View Full Version : Cherokee
Pages :
1 2 3 4 5 6 7 8 9 10 11 12 13 14 [ 15]
16 17 18 19 20 21
- free mods
- Map sensor i think HELP!
- Power Windows, Radio go out...................
- 91 jeep cherokee 4wd 5 sp, 6 cyl wont start
- some times wont start if i dont unplug then plug the map sensor
- Fuel Pressure Regulator, 88 Cherokee
- 94 4.0 np242 no 4hi
- 86 wont start
- Help, my power windows do not work
- new interior for 87 cherokee? where do i get it
- fuse diagram
- finiky jeep
- Fender flares for a 96 cherokee
- 89 cherokee, no cup holders!
- 92 cooling conversion
- odd electric problem - need help
- Cherokee Passanger Mirror
- WHERE IS HEATER BLOWER ENGINE (89 jc)
- chev 350
- Brake bleeding blues
- Heater Box/Heater Blower Resistor Block/Vac Schematic
- Ignition switch Question
- Cherokee Laredo 88 speedometer
- code: 1041
- 97 cherokee sport semi-stalling problem
- 4 wheel drive not working
- Gas Tank to small??
- instaling automatic start on an 87
- Engine & Transmision
- Starts on and off
- ac oil for compressor?
- R-12 or R-134a?
- 4x4 will not ingage in front axle? help!
- Oil From Blown Head Gasket? - 88 Cherokee
- Rear disc brake conversion
- fuel tank humming
- overheating, not as bad
- runs great...won't start
- Even Simple Jobs can be trouble...
- Overheating...gee who woulda guessed
- Blow-By
- Shimmy at speeds between 56 and 64 mph
- '99 cherokee sport
- valve train chatter
- Horn not working!
- Ignition Problems
- Cherokee belt squeal
- stuck thermostat?
- 91 Jeep Cherokee keeps stalling. Help me!!
- exhaust flowmaster or magna flow
- turn signal
- Headlight do not shut off, bright indicator on
- overheating, of course-revisited
- Help!!Rear end sagging and clunking
- Help, tire selection
- removing the fan in a '96 4.0 . . .HOW!!
- Idle Problem
- dash lights and window fuse keeps blowing PLEASE HELP!!!!!!
- Steering gear box replacement
- restoer engine & lub?
- 88 motor Problems
- Ground Location-Signal/Marker/HazLights Harness
- clutch fan
- 88 Wagoneer front end "skip" and grind
- what lift kits would you guys suggest
- U Joint?
- key troubles
- 1987 Cherokee Fuel Rail
- 1999 sport heated side mirrors...
- Overheating, of course
- wipers
- GEN light - 96
- 89' Jeep Cherokee temp gage
- Does NE1 know where I can find a pic of how the window cable attaches...
- XJ seats
- Cherokee 91 rain water leaks.
- problems starting
- won't start
- remove ignition tumbler
- 4wd
- Shaking
- i have no compretion
- Yellow spark=no start
- Serpentine Replacement
- 2001 Jeep Cherokee Sport radio problem?
- [Req] Dash Pics
- FYI--rear window wiper motor an easy replacement
- any one know where i can find an engine?
- service manual for 93 cherokee
- '01 sport window regulator oem part number
- not geting spark
- electrical problem
- Oil pressure gauge stock
- Very Bumpy Ride
- 93 Jeep Grand Cherokee 4.0 Crank Position Sensor?
- wont start when hot
- More horses for my 92' 4.0
- 1987 Jeep Cherokee Electrical Problem
- 88 Cherokee Headliner
- Rubber Recommendations Anyone?
- Cherokee damaged by thief.
- Seat belt light does not go out
- 1992 cherokee ignition/starter problem?
- My XJ shakes at 55-60... CANT FIX IT!!!!
- 87 Cherokee Lift ?
- popping noise
- Oil leaks--where to start?
- 94 cherokee dashboard problem
- Swapping Differentials
- high idle
- 1990 Odometer/Speedometer not working!
- 89 cherokee delayed spark
- Thinking about adding roof rack...Ideas?
- 4.10 gears
- 2000 Cherokee Parts
- 1989 cherokee crank sensor wiring
- Average gas mileage
- 89 jeep cherokee
- 2000 Jeep Cherokee Front Drive Shaf Question
- Overseas Military, Help W-89 Cherokee
- carb wont come off
- to much gas in the carb
- Jeep GC Liftgate Wont open
- Brake Light Problem
- Carb?
- 1988 Cherokee Wagoneer LTD Gremlins
- 1989 cherokee abs conversion
- Both Directional Indicators come on w/Parking Light Switch
- 92 Jeep redo Comfortride Shifting problem
- shifting problelms
- 4.0 problem when Accelerating
- help Help HELP
- what comes with my jeep
- throttle....
- [MOVIE] |0lllllll0|
- Power steering
- One simple question
- no start 93 jeep grand cherokee
- Heater blowing cold. HELP!!!
- No cruise control
- 92 cherokee clutch problem, need help please
- Is their a docter in the house?
- Need help on this one
- 87 4X4 Kicks out of reverse!
- whinning sound while running and cracking
- 2000 Cherokee 6 cyl
- Cherokee name differences?
- electrical
- Reverse
- 02 Cherokee not blowing hot air
- rear window glass and gasket for sale
- Differential humming
- I just bought a 94 Cherokee, please help
- lockers for 94 Cherokee
- Back gate vibrating, how do I adjust?
- Blow-By problems
- Rough Idle
- 99 Cherokee Power Windows.....
- Remote Locks/Keyless Entry
- Lights
- 2000 Cherokee Valves
- 6" to 8"
- not shifting to first. overdrive problems fixed
- Rocker Panel Rust
- 89 cherokee, everything runs without key
- bypass the nss
- newer seats older XJ
- 90 Cherokee 4.0 rough when warmed up
- 1985 Jeep Cherokee; 2.8L V6; NP228 T=Case.
- new tires for 1994 Jeep Cherokee 4.0l 5sp
- Oil Leak from oil filter adapter
- Got Milk?
- good bones, no mucle(overheating)
- Radiator-What´s the catch?
- 90 jeep cherokee limited4x4 with auto trans
- Stearing column
- Rear main seal
- better performance
- Vaccum diagrams for the transfer case on a 88 XJ?
- 94 XJ cold start screeching noise
- 90' slow start, any advise would be great
- I'm thinking about a lift...but how high?
- 1990 Jeep Cherokee - Turns over, but won't start - Please help
- `89 cherokee code scanner
- 95 Cherokee 2.5L missing at speed w/ O2 indication from OBD
- 88 rear axle swap
- 01 cherokee 4.0 tranny slippage?
- 93 cherokee running rough
- Cherokee Rims
- 98 cheorkee automatic tran. fluid
- Piss Poor gas mileage
- Transmission Indicator Light not working
- 94 cherokee: need help deciding what i should do about transfer case
- 2000 Cherokee scraping from rear wheels
- crackling noise from steering colum on 95
- Adding rear shoulder belts to older XJs
- 87 4.0 Would Like It To Start Faster!
- Gibson exhaust on '96 Cherokee
- 1990 slow start
- 91 cherokee abs
- Blower only works on high ??
- replacement airbags for 1998 Cherokee
- 88 Overheating/head gasket
- Brakes act funny on rainy days?
- Head work?
- 96 jeep keyless remote
- Spark Plug Gaping
- Weak or no spark on 89' with 4.0
- 92 4.0 Very Rough Idle
- Aftermarket temp
- How to add back seat headrests? (1996)
- 1996 Jeep Cherokee Sport
- sound on engine
- bad fuel consumption the danm thing drains the fuel tank too fast
- Noise from Oil Pan
- 2001 jeep cherokee
- Blower is not working???
- braking problems
- 88 Cherokee heater fan does not blow.
- Loud squeal when ac is turned on
- 97 Door panel Removal
- 90 Cherokee won't idle...
- 97 Cherokee radio light replacement
- 1985 Hard Start Cherokee HELP!!
- bumper
- towing
- 89 4.0L Missing/Backfire when above 900 rpm
- stalling
- illustration for speedometer
- HELP!!!***1989 4.0 Jeep Cherokee idles fine, runs rough with any gas***
- Heater/AC blows thru defroster vents, not floor
- Heater core replacement
- 02 sensor
- 91 cherokee oh god please help
- push bar/ grille guard!!
- 97 Jeep speaker wiring
- Crank - No Start
- Overheating 90 cherokee
- hazard/ brake lights not working
- Passenger side window only work from drivers side.
- Airbag light always on. 98 cherokee sport
- Thinking of buying 97 Cherokee Sport 4x4
- 1998 Jeep Cherokee overhead console
- 96 Cherokee Transmision dipstick tube removal
- Heater control
- shifter ?
- Clutch bleed
- Doem Light Short - t-shoot guidelines
