View Full Version : Sephia
- 1994 headlight
- 2000 KIA Sephia - Help me go faster!
- '00 Sephia heat
- Tire Compatibility Kia Sephia 2000
- Rear trailing arms or more??
- New Kia Incentives and Rebates – Dealer Negotiation Tricks Email
- White Smoke Out The Exhaust
- Sephia randomly sputters
- Timing Belt Time Bomb
- 2001 Kia Sephia Won't Start
- $282 for new plugs and wires?
- Trunk light problem
- 1997 Sephia - Alternator belt/Power steering woes
- 1996 kia sephia won't start on the rain
- 99 Kia sephia turns over, wont start
- 2000 Kia Sephia misfiring randomnly
- Fuse Guide
- help.. 2000 kia sephia
- Sephia 1,5 automatic - ANY HELP PLEASE!!!
- 98 Sephia Wont Start
- 2001 Sephia tranny problem
- Big Problems with a 2001 Sephia!!
- Possible Headgasket prob?
- 1999 Kia Sephia Transmision
- How to replace Ignition Switch on 97 Sephia?
- A/C fan won’t work when key is turned ON. 97 Sephia
- Kia Injection Idle Problems
- 98 kia sephia head bolt torque??
- Would i be better off driving this car off a cliff
- cam gears
- Shift Problem - no 2nd or OD
- body kits??
- 2000 sephia over heating at speed fans work
- kia 1999 sephia
- transmission OD flashing in dash
- fuel
- need diy help
- 2001 new owner
- 2001 kia sephia window problems!!!
- 2001 sephia 4 cylinder misfiring
- In Need Of Help
- 99 Sephia Choking and Fan Just Stopped
- looks for 1996 kia sephia ECU
- new 2000 Kia Sephia owner
- 99 Kia Sephia Alt./Wp belt
- 99 Kia Sephia cranks but won't start...?
- Please help me replace my window
- need help installing new radio.
- 97 kia sephia,heat and air
- need help with removal of drivers side axle
- i need a 94-97 Sephia 1.8 DOHC 5-speed intermediate-shaft
- in need of some insight
- Brake Issues
- No Heat for Kia
- kia 1999 codes
- bypass button for shift interlock
- 2001 Kia Sephia code P0705
- '98 Fuel Sensor Sender??
- sephia fuel pressure regulator location
- 99 sephia
- running bad
- 98 kia wont shift
- 2000 Kia Sephia humming noise
- 1997 Audio Fuse
- 98 Sephia runs rough
- where is it?
- Windshield Fluid Bottle, AC causes car to stop
- Can anyone expalin this to me please ?
- Help me please..............
- 2000 Sephia window/fuse problem
- 99 sephia clutch prob will not go in gear
- 2000 Kia Sephia water pump / timing belt
- 99 sephia won't shift
- need a camshaft
- Melted A/C Fuse
- '01 sephia a/c noise
- 99 sephia sluggish/hesitating when cold (P0171)
- 2001 Sephia Steering
- Fuel, I think? Please let me know if you know for sure.
- Fuel, it is something to do with fuel, I’m just not sure exactly what
- 2001 Kia Sephia Running Rough in Drive
- wp/alt belt
- Dash bulb replacement?
- 2000 Kia Sephia - engine miss cyl 1
- 01 Sephia No 2nd or Overdrive
- Wire Diagram for 99 Kia Sephia
- fuel filter 2001 kia sephia
- OB2 codes P1624 and P0734
- Need help with dissembling
- Squeal on start up and when A/C is on!
- ac system
- 2000 Kia Sephia Problems starting
- 96 kia feul pump & relay switch
- no spark no start 96 sephia
- 99 sephia tranny issues....
- '99 Sephia won't start
- wiring harness
- Help with '99 Sephia
- 98 Kia Sephia Only starts after a few turns
- 99 kia sephia code P1673...
- HELP!!Losing power when going uphill but get it back when on flat ground....
- Getting 24 MPG on the highway, how much should it give? What could be wrong?
- Brakes Locked?
- code p0740 torque converter clutch selenoid
- Smoke in the cab...yeah....
- radio issues on my 2000 kia
- 97 sephia
- sad 99 Sephia
- I think it may be the fuel filter what do you think?
- 98 Sephia STILL won't start. Please help!
- '96 Clutch Slave Cylinder RnR
- Does your Sephia just die or quit read this might help
- 96 kia alternator
- 98 Kia Wont Start
- 98 Kia Wont Start
- Sportage - thinking of buying?
- Kia Sephia - Fuel Pump Reset Switch
- Sephia won't shift out of park
- timing belt question
- Half shafts
- '96 Burning Alternator Belts RnR
- Vin #
- 2000 Kia blinking check engine light
- Location of PVC Valve and Fuel Filter
- 1998 Kia driver's door locking mechanism problems
- High RMP issue
- Body kits
- motor swap
- What engine do i need?
- Air Filter causing hesitation at acceleration?
- 97 BP05 performance?
- 1999 sephia auto trans problem-please help
- Is freezing in Maine...my Sephias heat stopped working?Any ideas please?!
- 1998 Kia Sephia
- check engine code of P1448
- Check Engine Code P1673 on a 2000 Sephia
- my starter
- cant remove plug wires!
- Issues
- Freeway problems in a 95 sephia
- Begging For Help
- Can Anyone Relate to These Issues?
- 98 kia sephia fuel pump
- tranny flush
- 2000 Kia Sephia engine switch
- 2000 Kia Misfire in Cylinder 1
- timing belt 2000 kia sephia
- Not Starting after turning off
- Roaring noise?
- 99 lost power?slow uphill
- KIA Sephia 2000 Air Bag Light stays on
- Kia Sephia Head Gasket Replacment
- '96 Sephia RS-What is the towing capcity??
- '96 Sephia LS Being Sold For $550 in Central Florida
- timing
- Park Range Switch?
- help Kia sephia 2001 spark plugs
- 1998 Sephia OBD Trouble Codes
- oil light
- intermittent skip at idle - 97 sephia
- Kia won't pass inspection, still needs repair, what now?
- reason for o/d off light blinking here
- 98 sephia
- o/d light flashing
- Hard shift on auto transmission 2001
- wheres the ecu???
- sputtering and hesitation
- overdrive led is flashing
- alternator swap
- '96 Sephia 1.8L
- Help!!! Trying to change cv axle
- 2000 Sephia Timing Belt
- 2000 Sephia Check Engine Light
- 98 sephia
- Headlight help
- 98 sephia
- check engine light on and O/D off light blinking
- 2000 Sephia Transmission removal
- 95 Sephia body kits
- 2000 Sephia
- 96' Sephia Timing Problem
- 1999 Sephia speed sensor
- 1999 KIA Sephia code P0732
- emergency brakes
- 2000 Sephia, no spark, no start
- Problems with my 1997 Kia Sephia randomly not starting...
- Advice Pls.
- Need 1.8 L
- camshaft position sensor
- timing marks
- 2001 Kia sephia
- car alarm/horn
- 1999 Kia Sephia Door Jam
- how do i replace an alternator belt on my 1999 kia sephia?
- Not Shifting
- 1996 Sephia fuel pump
- 2000 sephia hard to start after filling gas
- 1999 kia sephia broken drive belt
- 97 kia sephia radio not working
- 2 problems, ac/heater fan & starting
- Timing Belt
- 1998 Sephia WIll Not Shift out of Park
- Code P0170-Fuel trim malfunction- 97 kia sephia, Help?
- Wow Kias are pieces of crap
- 96' Sephia won't start. Is it a timing belt?
- 2000 Kia Sephia Ls Automatic (Engine Lite On)
- engine oil leak
- staling
- Timing Belt
- 2000 Kia Doesn't Start In Cold Weather!!!
- 99 Kia sephia how do you remove the stereo
- dieing problems.
- 96 Sephia has no fire and not getting fuel??
- Neutralizing in 3rd gear
- Spedometer
- 1998 Sephia
- '96 kia sephia clutch
- 1994 sephia starter
- Keyless entry programming instructions
- Ground wire?
- 2000 sephia dash lights are out
- kia sephia 2000 Check engine light on-how to read?
- Help!
- Help! Security alarm going off
- How do I know if I have a tranny problem?
- How many miles on 1st GEN Sephia?
- air condition smell
- 2000 Sephia - check engine light blinking
- Cheap Body Kit?
- Wiring Colors for Radio harness
- Replacing Transmisson
- reset check engine
- 2000 Sephia Seems Sluggish At Times
- pcv valve
- brakes!?????
- 98 sephia generator
- did i get the lemon Kia??
- why warranty work?
- Oil on Spark Plug #3 - 1999 Sephia
- Question
- 2001 kia sophia
- Anyone know how much or where to get a Passenger side headlight and front bumper 98
- 1999 Kia Sephia Starter
- JERKING AFTER COMPLETE STOP- New Tranny
- air bag light
- just got some stuff!!!!!
- who makes parts?
- Frozen emergency brakes
- Burnt headlights
- Increase idle
Automotive Network, Inc., Copyright ©2012
