View Full Version : Trans Sport
Pages : 1 2 3 4 5 6 [7] 8
  1. transmission problem
  2. Passenger window not working..
  3. Transport dies and won't start for 15 mins
  4. Hi, Just got a 1995 TransSport
  5. ODD PROBLEM - please help - clueless!!!
  6. Hard shift 1st to 2nd gear
  7. 93 transport-no start-but cranks
  8. 98 Trans Sport gauges
  9. LPG Conversion
  10. 95 Transport - dim lights/no power/speedo and tach not working?
  11. Tensioner pulley cutting into engine block - CAUTION
  12. sliding door replacement?
  13. 94 Trans Sport Power sliding door module
  14. 1994 Pontiac Transport *( ABS/ TCS lights are ON )*
  15. pwr locks/int lights/radio/pwr seats
  16. idle speed
  17. 94 TransSport Starting Problem
  18. 94 Transport wiring diagram
  19. 93 transport eratic idle
  20. 94 Steering Wheel Controls NOT working?
  21. 95 Transport 3.8 Overdrive TCC Sensor problem(s)
  22. 95 Transport
  23. missing @ highway speed
  24. OBD/REadiness Driving Procedures
  25. engine braking
  26. 3.1 versus 3.8 engine
  27. What is this part under the car?
  28. '94 blower motor, bolt on vs press on?
  29. Diagnostic With Obd1: Print That Page
  30. Replacing Heater Core
  31. Transmission - Please Help
  32. 94 transport burns a lot of gas
  33. Keyless Entry Remote Programming for 94-96 Trans Sport?
  34. intake manifold removal, fuel injectors and torque
  35. Another question regarding poor heat - aux water pump
  36. how many codes
  37. SLOW!!! to warm up
  38. Fixing my intake manifold coolant leak and need a quick answer..
  39. the song of the injectors
  40. 93 transport(3800) randomly won't start.
  41. code problems
  42. steering wheel radio controls swap
  43. programming keyless entry fob
  44. Radio does not turn off. Relation with electrical locks ?
  45. Engine stops when shifting into R
  46. Another Heating Question...
  47. trans sport outer door handle replacement.. help!!!
  48. Rear noise driver side96 Transport
  49. ABS TCS lights on
  50. Help!!!!! P1640, P1670
  51. 92 3.8 SE pulling right under accelleration, then left if I lift off..
  52. Transport 98 radio theftlock system
  53. Changing the Valve Cover Gasket!!
  54. Replacing valve cover gasket
  55. Transmission Hard shift Chevy Transsport Bj99
  56. Blowing Fuse (Mall/Radio/DIC)
  57. Fuel Presure Switch Location
  58. transport 3.8 1995
  59. 1998 ABS System
  60. 1998 Sales Brochure
  61. 1997 Tran Sport Montana poor heat
  62. Low coolant light and no heat related?
  63. Tcc
  64. Code PO449
  65. '97 Trans Sport--Fuel Problem? ECM?
  66. Help--Oil Leak!!
  67. 97 Transport starts then won't start
  68. heating problem
  69. Mileage has tanked - Oxygen Sensor ?
  70. Front AC Problem / Rear AC OK
  71. ehaust leak.. very loud!!!!help!!!
  72. trans sport wheels
  73. 98 Trans Sport/Montana - no start
  74. HVAC not blowing through dash
  75. Where is the OIL SENDING SWITCH??
  76. ABS acting up, 1992 Transport SE 3.8l
  77. blower function ok except for fastest (4)
  78. 1993 Pontiac Transport Transmission Problems
  79. 1997 transmission shift point
  80. '96 Transport AC Fan Quiting Intermitently
  81. transport 98
  82. 95 transport air pump?
  83. changing trans fluid, how much?
  84. HELP!! P0171 & P0300 codes
  85. 1993 3.1L V6 Firing Order
  86. A/C bypass on 94 3.8 trans sport
  87. Anyone have diagram of spark plug wires diagram for 98 transport?
  88. EGR Valve - 3.1 engine
  89. 1995 3.8L runing rough, stalling, shuttering
  90. tift deterrent relay 2000
  91. radiator cap hissing
  92. 97 Trans Sport Rear Power Window Intermittent Operation
  93. 97 Pont. Transport after frozen windshield wipers
  94. 1998 Transport power rear windows
  95. 1998 Transport Thermostat
  96. 1998 transmission unavailable?
  97. 1990 - No air (hot nor cold) coming out of vents
  98. 95 Trans sport new owner
  99. rear wiper doesn't work
  100. Where is the O2 sensor located on a '93 3800??
  101. 94 Pontiac TransSport won't crank fire up
  102. serpentine belt slip
  103. crankshaft pulley change
  104. Odd electrical problem
  105. automatic shifter won't engage
  106. Very Strange Electrical Problems.. Need Help Please!!
  107. HELP!!! 1995 electrical problems???
  108. Radio Backlight
  109. Heat gauge
  110. Automatic Door Cable!
  111. back hatch lock
  112. Pontiac Transport Electric Door Locks
  113. No HEAT and LOW engine temp solved!!!
  114. 1998 Pontiac Transport Drives Sluggish
  115. Tie - Rod End
  116. Low Engine Temp Since Cold Weather?
  117. 1997 transmission problem
  118. Power Window Dilemma
  119. 1994 3.8L Trnasport Tranny problem
  120. 1998 Transport NO HEAT!
  121. blower motor finally went
  122. GoPed Vs TransAm!!!
  123. bug shield
  124. 1992 transport won't start
  125. 94 Trans Sport and Bonneville tranny
  126. !993 Chevrolet Lumina APV occasionally no spark to start
  127. Rear door handle?
  128. Electrical heater
  129. wtb remote p/n 10202295
  130. 1994, 3.8, No Power
  131. Rather Urgent Headlight & Brake Problem
  132. 1992 Trans Sport Remote Progamming ?
  133. Stud length with new rotors 1995 Trans Sport
  134. snaping in front
  135. wheel interchange
  136. 1993 Trans Sport
  137. pink,red antifreeze and problems
  138. Van starts and then bogs down and dies after 5 to 10 seconds.
  139. HVAC Fan
  140. Timing
  141. rpm fluctuation at highway speeds
  142. 94 Transport ....no fuel
  143. no spark after fuel pump replaced
  144. AIr lock: just for the record
  145. Clear Service oil Light
  146. passenger side noise????
  147. over heating problems
  148. Heat Gauge
  149. 1995 Trans Sport rear bike tire air pump
  150. where is thermostat located
  151. Front Ball Joints/Tie Rod Ends 1995 Trans Sport
  152. Twisty, Lazy Seat Belts on my 1995 Trans Sport
  153. 1995 Transport: Exterior Door Handles?
  154. 95 Transport: Front Door Panel Removal?
  155. Oil in radiator and overflow bottle
  156. Air Bag indicator
  157. Transmission Hard Shifts
  158. head lights
  159. 1997 Lack of sufficient heat not due to thermostat
  160. where to buy an automatic transaxle
  161. Starting Problem
  162. power sliding door-diagram
  163. 1995 trans poart wiring diadram
  164. Compression
  165. rear/mid section clanking over bumps
  166. 1995 3.8 Crankshaft Position Sensor Replacement
  167. 1996 trans sport transmission swap
  168. My 1995 Pontiac Transport
  169. Hesitation
  170. Diagrams available
  171. 3.4L van intermittent no-startproblem/fuel pump relay chattering
  172. 1995 Transport Problems
  173. wirning diagram tp-sensor and egr-valve
  174. Wiring diagrams
  175. ECM-Problem (OVERDRIVE)
  176. 1995 Radio
  177. OBD Codes
  178. How to find the remote RECEIVER in a 1995 Trans Sport?
  179. transmision
  180. Hello all 1995 Transport issues
  181. 98 Transport - Doors do not lock (but unlock OK)
  182. 97 Transport cooling fans
  183. Update on "front end syndrome"
  184. automatic locks???
  185. 98 Transport "service engine" light
  186. Transmission problems
  187. Insane Lights on Transport
  188. 35mph-40mph not change 2-3 overdrive automatic-transaxle
  189. 1990 transmission
  190. Antifreeze going down ever so slowly
  191. Blue Smoke From The Exhaust TRANSSPORT3,8L-95
  192. hight hco and co in the gases 3,8l tpi engine
  193. What does code 53 mean???
  194. Wheel Hub Rip Off
  195. 1993 Pontiac Transport Wiring Diagram
  196. Fuse Constantly Blowing
  197. Bad vibration in puller fan
  198. 95 Transport Frt Rotors
  199. Radiator Fan Switch??
  200. 1993 headlights any different for the European model?
  201. 95 3.1 wont stay running timing?
  202. Slight "clunking" in the front end?
  203. 3.8 Transport is bucking and missing real bad from about 40-60 MPH.
  204. Buzzing Vibration at 2000-2500 RPM
  205. Need help for 3.1 engine
  206. 1993 3.1
  207. Front end syndrome
  208. 98 Trans Sport Window Regulator
  209. Best Place to Buy Hubcaps??
  210. OPINIONS on Rotors and PADS?
  211. HELP - Where can I order parts for my Trans Sport 2.3 ?
  212. weird OverHead Problem ! HELP Pls. !
  213. 1st mod thing
  214. 1995 Trans Sport Front End Noise
  215. Need Electrical Connector for Brake Light Assembly
  216. HOw to fix low fuel light?
  217. 95 Trans Sport Spark Plugs
  218. Speedometer reading too fast
  219. 1998 transport driveline noise
  220. 1995 Transport 3800 shutters sparaticlly
  221. Tire advice
  222. Low Coolant Light flashes
  223. Trans Sport 3800 1995 oil filter location?
  224. Reading trouble codes
  225. How to fix the 1996 Pontiac Trans Sport Power Sliding Door
  226. Cranking problems on 95 3.1 TS
  227. Stalling and Engine Light
  228. 2 button remote wanted
  229. intermittent window problem??
  230. Adjusting HEadlights at home
  231. Broke Rocker Arm Bolt During Gasket Replacement
  232. 98 transport cd player error
  233. How many have had their Trans Sports stolen?
  234. Steering column guard for a 1995 Pontiac Trans Sport?
  235. Door handle broke
  236. Turing over problems
  237. 1994 Transsport HELP!
  238. Yet another keyless entry question
  239. Greetings from German Pontiac Forum
  240. Imaginary rumble strips???
  241. Transmission Problems
  242. Difference between a '94 and '95 steering column? Steering column guard..
  243. service lights on???
  244. speakers in dash
  245. fuse problem
  246. Passenger window won't move???
  247. Low compression in 1 cylinder
  248. Overheating at idle 90% of time
  249. Changing drive belt
  250. Olds vs Pontiac same,but different
