97 lesabre driver side wet
s426
02-20-2005, 12:53 AM
hello every one
the driver side has are very wet after rain,while in park,
i found that the water is coming from the corner beneath the dashboard.where the emergency break bracket.
that after i took the seat and the carpet off, and changed the carpet,
i test it with windshield fluid alone using wipers, so the liquid was blue.
what should i do. take the dashboard off. and look for that crack, well that help to find it.
i took the top of the outside vent off, i put water in it. i put water on the left side under the hood, nothing coming inside the car, but when i used the wipers and fluid it comes inside. and when it rains,
any idea how to find it, and fix it , thank you
yogi_123rd
02-20-2005, 10:15 AM
The proble sounds like the outside drain holes are clogged with leaves, causing water to pool in the windshield wiper motor area. Remove the outside grate where the motor arm comes out of. Clean the drain holes that are in the extreme corners.
s426
02-20-2005, 12:32 PM
hello
thanks. i`ll try that .
the vent opening <the corner> where it facing the wheel.how deep is it.i`ll try to put a vacum hose there.see what happen.
thanks again.
thanks again.
