97' jetta gl problem, any ideas?
pirate_at_30
03-09-2004, 11:58 AM
the starter on the wife's jetta went out over the weekend... got the original out and put back in the new one. hooked everything back up, but when i hook the battery back up the alarm instantly goes off. i tried to put key in driver door and turn but nothing. i cant even check to see if the starter is working b/c the alarm disables ignition switch. any other ideas on how to turn alarm off? thanks for any clues.
boschmann
03-09-2004, 04:39 PM
Was the alarm system working before disconnecting the battery, particularly the disarm function with the key in the driver door? Putting the key in the passenger door & unlocking should also turn off the alarm. If that works suspect the driver door switch. If neither work you can disconnect the alarm module (located just above the fuse/relay panel), disconnect the battery first. Reconnect the battery and check that pin #7 is hot (12V+) when either side lock is turned to lock position. Pin # 6 is hot when either side lock is turned to unlock position. If not repair the switch or wiring. If the switches are working replace the control module.
