  32. Parking & Head Lights don't work
  33. GM HEI Ignitor "fix"
  34. auto gearbox
  35. I need a transmission for a 97 626 LX
  36. changhig tranmission
  37. pcm relays
  38. evaporative emission control valve
  39. egr valve & codes
  40. Battrey won't start when cold
  41. '95 trans fluid
  42. '82 Mazda 626 no fuel
  43. electrical problem HELP!!!
  44. transmission problem
  45. high idle
  46. '93 626 Manuel stucking in gears.
  47. Cannot shift into Park - problem with lock-release button
  48. No Cold Start Mazda626/86
  49. Where is the thermostat located 2001 626 ?
  50. tcs warning lights
  51. 97 Mazda internal wiring problems
  52. Scheduled Maintanence-waterpump w/ timing belt
  53. maZDA spaRKS
  54. Squelling Noise?
  55. 03-05 Mazda 6 wheels on a 93-97 626?
  56. Engine Temp Gauge went to hot today
  57. transmission or cv joint?
  58. 2000 626 brake pad installation
  59. 626-auto swap to stick...problem
  60. Is there a way to bring the back windows fully down?
  61. Check Engine Light
  62. Help! Need to program new key for 1998 626
  63. Cruise Control For 626
  64. idiling rough and stalling 88 Maxda 626 turbo
  65. Alternator Replacement
  66. '93 626 Parts for sale
  67. How do you time a distributor?
  68. Mazda 626 2000 owner's manual
  69. vacuum chambers
  70. Problem finding 93' 626 fuel filter on engien.
  71. heatercore door 91, 626
  72. Dashboard lights not working.
  73. 2001 626 - Windows Won't Work
  74. Help Car Stall At 3,500 While Driving
  75. My 94 died on the interstate & won't start.
  76. differential bearing
  77. Problems filling fuel tank
  78. Aaarhg... I dropped the freeze plug in the block
  79. One more question about knocking or misfire?
  80. 16" OEM wheel to fit 1999 mazda 626?
  81. Where do I get a key made (that works)?
  82. Where is the fuel pump relay?
  83. Heater core 91 Mazda 626
  84. 90 626 engine codes
  85. After driven for about 5-10 mins my car wont reverse
  86. M plate 626- gearbox scrap?
  87. 87/88 626 2.0Diesel temperature problem?
  88. 98 626 won't start
  89. 89 626 turbo performance parts? Where?
  90. 1989 626 turbo, anyone know these cars well?
  91. Trouble pulling cv axel
  92. Possible Tachometer Problem
  93. A/C problem
  94. low voltage on rear running lights
  95. 97-626-2.5-Timing Mark on Left Camshaft???
  96. trans change
  97. A Soldier's story (trans out)
  98. 94 626 trans linkage problem
  99. 93 626 timing diagram
  100. no rear running lights
  101. 1996 a/c problem
  102. Knocking when slowing
  103. Weird headlight
  104. 98 Mazda 626 Gas, Spark Plug, Idle Issues
  105. 91 passenger door problems
  106. Mazda familia
  107. 1993 626 stalls when stoped, and a/c blow hot air
  108. '91 Mazda 626, engine rebuild needed?
  109. '97 Coolant Problems
  110. 1999 Mazda 626 keyless remote programming instructions
  111. i really need all the help i can get
  112. Error Codes
  113. 626 O/D off and engine light on
  114. Harmonic Balancer
  115. 626 tranny search
  116. 93 mazda 626 hold light flashing....please help
  117. 98 Mazda 626 automatic; low idle and AC problem
  118. please help
  119. Mazda 626 GT 2.0 that will not start
  120. taking out the dash
  121. 91 626 taillight problem
  122. I need some help
  123. 84 Mazda 626: Fuel Gauge Not working
  124. check engine code 23,24
  125. how to program used remote control for my 2000 Mazda 626 LX
  126. Headlight adjustment screws
  127. 2000 626 performance modifications
  128. low idle
  129. tranny code help ?
  130. fuel gauge
  131. suspension question
  132. 1999 626 2 liter gas mileage
  133. Backflushing
  134. transmission cooler
  135. keep or sell?
  136. 93 626 engine problem
  137. mazda 626 cronos head bolt torques
  138. rear cailpers will not compress
  139. 1996 626 alternator belt
  140. 1993 626 distributor parts?
  141. car shakes when you brake
  142. 1990 626 2.2 block interchange?
  143. AC woes
  144. looking for fiberglass hood for 1993 626
  145. Dohc question mazda
  146. driver side mirror assembly
  147. check engine light, malfunction
  148. temp sensor
  149. Mazda 626 Transmission or Engine Mounts
  150. 93 626 For Sale
  151. my list of fast, cheap, used cars with performance data
  152. I want a Bosal performance Cat-Back for my 94' 626 ES V6 (part# 112-201)
  153. AC Compressor making racket
  154. 1991 valve cover gasket
  155. Buick vs. Mazda
  156. 97 626LX 4cyl - Computer probs
  157. anyone know where to get a manual window regulator
  158. high nox wont pass emissions
  159. Starting
  160. Steering Wheel Adjustment
  161. Car overheats when AC is on (1999 Mazda 626 LXv6)
  162. engine problem? please help!
  163. early 626 help
  164. Timing Belt Replacement
  165. performance fule injectors and fuel rail
  166. 636 transmission diffult to shift into 3rd
  167. belt????
  168. Replacing Transmission Filter in a 626
  169. top speed 91 N/A auto
  170. Broken radio
  171. spark plug firing order
  172. Transmission
  173. 97 626 trans rebuild kits???
  174. p-flow for 626
  175. Demons in headlights
  176. Idle low, sometimes stalls
  177. 626 Transmission issues "HELP"
  178. 98 626 air cond belt squeal
  179. 2000 626 squeaks at start up
  180. 99 mazda 626 security key blinking no start!
  181. radiator removal 626
  182. Speed alarm in 93 Mazda 626
  183. FREE 626 steel rims
  184. 626?
  185. '98 626 Major Oil Consumption ????
  186. '94 Coil springs & shock/strut
  187. ecm codes
  188. plug gap?
  189. 95 2.0L engine ticking from injectors?
  190. '93 626 brake light - panel
  191. '95 - '96 Cronos
  192. water pump replacement 86 626
  193. Water leak advice
  194. 4 cyl rough idle and check engine lite
  195. 97 Mazda 626 LX 4cylinder
  196. Annoying Sound
  197. Please Help!!! I Need My Car... :(
  198. '91 mazda 626
  199. Need help... engine toggles between 2000-3000rpm
  200. Newbie Question
  201. idle problem
  202. Antifreeze pouring out of car! Major! Help!
  203. 91 626 oil filter
  204. power light is on
  205. My 626
  206. 99 GXI Estate remote locking problems
  207. Transmission valve Body
  208. mazda 626
  209. EGR Valve
  210. 1993, changed transmission filter, hold light comes on and it won't shift into third
  211. ’94 Mazda 626 Airbag Dash board light?
  212. 2000 626 Keyless Entry System install?
  213. '99 626 Running very rough
  214. Emergency Please, Please Help!!!
  215. Firing Order - Spark Plug Wire Set
  216. program key 98 626
  217. Oxygen Sensor(s)???
  218. transmission problems
  219. please help-looking for programming for 97 626 keyless remote
  220. Capella / 626 trans "Hold" issues
  221. Strut replacement
  222. 626 hesates in 1st and 2nd
  223. Wont start part 2 ( Please Help Desperate)
  224. Headlights
  225. 91 blower not working
  226. B&M shifter
  227. Engine code P0708
  228. Mazda worth fixing?
  229. No Spark
  230. 2000 626 sputters and nearly stalls at idle
  231. 1996 Mazda 626 anyone with this car can help me Fuse Panel
  232. 89 Mazda
  233. 1991 626 fuel pump problem
  234. wanna get a 99 626
  235. crank pulley broke off my 98' 626es
  236. air conditioning
  237. 98 Mazda 626 AC or Engine problem. Please help
  238. Car will not start 3
  239. Car will not start 2
  240. Car will not start
  241. problems getting out stock radio on a 96
  242. Intermittent Check Engine Light - 94 4cyl 626 A/T
  243. 1991 626-Wants to change GASKET, how? Anyone got a diagram of the engine?
  244. gauges lights stay on even when the switch is off
  245. Problem with Installed CD Receiver - Please HELP
  246. help!!! abnormal transmisson leak
  247. Removing tape deck for repair/replacement
  248. 99 626 hu install
  249. 97-V6 2.5 Water Pump R&R Procedure
  250. Mazda IHI Turbo
