Automotive Forums Car Chat
Panoz
> GTRA / GTWS / GTS
View Full Version :
GTRA / GTWS / GTS
Pages :
1
2
3
4
5
New Panoz Owner
What clutch/flywheel? UD pulleys?
Panoz goes under the knife... no more getting passed by Minis ;)
Splitter material
Rear end re-seal
transmission problem?
WTB: Want a GT-WC
Off-Set Upper A-Arms
Cobra engine for sale on NASA Forums
Spectacular prototype crash in the LMS
Panoz gtra for sale.
Check those motor mounts
speed sensor
Manuals?
The Eagle has landed
Helpful Info on Ford Fuel Injection
Why not a Lexan windshield?
Brake Pedal Feel (not much!)
Fuel Cell Foam Breakdown - Chapter II
Track Times Post Spring Change
Looking for Texas or Sebring car
oil dipstick tube
Rear sway bar for the GTRA
More Power
VIR laptimes? for a relatively stock GTRA...
Considering a Panoz GTRA... Reliable?
Our GT-RA in LeMans Livery
Fuel pressure GT-RA w/ 5.0
Panoz page on wirewheel.com
Pirelli Scrubs
18 inch wheels
Rear Sway Bar question. For those that have one...
A Little Update on GTWC Chassis #3
Another New Guy
Fire Bottle Sage Continued
A sneak peak of my new graphics
Correct spark plugs for 351W GTS motor?
New buy here
Fuel cell foam breaking up?
Pi Dash
18" BBS Wheels and Pirelli Slicks
PI dash User setting for GAS?
Erratic Speed Reading on GTWC
Trailering a Panoz
Driving impression of GTWC
Mechanical/Tech issues tracking the GTRA
front tow hook
Part number for PGTWC windsheild?
Final Track Prep - Dyno run on 4.6 motor
New Guy Signing on!
Koni shocks
Maintenence costs?
VIR Review: Full course w/ NASA
IRL CCWS merger effects on Panoz
Extra reservoir on firewall for 4.6 cars
Squaring upper control arm with chassis/alignment issue. **Help**
How do you set the spindle bearing preload?
Sparco wheel is in the car finally...
Car #3 arrived and fun begins
GTRA -weight reduction ideas
CMP This Past Weekend
In Car Video
Waiting for Car #3
Oil Temp Sensor not reading
Anyone use a Motive power bleeder?
Sparco wheel came in... if you go Momo/Sparco you'll need a new quick release.
Front Brake Rotor Question
series car clutch pressure
Quick and easy way to re-furbish the dash.
Seat height, and the sight line.
She's pretty much ready for her first beating... I mean outing ;)
GTWC cars for sale
GTRA how much oil?
Comparision of GTWC & GTS
4.6 gtwc oil change
New wing treatment
I need ot buy a new fire bottle... anyone have a PN?
Corner Balance
New Panoz web site
Fire Supression System: Where are the nozzles? How do I know if it's charged?
Use black RTV to seal slightly seeping differential? Check the torque on yours...
Going through the GTS Torque Specifications last night, need some insight.
I only have 1 1/2 turns lock to lock... normal? Seems like very little travel
Is your "key" held in the car w/ simple wire? Here's a better way.
Panoz registery
Sebring winter test..not Panoz related
Flat bottom steering wheel recommendations?
Just to verify.... regualar 87 octane right?
new member car 56 track addict
How would you tack a bolt head in place to an aluminum seat rail?
Another Change When Running Slicks
Putting the Ultrashield seat in the Panoz
Torque spec
New tires and some personalization of the race car
Is it normal to have some play in an AN fitting? PICS
Panoz to appear at the Rolex 24 Hours
Got the other end of the battery adapter and cables... how to hook up?
Setting ride height
Routing of speed sensor cable
(www.allsprings.com) Cheapest place I've found for springs
Gary (or anyone)... Rebound setting on my new konis? New springs?
What are the reference points for setting ride height?
Help with trans/diff fluid swaps... stupid procedural/tool questions (PICS)
Is there a SCCA/NASA Class?
A few pictures of Gary Jones' carburetor setup on the 5.0, and a few questions.
Any interest in joining Mustang event at Carolina in March?
Working off the list
Any need to change powersteering fluid? Best method?
Car in the air w/ wheels off and in neutral, driveshaft/axle spin when on... Normal?
Anyone interested in stainless exhaust?
Repack wheel bearings and checking spindles
NASA Road Atlanta in March
Gtra, Gtwc & Gts
Why do these cars have two IAT sensors when mustangs don't? (PICS)
How is your IAT sensor secured to the filter mount/shield?
I keep hearing that I need to get a spare clutch cable... what fails?
I'm a waxer at heart and can't leave anything alone... fixing ugly.
Anyone find contact information for Coleman directly?
Question on removing inside bearings
Alignment procedure.
My fuel filter says, "MAR 22 06" on it... has 130ish hours... change?
Can I swap my 350lb srpings to the rear and get some 600lbers for the front? (or 550)
You might want to pull your motor appart and inspect...
My car arrived this evening!
Nut and bolt your car...
What's keeping your trunk lid on?
How are you guys insuring these cars? Fire/Theft/In-tow?
Altitude...
Pirelli Rain Tires Wanted!
Jacking Adapter
When good spindles go bad!!!
Guys that know 5.0s have a few questions (PICS)
Is this my coolant temp sensor? The wire has a PN but no label
What's the metal pipe in the air bride for? Check this out.
Does the chassis plate number have anything to do w/ the car number?
Educate me on re-packable bearings... what are these "caps" on the ends?
Guys... check your wheels do you run a front spacer? PICS
For anyone considering Amsoil fluids, they do make a synchromesh
Chassis "Band-aids" for Slicks
Anyone have the maintenance checklist sheets in a word doc?
Steering Gizmo Needed...
Panoz Factory Support
Name change from "Nonspecific" to "Panoz GTX"?
Some Panoz GTRA/WC Info
Well I found the wheel speed sensor... it's broken and w/o trigger. Pics of yours?
Do you guys have screen/mesh in the main radiator opening? I don't.
Problems Found And Solved
Where does the PI dash pickup the speed from? My speedo isn't showing.
HELP: I have an electrical sensor in my RR brake line... what is it?
HELP: Should the 2 piece rotor be solid? My rotor discs jiggle, they're a bit loose.
Parts list/application/source
Panoz GTx info and specs
Panoz Cars and Parts
Information I've gathered on the Panoz GT
Hello to Panoz GT-RA and Series Car Owners
Quality Real Meat Nutrition for Dogs:
Best Air Dried Dog Food
Real Beef Dog Food
Best Beef Dog Food
