View Full Version : Tires and Wheels
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17
  1. need help with offset...
  2. Neuspeed Race or Eibach?
  3. 18x7.5 front and 18x8.5 back
  4. Does shock affect the ride height?
  5. WHY ME? How can everybody else ride slammed?
  6. camber
  7. will a 5 lug bolt pattern fit my integra?
  8. interactive wheel program
  9. 15 in. Tenzo "Sinko" wheels & tires 4 sale!
  10. lowering a 94 integra GSR
  11. Suspension kit
  12. tire rubbing
  13. What kind of springs to get my boyfriend?
  14. Bridgestone Turanza EL42 Problems
  15. Best tire for the winter time?
  16. Motegi MR-5
  17. Is rear higher than front normal?
  18. Eibach Vs. NEuspeed (with Bilsteins)
  19. Ground Control, Tien, suspension and more questions!!! PLEASE READ!!!
  20. identifying wheels
  21. fitting 19's on a civic
  22. please help, pic of shock tower
  23. fav suspension setup
  24. break problem
  25. im stupid
  26. will 6th gen springs fit on 5th gen civic?
  27. spring numbers
  28. After 6 months of use check out these PICS of my skunk2 camber kit!
  29. 1" drop enough?!
  30. CRX wheels and brakes
  31. tokico hp's or premiums??
  32. integra springs on civic?
  33. Honda N600 lug nut and stud
  34. i want to be droped, but have stock springs and shocks? what do i do?
  35. scratched my enkie's
  36. A? about wheel size for a '91 Toyota pickup
  37. How do i remove REAR WHEEL HUB?
  38. Goldline Springs?
  39. which wheels?
  40. Yokohama Parada Spec 2
  41. What 16" Gunmetal 8 spoke wheels are avail. in 42+ to 45+ offset?
  42. camber dangerously off, what do i do?!
  43. shocks?
  44. Rims size chart for different cars
  45. Lug pattern for 1985 Nissan Maxima SE
  46. I need some info on coilovers
  47. sway bars
  48. Puttin On Lowering Springs
  49. Trailing arm questions?
  50. Camber Kits???
  51. ? on Primax Wheels
  52. Factory height without factory springs?
  53. MOTEGI MR7 Rims
  54. how low?
  55. questions about MSD ignitions/wires
  56. A-arms knockin away, need help
  57. 4 wheel disc conversion?
  58. Adjusting coilover suspension ?'s.....
  59. Desperately need professional opinion for my suspension problem
  60. tyre pressure vs profile??
  61. ride height dropping?
  62. axles(wheels,cv) making weird noises
  63. help AF Civic Tech!
  64. TIres or Tires& Rims
  65. coil overs
  66. wheel lock question
  67. Blizzak WS-50 mileage estimates???
  68. is this ok?
  69. ok what about these
  70. Wheel Question??
  71. tires
  72. Replacement tires
  73. What Size Wheel, What Kind?
  74. donor olds calais wheel fitment question
  75. Damaged Wheel Bearings?!!??!!
  76. Dark wheels (black or gunmetal) with a blue lip. Any out there?
  77. scratches
  78. transmission
  79. Bad to lower w/o aftermarket shocks? Plz Hlp
  80. negative camber on stock suspension
  81. name this rim please!
  82. ?? Will 20 inch rims fit on a '93 Cadillac Sedan DeVille ??
  83. 8 spoke civic dx wheels for sale
  84. need some good 5 spoke silver wheels
  85. Suggestions for Replacing Stock '99 Accord Coupe EX V6 Mich MXV4 Tires?
  86. Anyone with a STOCK Suspension 99-00 Civic Si ?
  87. Tanabe Springs with ??? shocks
  88. Cooper Tires
  89. Need some advice/help on lowering my Integra
  90. Axis Se7ens
  91. Votes on my website so far
  92. Mugen strut bars good?
  93. Bump Stop / Ride height question
  94. What's the difference in the real world?
  95. Wheel Size?
  96. Skunk 2 camber kit ?
  97. i need some help with tire sizes and such
  98. Rims safe for winter??
  99. lowered problems
  100. Need a 2" drop
  101. Question on wheels
  102. Lude Offset
  103. KYBs with a 1.75" drop
  104. Need info on all the air suspension manufadturers
  105. 99 toyota camry
  106. Need Help
  107. NEX coilovers
  108. Ground Control Coilovers ?
  109. Problem Tires
  110. Best Tire for 1998 GS400
  111. Best Tire for 1998 GS400
  112. water in gas
  113. Are these good tires??
  114. Neuspeed sport lowering springs
  115. air ride system?
  116. Bars
  117. Ford Pickup tire selection
  118. Wheels or suspension first??
  119. What To Do
  120. Are all Tie & Strut bars created equal?
  121. road side service
  122. True or false? Koni's tend to blow
  123. What is the best tire's make ?
  124. 16" or 17" wheels
  125. tire installation accident
  126. Low Profile tires
  127. Pirelli PSI, Please HELP!
  128. Need Spring Replacement without lowering vehicle.
  129. Coilovers
  130. What springs should I get
  131. Does anyone know the weight of Tenzo R sinko 15" rims
  132. 96 maxima se rim size issue
  133. Pics of my New Rims and Suspension
  134. My Tires are Rubbing!!
  135. spring crisis
  136. please explain coil-overs and shocks and such
  137. Coilovers?? What Good!
  138. Whats wrong with my torque wrench??
  139. Konig Tantrums For Sale Cheap
  140. Konig Wheels For Sale Cheap
  141. For sale: 18" wheels and tires
  142. Rear disc conversion on a 96 hatch
  143. aim/chassistech low boyz full bodied coilovers $600 why not?
  144. I cant lower but want wheels, what to do?
  145. buy these wheels
  146. coilover/shock combo?
  147. Shocks
  148. brakes on 89 accord dx (2door coupe)
  149. I need pictures
  150. odd ball bolt patterns
  151. everyone should get a sway bar
  152. blown ride
  153. Help!!!!!!
  154. Need to replace MX-4’s on my wife’s Caravan
  155. tire recomendation....
  156. Blown strut or not?
  157. Here's a quiz - does anyone know....
  158. New tire advice
  159. handling
  160. best suspension for 92 hatch with 17" volk TE-37's?
  161. What size tires for stock rims
  162. Pro Kits or Coil Overs?
  163. Falkens
  164. Advan RG wheels??
  165. Help which kind of 4dr 98 civic suspension is the best!!!
  166. help on using what tire
  167. accord oem's wheels
  168. rims smoke and are burning hot???
  169. kuhmo ecsta VS yokahama A520's
  170. bad pavement
  171. What brand is this?
  172. r35 skyline
  173. 4 18 x 8 LEXUS 5 bolt 45mm offset FOR SALE
  174. What about these Wheels\Tires??
  175. suspension problem
  176. what do i do first
  177. FS: 17 inch rims
  178. 225 wide tires on a 7" wide rim?
  179. seriously please help..
  180. replacing center cap
  181. type and size
  182. 17" or 18" on 330 Ci? Performance is the issue
  183. konig rim questions
  184. Shock Mounts and Boots
  185. Summer/Winter Setup
  186. Need wheel suggestions, PIC inside!
  187. 90-93 Honda Accord Neuspeed sport springs
  188. Switching to coilovers
  189. Eibach Integra Springs in a Civic???
  190. Coil over installation
  191. stock height of a 5th gen civic?
  192. Skyline R34 18's stock
  193. which coilover setup?
  194. Integra GSR rims and tires 4 sale ($400 + s&h)
  195. Borbet Wheels?
  196. spinning wheel galore
  197. does dropping your civic ruin your steering assembly?
  198. my infiniti
  199. Suspension Basics
  200. Velox Rims?
  201. 2000 Xterra Replace Front Rotor
  202. steering wanders on uneven pavement
  203. coil over adjustment
  204. Powder Coated Rims?
  205. Super Street October Issue
  206. please list some cool websites that show pictures of cars with 20' rims or more
  207. big or small
  208. Need to get rid of some new 17"s..
  209. clunk noise
  210. bump stops
  211. Civic vs. Integra Springs
  212. 17x7.5?
  213. Ford Ranger Oil Pressure
  214. need help
  215. How low should he go?
  216. honda civic 89 1.4 16 valves, unleaded(without plumb) or normal(w plumb) fuel, IMPORT
  217. oil gauge installation
  218. HR spring or coilover?
  219. Air Cylinders in my 89 CRX
  220. Studded Snow Tires - An Alternative?
  221. Slammed???
  222. How About Rotors?
  223. FAT LIP!! u need this! **Looky!! pics**
  224. Color Coded wheels!?
  225. Luke is gone !!!
  226. To strodda
  227. volks rims??
  228. Gas Gauge Problem?
  229. Help me choose new rims
  230. skunk2 camber kit
  231. Wheels for tires
  232. Been doing research, which true coilover setup?
  233. Upgrading rims and dropping, need help!!
  234. Delsol dropped
  235. Upgrading Tires/Wheels w/o lowering?
  236. looking or racing hart cp-r or cp-f wheels!
  237. Oil Recommendations
  238. Got my rims now I need tires!
  239. Pro Kit or Sport Line?
  240. 94 accord on 19's?
  241. help on lowering my car
  242. Bolt pattern???
  243. Installing Springs Help
  244. 5x108 RH rims
  245. tire rub
  246. 305/50/15 rim fitment
  247. the camber confusion CONTINUES
  248. kyb agx with eibach sportlines... camber kit needed?
  249. need camber help
  250. Sparco
