abs brakes to manualglassman556 01-23-2005, 09:50 PM hello all I know some of you changed your brakes over from abs to manual.can you tell me again what all is involved?I have a 1990 lerado the abs pump and motor run all the time off and on.abs light comes on every time I hit the brake pedal.what year should I get the master cyclinder and booster off of?guy at junk yard said $75 for everything I need.new pump and motor is $350.I am going with the good old fashion brakes.will some one let me know in detail from start to finish on the chang over.thank you in advance wayne.be careful and have fun wiyh your jeeps!!!! 89ltd 01-23-2005, 10:06 PM check out this link, I did the conversion myself on my 89, any more questions , let me know. http://www.automotiveforums.com/vbulletin/showthread.php?t=322569&highlight=abs+conversion glassman556 01-23-2005, 10:24 PM check out this link, I did the conversion myself on my 89, any more questions , let me know. http://www.automotiveforums.com/vbulletin/showthread.php?t=322569&highlight=abs+conversion hey its sounds easy enough.what do you have to do to the back brakes?thanks for the reply talk to you later. 89ltd 01-24-2005, 08:21 AM the rear brakes are the same on both systems. I confirmed this by asking the parts guy and he said all components on both systems have the same part numbers, ex. wheel cyl. etc. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
