front speakers
hiduke89
08-22-2005, 11:42 AM
I want to replace the front speakers on my car but my ca has manual windows and i can't figure out how to get the window lever off...Nay suggestions?
matt09524
08-22-2005, 02:48 PM
Buy a newer car with auto windows? j/k Look for a small set screw somewhere near the car door panel or some kind of push to lock mechanism
mike_05_sunfire
08-23-2005, 09:32 AM
I have replaced the front speakers in my 05 and found the window levers a little tricky to take off. Just behind the lever (between door panel and lever on the post) there is a retaining clip that needs to be removed and the lever will pull striaght off. Hope this helps....
Cheers.
SirCull
08-24-2005, 09:19 PM
I believe that a body panel remover is a good tool to have, for any application. I'm planning on picking one up before I start some of my mods...and i guess you can use them just about everywhere on the car....also, i dont know how this will do, but if you get a screwdriver and wedge it up it might work...but dont quote me on that :)
hotbug1776
08-25-2005, 02:15 AM
believe it or not an shop towel can remove it from what I'v heard. take the towel, slide it behind the window crank, kinda wrapping it around it somewhat, I believe givit a "twist" and pull and the clip will come out with the rag. I''m going off of memory of something I read once so take it as you will.
mike_05_sunfire
08-31-2005, 06:37 AM
Using a screw driver does not work (I tried that first) very limited space, but a tool with a 90 degree bend in it will work. As for the shop towel, it is very possible that will work because the clip is only a wire spring clip, nothing too strong, but the next time I have to take the door panel off I will try it and let you know the out come..
StimpE
09-05-2005, 01:33 PM
I have tried the towel method, and it worked for me, the thing came off easy. THANK YOU
