View Full Version : Park Avenue
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14
  1. Could this be transmission related?
  2. easier way to change oil filter?
  3. a/c compressor oil and orifice tube
  4. 2002 turn signal relay location?
  5. a/c problem
  6. AC clutch seized up
  7. "Security" light stays on
  8. Hard Shifting
  9. Abs codes
  10. rear camber on 90 PA?
  11. 96 P.A. Ultra 3.8 sprchrgr/SUNROOF. WATER STILL LEAKING!! PLS HELP!
  12. 92 PA Headliner
  13. 96 Park Avenue
  14. 99 PA Ultra. Fluid in inner tie rod boots???
  15. 92 PA Acceleration Issues
  16. Howl / Moaning under hard acceleration - 1997 Park Ave
  17. 92 PA Towing Advice
  18. draining cooling system through drain valve
  19. Throttle & Ignition Issues-92 PA Ultra
  20. difference between thermostats?
  21. 92 PA Change Oil Soon Reset
  22. 96 PA clicks when trying to start
  23. 2 tensioner pulley questions
  24. A/C clutch smokes after recharging
  25. 96 PAU intake manifold gasket replacement
  26. climate control doesn't cool anymore
  27. 92 ultra power steeering hose
  28. Monroe GM Shock Conversion Kit
  29. Turn Signal Problem Solved (I hope)
  30. 92 PA A/C & Cooling Issues
  31. 03 Park Ave Ultra vibration
  32. Need Radiator Removal/Installation Help
  33. Memory buttons
  34. 99 park avenue bucks and hesitates for 10 seconds then runs fine
  35. 1990 PA theft deterrent
  36. 95 PA running like crap again.
  37. replacing 3800 engine
  38. Roaring Noise - Front Left Wheel
  39. 1994 Park Avenue P0101 stalling, rough idle, loss of power
  40. vacuum line for fuel pressure regulator for 97 PA
  41. ticking noise after UIM/LIM replacement 97 PA
  42. How are 99 Park Aves? Lesabre 2000 on Vs. Park Ave
  43. 99 PA Ultra (Variable-assist steering) ???
  44. 2002 PA Air Shocks
  45. 99 PA starts weird/now a misfire
  46. 97 PA found antifreeze in air duct between air filter and throttle body
  47. Shaking Steering Wheel during slow braking
  48. 92 park ave turns over wont start
  49. 99 Park Ave Oil problem? Lifter Banging?(Video Included)
  50. 2002 Park Avenue (not Ultra)
  51. Verification
  52. Car still pulls and shakes
  53. 96 park avenue fuel injector
  54. Air Conditioning Trouble Shooting.
  55. 1994 Buick PA Headlight staying on
  56. Ext. temp doesn't display anymore - flashing display
  57. 98 PA MAP Sensor
  58. 92 PA Leaking Antifreeze but is not overheating
  59. Heater problems
  60. Recurring SE Light EGR valve
  61. 1994 PA Ultra Won't Crank
  62. tranny change now won't start
  63. Trunk pull down faluire
  64. 94 PA Headlights come on by themselves
  65. Blower motor Stopped working
  66. Oil Pressure 130 Pounds
  67. 2 climate control problems - related?
  68. Car pulls to the left - caliper grabbing?
  69. Turn Signal Problems...again
  70. 91 PAU wont start when cold
  71. traction control light comes on
  72. 92 ParkAve Engine Swap & AirBag Suspension
  73. 98 Park Ave Heater Problem!
  74. Rough Ride
  75. Little lights...and other things
  76. Horn repair/air bag replacement???
  77. Motor mounts for "97 Park Avenue
  78. Sensor location
  79. '99 Park Avenue will turn over but won't start
  80. Consult the PA Experts
  81. Rough idle, intermittent check engine light, and intermittently won't start. 94 PAU.
  82. new ignition key?????
  83. spontaneously "restarts"
  84. General Question About an Exhaust System
  85. '96 Park Avenue steering problem
  86. Buick Ultra Service Engine Light
  87. Vibration 01 Park Avenue
  88. 2000 PA New Instrament Cluster
  89. 92 Park Ave Heater Core
  90. 94 Buick PA Cruise Control Problem
  91. Park avenue 15" rims
  92. I have heard a rumor.
  93. Oil Pressure Sensor
  94. Heater: driver side not as hot as passenger side
  95. Does the new ABS computer need to be programmed?
  96. 02 Water Leak
  97. Too Much Oil? 92 Park Ave.
  98. 92 Buick Park Ave Air Conditioning Trouble
  99. What do you all think ?
  100. 92 Buick PA A/C Trouble
  101. Last little bit of help before i junk my car.
  102. 92 PA Ignition Coil and Coil Pack Wiring
  103. 1995 Avenue stall and a couple of more problems
  104. question about the crankshaft sensor.
  105. 92 Buick Park Ave Oil Change
  106. 92 PA leveler?
  107. 02 PA AC not kicking on
  108. Front struts
  109. 200K on timing chain assembly, time to replace?
  110. Can't get to 3000rpm
  111. 88 Park Avenue codes
  112. 94 ultra no acceleration
  113. 1997 Buick Park Ave. Location??
  114. What is this part??
  115. battery charging
  116. transmission mount HELP
  117. 92 Buick Park Ave head light issue
  118. 2000 pa suspension problems
  119. 91 Park Ave cranks but does not start
  120. engine and power windows die intermittenly
  121. Need help choosing a fuel pump.
  122. Rear View Mirror Wiring
  123. converting a base 98 park to an ultra
  124. 2002 PA Fuel Line
  125. Engine Rattle
  126. Is My Compressor shot?
  127. Leaking Antifreeze at intake gasket
  128. is this a good price.
  129. '96 PA A/C Acting Weird
  130. 91 park avenue heater/ac control head
  131. 96pa a/c issue
  132. Inside car hood latch
  133. 96 Park Avenue Gauges Fuse blows
  134. 96 buick park ave 92 pontiac bonneville
  135. 2002 PA air ride compressor interchange info
  136. 2002 PA continues to leak water in
  137. what to watch out for
  138. Transmission Pan
  139. 3 beeps and the Trac. Off & ABS lights come one
  140. A.C. blowing really weak
  141. A/C Compressor No Power
  142. a/c not working 02' pa clutch will not engage climate control prob also
  143. fuel pump or fuel filter?
  144. 99 park avenue jerking/bogging fuel cutting out???
  145. 91 Park Ave Gear Ratios
  146. 96 PA a/c blows hot and flashes
  147. 96 PA indicating lights
  148. just bought another PA ultra with transmission issues, need advice
  149. aux.input/output code
  150. Set timing
  151. Interior lights staying illuminated
  152. Is it possible to reprogram keyless entry fobs to work on other cars?
  153. How to flush radiator with dura cool '97 Park ave Ult?
  154. clacketey sound when I turn off my PA Ultra, coming from snout of supercharger
  155. How to replace idler pulley behind right side Mtr Mt. '97 PAU
  156. Knock Retard!!! after plug wire change
  157. 92 Buick PA A/C issues
  158. How hot does your PA run?
  159. 2003 Buick Ultra EVAP system code
  160. 91 Buick PA acceleration issues
  161. 99 PA Ultra needs a new cat
  162. 91 Park Ave wont move in any gear!!
  163. 94 PA Ultra Supercharged dies after warm
  164. 99 buick Park Avenue / ignition
  165. orifice tube
  166. a/c blowing hot air
  167. keyless entry for 1990 park ave.
  168. 2002 PA self-levelling air compressor
  169. 93 PA transmission replacement
  170. a/c problem
  171. 1994 PA Dynaride suspension
  172. Need help on how to access the Passenger side Heater blend Motor
  173. 96 park ave lamp replacement
  174. Transmission clunks in Park
  175. 1998 buick-remove fuel rail
  176. 91 Park Ave front ball joints
  177. 97 Park Ave self leveling system
  178. 2001 Park Ave lost remote function
  179. 99 Park Avenue - dies in warm weather
  180. 99 Park Ave Ultra left turn signal replaced
  181. 93 PA transmission problem???
  182. Remote keys
  183. 97 PA New Condenser Problems
  184. Lamp monitor
  185. 88 Park Ave having problems with acceleration.
  186. 91 park avenue headlights will not come off bright
  187. 2001 PA Ultra A/C Leak
  188. 2005 Park Ave Ultra Tranny HELL....HELP...PUH*LEEEEZE!
  189. Power Seat Recliner?
  190. Does my 95 PAU just have 2-wheel ABS?
  191. 2002 Park Avenue Service Engine Soon Light
  192. 98 PA programming new keys?
  193. Transmission fluid in radiator - Help
  194. Seat Transmission
  195. Knock Sensor
  196. Darn slow streets
  197. 1998 Park Avenue ABS Pump Question
  198. dash lights not working ...
  199. 92 PA stuttering while driving
  200. Factory chrome wheels???where can i get them???
  201. 91 Park Avenue Won't Start
  202. 99 park ave climate control drift
  203. Create Weep Holes on Doors?
  204. Engine mounting bracket
  205. 95 buick park avenue ignition locked, broke wheel pin that locks by forcing it
  206. 93 PA transmission question
  207. 99 PA a/c won't blow through dash vent
  208. 96 PA ABS - grabs when stopped - no codes
  209. Question????where to find one of these
  210. 97 PA Ultra (Supercharged) - Help! High idle - IAC?
  211. door handle
  212. turn signal issue
  213. Side Mirror Jiggles 2002 PA
  214. Buying '99 Park Ave Ultra, couple of Questions...
  215. Buick Park Avenue Ultra
  216. hood
  217. Car Value
  218. 91 park ave - how to replace ECU
  219. Gluing electric HVAC actuator gear
  220. Glove Compartment.
  221. Brake Pedal Pad Rubber Cover
  222. 1997 Park Avenue Ultra no start
  223. start problem
  224. Help!!!!
  225. 2002 PA Air Shocks?
  226. Problem with antenna and trunk release..
  227. Determining Paint Code
  228. ABS Brake Module
  229. 93 PA SC mod question!!!!!!!
  230. Check Engine Light - What Next
  231. A couple of problems.
  232. 1991 Park avenue No display on Climate control
  233. 1992 Park Avenue Will not start but turns over
  234. Tire Pressure - S Rated vs T Rated
  235. 96 Buick Park Avenue
  236. 92 park ave starting problem
  237. Disfunctional control buttons on the instrument panel
  238. loosing mind with dead 87 pa
  239. Tire Pressure?
  240. Park Steering Wheel Radio Volume
  241. Re: 1991 PA -> What is a tranny?
  242. Re: 92 Park runs rough when hot II
  243. Stalling and electrical components reset
  244. What do you call this part?
  245. Front end Wobbles after potholes
  246. Disable Auto-Wiper Sensor on 2001?
  247. Warning lights-ABS-Traction Control
  248. Wiring Problem?
  249. Programming fob 2003 buick ultra
  250. 95 PA ultra idler pulley replacement
