View Full Version : Contour
- 97 contour transmission removal
- Erratic idle/engine
- For Sale: 1995 Contour/Mystique shop manuals
- 98 Ford Contour SE 2.0 Zetec Won't Start
- Needs help
- 97 contour trans slip code...
- Buying a Contour SVT
- 95 zetec acceleration problem
- 2000 Contour Randomly Stalling
- 1998 Ford Contour SE Pulling to the left HELP please!
- V6 timing chain question
- Where is the fog lamp relay?
- 98 SE tranny troubles
- 1998 Contour se 2.5 motor swap into 98 svt contour
- 2000 ford contour v6 2.5l dohc fuel problem
- 97 2.0 fuel injection problem
- 1995 Ford Contour 2.5 L v-6
- 200 ford contour v6 2.5
- 1996 Contour 2.5L LX "No Radiator fans"
- Engine Swap
- Scary Brake Failure
- 98 contour svt 5sp trans problems
- Whistling noise from under the hood
- Stalling, Grinding, and Rough Idle..
- Where is the water pump?
- simple trunk lid question 1998 tour
- Where is the thermostat?
- code po302 help
- drivers window broke with clicking sounds
- 1995 Ford Contour Turn signals not working.
- Ok experts try this out for a challenge
- timing belt tensioner
- 97 Ford Contour rear end rattle
- Oh man, Timing belt probs I've never seen
- contour hesitation
- tranmission swap 2.0 auto clatter chatter plz help
- transmission in stalled car wont start ???? wtf
- Default shifting transmission out of park without battery?
- 1997 contour 2.0 Help
- '98 2.0 won't always start
- What years of 2.0L motor I can use in a 1995 contour?
- transmission question
- 99 contour ac/comp fuse
- 1996 Ford Contour 2.0L I am having a charging problem
- seats....... opinion or fact?
- transmission removal 98 contour 2.0 auto
- a/c compressor clutch
- 1997 contour 2.0, iac location?????
- 97 contour gl ingition fuse keeps blowing
- 1999 contour will start then die, HELP
- camshaft help
- question please help resolve 98 contour
- Speedometer not working
- Charging System Issues
- timing question
- Park plugs sitting in oil
- Help!! Timing belt routing
- Electrical Problem
- Radio, Dome Light and Power Mirrors won't work?
- ECM/PCM Help! 1999 V6 Contour is dead and computer not talking
- Busted Roter
- replacing the beloved timing belt!
- code p0446
- Shifting Problem. Please Help Out
- 96 contour trunk and locks
- 99 Contour-engine light on, stalling
- 97 2.0 wont start
- Replacing Power Steering Lines
- sway bar stabilizer links
- 99 contour 2.0 wont camshaft position sensor?
- 1999 contour se
- revving high between gears
- Help: 1995 contour LX 2.5
- 98 contour transmission issues
- No power steering assistance!
- timing belt troubles
- 96 contour alternator...
- 99 Contour 2.5L - DTC P0420
- Bad Starter??
- Free parts for Contour
- Need Help...98 ford contour..2.o 4cyl Vtec
- how to locate spark plugs?(Ford Contour 2000,V6)
- 1997 Contour serpentine belt tensioner
- 98 2.0L Erratic Idle Problem
- 98 Ford Contour overheating
- bad idle in gear, intermittent
- Camshaft Seal
- valve cover gasket?
- 99 2.0 Ford Contour
- 1999 Ford Contour Weird Blower Motor Issue
- 1999 ford contour no start
- 2.0L SES light, running lean
- Electrical issues, NOT fuses!
- Exhaust Pipe
- 2000 Contour/charging system prob.Need to solveASAP
- wire harness
- 2.0L timing belt issue
- No A/C No Heat No Blower 98 contour
- 95 bucking and kicking
- Trunk key separate?
- 1999 contour overhating thermostat has been changed
- AC not blowing cold
- no power through stock radio power wire
- 96 Contour GL, Blend door stuck
- 1999 contour idle problem
- 1999 Contour Turn signals
- 1995 Ford contour has no crank.
- How do you change the trunk support lifts on 98 Contour
- PCV valve on 1995 ford contour
- 98 Contour running on battery
- Help me figure out this A/C issue (video inside)
- 1995 ford contour Jerks when coasting in gear
- Cd4e
- Heater and AC fan problem, 2000 Contour
- Stalling Problems As Well
- Lets play "What am I?" // Part ID please
- Emergency brake light
- Towing with a 4 cyl
- Broken pully
- 98 contour surges
- making it LOUD
- A/C blend door stuck in defrost
- 98 contour 2.0 rear brake shoes retracting star
- Car cutting off randomly
- 1999 ford contour charging problems
- 98 contour auto throwing code 1383 again! @@ !
- 95 2.0 no power
- 98 Contour Codes P1131 and P0401
- 98 contour transmission problem
- 1998 contour
- 95 ford Contour rear strut
- Crankshaft Sensor 1998 Ford Contour 2.0L Auto
- Time to change my O2 sensors.
- P0420 and P0302
- O/D light,spdometer, tranny
- Airbag Light Flashing
- ABS Sensor cable location
- 99' Contour SE - Smells like exhaust inside my car!
- 1998 Contour SVT Problem: Cats and CEL: Please Help!
- Code/fix help please
- Muffler Replacement
- Service Engine Light
- Clock question.
- 99 Contour 2.0 oil leak + jerkiness + idle issues
- Noise from timing belt
- 1998 Contour Stalls when warm
- battery light
- Grounding question.
- Weird power door lock problem.
- Why won't my car shift? I swapped the tranny already!
- P0741 O/D light flashing
- Need a little water pump advice
- coolant fan running to loud
- how can i find out what options were installed
- Looking for dollar store lighters
- struts
- hho generator
- 1996 Ford Contour (Will only work in Reverse)
- 95 contour NO SPARK
- Running Cold
- 980 Contour 2.5l not getting fuel
- crappy brakes?
- 1998 2.0 Timming belt
- 96 Contour,automatic trans troubles.
- HELP!! Bad Alternator
- 96 Contour 2.0 automatic - stops while turning or when breaking at a stop sign
- 1998 Ford Contour Front Wheel Bearing Torque Specs?
- Oil Dipstick Broke off in Tube
- 1998 Ford Contour SVT starting on its own!!!!!!!!!!
- Wheel speed sensor trigger ring
- Looking for a tranny
- 95 Ford Contour Wiring Harness
- Swapped Tranny, No Fuel Pressure
- brakes lock up in reverse
- Car will not start... need help !!!!!
- 97 contour rattles on ignition
- Urgent, CV Boots
- Help... check engine ... no not starting!!!
- Help, check engine light on with driving problem
- 1995 Ford Contour Timing Issue..Help :(
- Downshift out of O/D
- got one around
- 96 Contour Bad Fuel Injectors -P0171
- Don't Know What To Do
- Power window problem
- 96 ford contour problems
- Rear door stuck 98 Contour
- 97 Ford contour fan
- 99 contour strut into steering knucle
- 97 contour knocking
- 99 Contour SE Cant remove A/C Line?
- 95 Contour V6 intermittent flashing check engine, temp goes on immediately on startu
- Urgent-95 won't turn over-PLEASE HELP!
- 1995 Contour tranny work in 1998 contour?
- 96 contour 2.0 over heating
- 95 Contour V6. Intermittant AC cooling ??
- Crash sensors
- timing
- Stereo and dash lights
- 98 2.0L DOHC no pwer in first gear idles rough.
- Water Pump Replacment
- IAC location on 97
- o2 sensor
- In need of Body Parts
- 97 Contour Vibrates and Shakes
- flashing airbag ligth
- PVC location
- 98 contour, will crank but won't fire
- MORE Pow Wah
- Front struts?
- 95 Contour not starting right
- A problem with the EEC module fuse in 95 tour
- Replace Wiper Motor
- I'm doing the atx to mtx. HELP!
- 2.5 SVT Won't Idle IAC?
- 2.0 z-tech timing belt , no timing marks ocrank pulley
- no heat
- 1998 Svt Front Bumper
- 1998 Ford Contour RPM High
- valve cover torque
- Oil pool at spark plugs
- Front door latch
- contour stalls out when put i n aforward gear
- Then there was the contour...
- 0171,0174 codes
- Where is the PCV on the '99 Contour?
- need help!
- starting car after accident
- up grades
- Windshield Wiper motor problem
- 98 contour 2.5l dohc misfire/rough idle
- 1998 Idiot lights
- Please Help... 1999 Contour SE Stiff brake pedal but idle is fine
- 2.0 to a v6 motor swap
- Bad Acceleration, then brake pedal Hard
- 98 motor swap to 96 2.0
- 1996 ford contour
- difficulty of installing L3 white face reverse glow gauges?
- 99 contour ignition removal
- 1995 Ford Contour shimmies
- 98 Ford Contour Speedometer intermittent
- 98 ford contour overheating
- 1995 contour stalling
- Lower engine air leak
- '99 Ford Contour- Died while turning and will not start
- 98 Contour Vacuum problem??
- Motor Swap Question
- 1998 Ford Contour Roughly Idling
- 1998 Ford Contour Loud Grinding Noise
Automotive Network, Inc., Copyright ©2012
