1992 LeSabre cooling fan wire
lesab92
03-02-2005, 03:00 PM
There is a wire coming off the bottom of top resistor on the larger cooling fan (not the battery side of car) which appears to have been connceted somewhere. I can't figure where this wire should be connected. Does anyone know if this is a ground wire. One end is connected to the resistor and the other end is just floating in thin air.
spinne1
03-02-2005, 07:38 PM
I made a picture of my fan wire layout. It is here:
http://mywebpages.comcast.net/bandrchristy/pics/coolantfan.gif
I believe this should help. The two wire connector is a push in and lock type. All wires touching the white resistors are soldered to the resisters.
lesab92
03-02-2005, 11:48 PM
Thanks, that's exactly what I was wondering. Thanks for the drawing. When looking at the fan from above, you can't tell where the wire was connected to; but because it's so short, I thought it had to connect to something very close by.
