View Full Version : 626/Capella/Capella Wagon
Pages : 1 2 [3] 4
  1. Mazda smoking
  2. 97 626 V6 Eating Coolant
  3. 93 Mazda 626
  4. 93 626 front headlights
  5. 1996 Mazda 626/ Sputtering and stalling during acceleration. HELP!
  6. 1996 Mazda 626/ Rattling in front passenger side tire when braking
  7. I need help please.
  8. 98 626 engine light on
  9. 95 mazda 626
  10. 98 626 EGR Valve
  11. 626 tail lights
  12. considering buying '01 i4 - please send recommendations
  13. 1998 626 specs for horsepower
  14. OWNERS OF 626's PLEASE READ!
  15. 626 security system - 1997
  16. Overheating-weird problem
  17. 2000 Ponitac Grand Am
  18. Hey Need Help BIGGG TIME
  19. Tornado in air intake related to check engine light?
  20. For Sale: 626 Gauges
  21. loss of power, regain it in 15 min.
  22. Battery charge light comes on intermittently
  23. Reversing / Fog lights on 98 626 SW
  24. immobilizer module - where is it?
  25. 96 626 LX Running ruff
  26. Ok guys, clueless girl question, be gentle with me ;)
  27. Manuel Window problems
  28. Air Conditioning problems PLEASE HELP
  29. Mazda 626 Tire /road noise
  30. Speedopmeter and Fuel Gauge
  31. 1996 Mazda 626 - Gas odour
  32. 1996 - 626 Cornos- Not starting
  33. 1999 626 Vacuum hose
  34. 2000 626 Tapping/Rattle When Hitting Bumps
  35. won't start
  36. FOR SALE: KLZE KL31 Cams
  37. transmission noise
  38. Radiator Flush
  39. need torque specs bad!
  40. mazda626 overheating and steering becomes hard
  41. Anybody have a similar problem: 1990 626 - No heat
  42. headlight alignment 1998 mazda 626
  43. body modifications
  44. Major hesitation under accleration
  45. PCV valve check
  46. Engine "Hum" between 59MPH-64MPH
  47. Help 97 626 check engine light
  48. '95 626 Automatc Transmission Shift Lever Problem?
  49. oil in radiator
  50. 1991 Mazda 626 - Check engine & washer fluid lights
  51. 91 Mazda & Some Needed Advice
  52. Replacing Heater Core?
  53. 626 for sale
  54. 98 mazda 626 need help w/ modifications
  55. 1989 Mazda 626 2.2L Non-Turbo Problem
  56. Please help 95 626 EX Manual
  57. what is a cronos
  58. 1999 626 heater wont work
  59. Are there any mazda websites?? -Please Read-
  60. Stuck CD
  61. Mazda Speed?
  62. my 626 - what model is it?
  63. FS: 19" Diablo 7Hart & 23" KMC V2 w/Pirelli Rubber!
  64. 1998 Mazda 626 (Need Advice.. Thx U)
  65. mazda turbo
  66. High speed vibrations
  67. Mazda 626 GT 2,5 V6 - engine running bad
  68. Beginner mods...
  69. MAZDA 626 gc POWER STEERING HELP!
  70. crack in the exhaust system
  71. 1995 626 keyless entry reprogramming?
  72. 626 wont get in reverse help
  73. 1993 626 ES Flashing Air Bag Light
  74. Oil leak, hardley any power to the car, and now my brakes are not really braking!!
  75. Power Seatbelts work and sometimes don't work
  76. reverse lights will not come on
  77. Air Condition Charging A/C
  78. Holy crap deisel!
  79. 1997 Mazda 626 Check Engine Light On.
  80. Help! Anyone's Opinion!!
  81. performance parts for mazda 626
  82. Desperately need timing diagram - 626 2.0 Twin Cam 1987
  83. need torques
  84. alternator help
  85. Automatic Seat Belts dead
  86. 94-95 computer for sale
  87. 90 626gt upgrades
  88. Plastic part on the undercarriege?
  89. Short shifter
  90. FS: my 92 626
  91. 95 Mazda 626 transmission
  92. Mazda 626 1993
  93. tranny swap?
  94. crankshaft position sensor
  95. need 626 modification help
  96. 1989 Mazda 626 Hatchback: Performance help
  97. car alarm won't turn off
  98. error code 0441 "Evaporative Emission Control System Malfunction"
  99. Changing rear brakes
  100. my car won't start
  101. overheating
  102. 99' 626 Part Out!
  103. Flashing Air Bag Light
  104. 2.5 litre ??????
  105. stereo and speakers not working...sound goes on and off
  106. Rims
  107. level of difficulty of changing trans on 98
  108. 86 626 problem starting after overheat
  109. 97 626 dead spot, hesitation & low Power
  110. Newb
  111. 89 Cruise
  112. 86-87 Mazda 626
  113. 97 626 hesitation on acceleration
  114. Help with stereo Install
  115. 93 & 94 Mazda Parts................
  116. Cold Air intakes, Cams, oil breathers, ect..
  117. Air Condition and Idling
  118. How/Where to sell used MAZDA parts? Please help.
  119. Do you need and MAZDA 626 parts? Check this out.
  120. 97 mazda check engine light - HELP!!
  121. '94 626 Shut down problems!
  122. is that the problem of battery?
  123. 86 Motor Block
  124. Grinding rumbling noise during startup
  125. 95 626 for sale
  126. possible 89 626 engine swap
  127. hesitation under heavy acceleration
  128. What do you think about my little car?
  129. mazda 6
  130. '89 Mazda 626 - No Spark
  131. Check Engine Light
  132. Alternator vs Battery Problem
  133. 93 maz 626 4-cyl, install starter
  134. 626 deisel
  135. pls help: rough idle (ODB II Error code inside)
  136. Air Conditioning
  137. Flame Thrower kit
  138. Turbo Converion
  139. Where can i get
  140. 1990 626 tail lights wanted
  141. My 626 doesn't start sometimes, but sometimes it does!?!?!
  142. wiring diagram for '87 mazda 626
  143. any1 done auto to manual conversion(89 626)
  144. headlights
  145. I Need a Harmonic balancer( crank pulley)
  146. 98 626 engine swap
  147. Normal running temp?
  148. horsepower question
  149. too kool
  150. Anyone Know Any Performance Sites?
  151. Mazdas are junk....oil pump.
  152. 89' 626 reverse glow guages
  153. Transmission stopped engaging/hold light flashing
  154. Is There A Guru Here? Need 200+bhp
  155. p/s grinding noise cold weather
  156. 1997 Mazda 626 keyless entry programing???
  157. 93 Mazda 626 transmission prob
  158. anyone intrested in a 88-92 front strut bar?
  159. 94 626 2.0L (4cly)to 2.5L (6cly)engine swap
  160. For Sale:ngk Laser Platinum Plugs, Free S+h
  161. 626 Anti-Theft system question....
  162. "HOLD" keeps blinking? what doe sit mean?
  163. set clock on 1999 626 (no manual)
  164. I have some problems, think you can help?
  165. 91 626 runs now but not right
  166. Computer (PCM) protocol for 1997 626?
  167. 87 mazda, little help here please
  168. brake pedal goes to far before engaging
  169. engine doesn't start after replacing timing belt
  170. 91 Mazda 626 Cranks But Wont start
  171. 97 mazada/95 probe gt/engine swap
  172. starting problems
  173. 01' 626 and 02'protege5
  174. AEM cold air intake
  175. short throw shifter
  176. headlight problems
  177. Rookie mazda user that needs help
  178. 87 mazda... wont start.. please post anything that may help
  179. No spark
  180. Changed air cleaner now wont start!
  181. 95 626 ingition
  182. 91 626 for sale
  183. 1997 626 Mods?
  184. just picked out a 626
  185. trans problem....suprise, suprise
  186. I need help in modifing my 626 ES
  187. Where can i get a body kit?
  188. 91 mazda 626 custom body kit
  189. 1995 mazda 626 for sale
  190. vacum leak??
  191. air flow meter calibrating
  192. mazda transmissions question!
  193. Muffler Replacement
  194. chassis wiring
  195. 86 mazda 626 wont start., Starter motor ground problem?
  196. Exhaust pipe size needed.
  197. Noise while starting engine
  198. 96' 626-malfunction indicator light
  199. speaker size for 98 626
  200. 1994 626 engine troubles
  201. 1985 Turbo conversion
  202. '95 Mazda 626 Stereo- Front Spkrs Dont Work
  203. '95 626 Remote Car Starter
  204. Alternator & Right Front Axle
  205. Blown headgasket - brainstorming
  206. Brake booster and master cylinder for sale CHEAP!
  207. 1991 626: plastic air box ex/imploded--worth fixing?
  208. 91 626 battery drain problem
  209. 90 626 not starting...Help please...
  210. white smoke
  211. 626 dies but not in reverse
  212. 93 Washed engine - now won't start.... help
  213. center channel for 92 audio system???
  214. surging/hunting 91 626 mazda in Drive...ok in rvrs
  215. Looking for front lip for 95' 626
  216. '93 626 mazda owners manual help
  217. 93 626 Transmission Problem
  218. how do i program keyless remote on 1999 mazda 626
  219. lookin` for`91 626 detailed engine specs
  220. lil 626 help
  221. 86 problem
  222. Parting out 1987 Mazda 626
  223. Failed Emissions test.
  224. 626 basic question-3 catalytic convertors?
  225. 626 problems need help
  226. Tranny won't shift from park
  227. 91 Mazda LX 626 Power Window Problems
  228. O/D off light?
  229. overheating problem??
  230. Tranny in the 626
  231. 93 Mazda 626 Valve Adjustment
  232. bought 94 626
  233. 92 Mazda 626; extreme rpm's
  234. ROOM fuse???
  235. crank position sensor question????????????????
  236. 1987 626 "Koni Shocks" for sale
  237. Break chatter limilar to ABS brake system kicking in.
  238. 1991 Mazda 626 -- won't start
  239. car won't start
  240. Body Kits for 86 626 i4
  241. 98 626 will not start when engine hot.....HELP
  242. 88 626 turbo CEL 16 & 42: What are they??
  243. 1995 mazada 626 fuel problems..help!
  244. Optima battery alternatives
  245. what is the firing order for a '93 626 2.0 4cyl
  246. Burn smell and CV boots
  247. help with probably purchase of 93 626
  248. Programing a Keyless Remote for a 98
  249. mazda 4 banger jdm cams wanted n.e. info?
  250. HELP!: 1981 Mazda 626 Modifications
