View Full Version : Technical
Pages : [1] 2
  1. steering lock
  2. 240 sx
  3. RB25 turbo/fuel upgrade
  4. Starter Removal - 1992 240sx
  5. RPM Trouble
  6. no power. just reringed
  7. car dies when i come to a stop at a light or just sitting there in park....??
  8. 240sx s14 CARB Legal Cold Air Intake?
  9. overheating problems with 240 sx
  10. problems W/motor
  11. engine sputters when I hit the breaks and eventually stalls
  12. 96 200sx se Waterpump
  13. ka24e camshaft clicking noises
  14. loose exhaust?
  15. engine swap S15
  16. engine torque damper ka24de install??
  17. ? ? How ? ?
  18. acceleration lag
  19. Advice for a newbie
  20. P/s lines for sr swap
  21. Changing distributor cap/rotor
  22. Need Help Hooking Up Tac
  23. 92 240sx Acceleration problem.
  24. KYB AGX vs. Koni Yellow Adjustables
  25. RB26DETT Or SR20DET?
  26. Wheel Size Swap
  27. exhaust
  28. How To Turbo Your 240sx
  29. I Need An Rb25 Wiring Diagram
  30. a little shakey
  31. vq35de swap?????
  32. headlight problems, I got your fix!
  33. Newbie needs suspension tips......
  34. need info about s15 and s14 which is better?????????
  35. Lots of Shake.
  36. Check Engine Light just turned on
  37. 240sx brake upgrade
  38. radiator leak
  39. 240 plans??
  40. sr20 radiator
  41. Welding the spider gear on a 91' coupe
  42. transmission leakage
  43. s14 Boost Tap/Controller Help PLEASE
  44. filter in the oil pan
  45. filter in the oil pan
  46. sr20det running rough
  47. consult cable
  48. 1990 240sx diagram/
  49. sr20det questions?
  50. Tranny Question??
  51. Oil for SR???
  52. Oil light?
  53. In need of a few wiring diagrams for 89 240sx
  54. 5 Speed - New Syncros?
  55. AMS Turbo Kit
  56. Speed Limiter Eliminator
  57. Brakes
  58. Overheating question on 95 240sx
  59. gearbox conversion??
  60. 1992 240sx wont start....
  61. squealing noise from engine
  62. Basic Engine Diagonostics Thread
  63. Need Help!!
  64. sr2odet wont run right
  65. Error Code P1400
  66. Restore's Engine Restorer: Work, Whatever, Full of shit?
  67. some wacky going ons
  68. no power to main fuse block under dash
  69. removing egr ?????
  70. Motor Importer
  71. 93 240sx swaped to 2nd gen. RX-7?
  72. SR20 differences
  73. CA18DET T28 turbo upgrade
  74. 300zx maf
  75. Where do I purchase...
  76. Electrical problem?
  77. newby needs help ka24e head swap???
  78. KA24DE cam to shim clearances
  79. jdm caliper fit on 240sx
  80. stock t28 300wheel?
  81. rebuild ?
  82. Turbo Kit vs SR20DET swap
  83. 240sx Front Clip Swap?? How Much $$
  84. Compatiple Parts?
  85. Lexan Windows
  86. cant rev pass 2k. maf? fuel?
  87. Strut Tower Bar good for drifting?
  88. Clutch troubles in 1992 240SX
  89. Awd Rb26dett 240sx..
  90. drifting can crack bumper?
  91. Uh oh... engine swap questions
  92. Sensor problems?
  93. S15 Front End Conversion
  94. n/a sr
  95. Difference between 95 & 96?
  96. Brake fluid
  97. 240 v8???
  98. alternator removal
  99. Sr20det
  100. egr system
  101. Side Skirt Identification...
  102. Help... Building Engine Questions
  103. S14 Radiator Support
  104. New Radio
  105. Tension Rods
  106. Will this swap work?
  107. turbo basics
  108. speedo cable
  109. dizzy vs coil
  110. Problem w/ CD player
  111. ignition??
  112. Clutch start switch
  113. How do I empty my gas tank?
  114. electro fan
  115. ch ch ch check it out
  116. Removing fenders?
  117. Did I kill my starter, please read if you know anything about a cars starting system.
  118. help on engine info
  119. Power Mirrors
  120. Engine Swap Question!
  121. Automatic transmission troubles
  122. How do I remove dash?
  123. 1992 240sx grinding problem
  124. Download Factory Service Manuals for Nissan
  125. Master Brake Cylinder and Fuel Injectors
  126. How do I slow my signal light?
  127. car with LSD
  128. Odd Driveline Vibrations
  129. major no start overheating issue
  130. 240sx RB26DETT engine swap
  131. help plz
  132. KA Stalling, and transmission question
  133. diffrence between a s13 and s14 motor
  134. Door lock relays
  135. Spark plug gap setting on a 1989 240
  136. Coolant problem
  137. MY 89 240sx keeps stalling out
  138. offset stock wheels?
  139. Gas mileage
  140. MY automatic seat belts aren't working
  141. June 3rd - Grip & Slip @ Willow Springs Horsethief Mile
  142. Electrical Problem
  143. Engine swap question: Ka-e to de
  144. 240sx with ca18det
  145. VG30DETT in a 240?
  146. another check engine light question.
  147. check engine light
  148. S15 6spd tranny question
  149. Gearing Question
  150. Transmission
  151. Rb25det On Its Way!!!!!!!!!!!!
  152. quick KA-T questions.
  153. stalling
  154. Alright Cut the Bull!!!!!
  155. start up
  156. s13 front end alternative?
  157. Idle question
  158. car wont start
  159. SR20DET problem...need help!!!
  160. Tie Rod Install
  161. Stock wheel size
  162. Drift Question
  163. SR swap question
  164. KA24E distributor trigger wheel(s)
  165. engines
  166. What the hell?
  167. Suspension
  168. PRNDL switch on Autotrans
  169. Too late for turbo?
  170. manual tranny fluid
  171. s14 motor into 1990 S13
  172. handling
  173. Timing problems
  174. sr20det install problem, help please
  175. 200sx/240sx 5 lug brake uprade
  176. Need help on opening my throttle body
  177. need help getting sr20det back running
  178. 240sx vh45de swap???
  179. Ebay intake
  180. sleepy eye, trying to fix
  181. Short shifters
  182. underdrive crank pulley
  183. Cold starts take a few starts
  184. Lowering my 240 and need some advice
  185. from AT to manual swap S14
  186. 240sx SOHC cams
  187. R4 cam from nissan motorsports
  188. Clutch problem question.
  189. t25 + rb26 turbo = s15 turbo?
  190. transverse KA24 into '91 240sx
  191. what engine is this?
  192. T25 vs. T28??
  193. 1991 240sx a/t swap to s14 sr20det m/t
  194. 1986 Nissan 200SX fuel injector removal
  195. ca18det
  196. MAF!!! need help!!
  197. Wiring Problems!!!
  198. idle problems need help................
  199. KA-T oil lines
  200. 240sx w/ KA24DE info
  201. Thermo Gasket Question
  202. 2JZ Swap
  203. Stock SR20 power and peppyness
  204. WTB: Vertex body kit
  205. Weard Heat problem
  206. best motor for s13
  207. Throttle Position Sensor (TPS) Adjustment
  208. S15 Turbo upgrade
  209. thermostat housing problem
  210. need help with swap VG30t in a 89 240sx
  211. Jdm Rhd S14!!!!
  212. Check Engine light intermintent - starting issues
  213. Egr
  214. seatbelt malfunction
  215. Warning Please Read
  216. Question on EGR
  217. Service Manual 240sx/s13/180sx
  218. Compression Check
  219. Transmission swap for auto 95 240?
  220. battery replacement?
  221. RB25 stock boost
  222. problems starting in cold Nissan 200SX
  223. screetching in the front right wheel
  224. 300 part --> 240SX
  225. brake system upgrade
  226. SRT20DET or CA18DET Silvia
  227. 92 window motor in a 95
  228. Legality
  229. Fast blinker Part 2
  230. popping the hood
  231. SR20 overheating just when idling
  232. Oil question.
  233. motor swap
  234. where to get vlsd output shafts?
  235. Suspension problem
  236. Turbo KA/SR20 Swap Cost Effectiveness?
  237. what are average speeds of 240sx's with turbos?
  238. low beams inop
  239. need help with a 87' 200sx
  240. new brake stuff
  241. slow 180 owners
  242. 1988 200sx Ca20
  243. Interior light on at bad times
  244. help
  245. swap
  246. Engine trouble -- 1984 200SX Help!
  247. Front End Clunk
  248. helllppp!!! cant get my 240 to a sudden stop!!!
  249. s12 ca18et question
  250. clutch
