View Full Version : Performance
Pages : [1] 2
  1. 1989 Supra 7M-GTE
  2. Supercharged Supra 2JZA80 GZE
  3. Hi Everyone! Boost controller question
  4. 92 turbo messing up?
  5. 1JZGTE -1988 Supra Turbo Swap
  6. Putting T61 Turbo on 90 Supra???
  7. 89 supra... no spark
  8. Questions
  9. 1985 Supra 1gu-ze swap
  10. 1985 Supra 2JZ-GTE Swap
  11. engine and transmission swap
  12. hey guys a little help please...
  13. Ryan Woons WOTM supra 0-60?
  14. swap
  15. Can my 87 supra have a big engine?
  16. To spray or not to spray?
  17. Single turbo supra VS Twin Turbo supra
  18. need info on blow off valves
  19. how would win or come close between mkiii and wrx
  20. what's the hype about mufflers on your mkiii
  21. 91 na engine misfire after warm?
  22. rebuild time
  23. tranny ?
  24. help please
  25. crank pulley
  26. clutch conversion from reverse to normal
  27. fog lights
  28. trying to get a 1jz
  29. 7mge 5 speed transmission
  30. electric fan kit
  31. mk3 supra cat back
  32. electric supercharger
  33. 1/4 mile time
  34. quick question about turbo
  35. 1987 supra turbo help
  36. 2jzgte into a mk3 supra help
  37. engine swap question.
  38. turbo surging
  39. 1991 7M-GE cat back exuast?
  40. manual ecu
  41. wideband question
  42. 82 supra 2jzgte swap
  43. nonturbo - turbo
  44. $cheap$ power
  45. downpipe
  46. electri fans
  47. Can a 1jzgte fit in a 91 Supra?
  48. fuel controller
  49. Im New To Supras, I Have A Boost ?
  50. intercooler on my 1990 Turbo
  51. new GTE won't boost
  52. Upgrade time
  53. 7M-GE to GTE wiring...help!
  54. 91 supra auto to 5 speed
  55. 91 supra auto to 5 speed
  56. Best place to buy 1G-GTE?
  57. Tuning help
  58. Tri-Turbo Supra
  59. 7mge
  60. 2jz-gte vs 2jz-ge. Please i need some help!
  61. Wiring problems
  62. 1990 supra turbo upgrade
  63. 1995 N/T supra, turbo upgrade....
  64. na vs. turbo
  65. what all do i need to do to swap an (A43DE) automatic to a manual
  66. Turbo Question
  67. New to the site
  68. 2JZ in a 4Runner: Adjusting TPS?
  69. 2JZ-GTE in 1998 Hilux
  70. tein flex install
  71. 7mgte engine
  72. 85 with a miss
  73. Is a supra worth it?
  74. tail lights???
  75. six speed transmission in a five speed car?
  76. wiring
  77. Basic mod suggestions wanted
  78. Spark Plug
  79. twin and single turbo
  80. 1jz
  81. A toy for the auto trans folks
  82. bov
  83. 2JZ-GTE motor into a lexus sc300
  84. Help me speed it up
  85. Boost control, stock internals
  86. Virtual Works Intake Manifold
  87. 1g-gte to 1 7m-gt
  88. Turbos??
  89. Mount?
  90. Cat-back??
  91. Baddest Blow Out Valve
  92. brake upgrade ....help
  93. Need some power supras not getting respect around here
  94. Need e-manage Base map for JDM Supra
  95. couple quick questions
  96. Best Combo
  97. Is it possible?
  98. more power from a 1g-gteu
  99. Cams
  100. [wanted] CT26 used turbo with tangient exhaust housing
  101. Motor questions..
  102. N/A Power
  103. 2JZ Swap!!
  104. CT26 upgrade question
  105. All-Wheel Drive Supra
  106. Twin Turboing
  107. MK2 Stock Specs
  108. Just Wondering???
  109. Just bought a 1988 MK3
  110. Need some help
  111. can intall 2jz-gte in my toyota supra 1994 n/a
  112. 1990 Supra Upgrades
  113. 6cyl
  114. racing fuel
  115. Installation of BOV
  116. MKIV NA/Turbo differneces
  117. 86.5na what should i do
  118. piggy back system
  119. wastegate
  120. bov
  121. factory internals
  122. good sparkplug?
  123. 87 performance parts
  124. 1ggteu intercooler upgrade
  125. wanna race from a roll???
  126. tuning potential of an oldschool supra
  127. 2JZ lifespan????
  128. turbo?
  129. 1G-GTEU durability
  130. rotor turning direction?
  131. single or dual solenoid
  132. profecB boost controller help
  133. 1990 supra turbo specs
  134. BOV vacume line
  135. Removing Boost Controller
  136. Boosting
  137. Underdrive Crank pulley
  138. Na-t
  139. 2 different Turbos on a TT
  140. HKS F-con ECU...
  141. 14.8 1/4 in my n/a!?
  142. My GA70 (1G-GTEU) TT...
  143. knock sensor
  144. What should i do with my 7MGTE?
  145. 7M-GTE to 1JZ-GTTE
  146. my mild n/a
  147. Engine harness?s
  148. Update on the car
  149. FOR SALE: HRE 545 19 inch wheels and tires - (santa clara)
  150. turbo exhaust manifold
  151. all this into a supra
  152. 7mge to 7mgte swap
  153. MK3 with 2jz motor & trans
  154. boost guage
  155. automatic to manual
  156. stock 7mgte
  157. Headlight Conversions? 89 supra
  158. 7mge to a 7mgte
  159. Which is better?
  160. 87-89, Getting HP
  161. Turbo Question mk3
  162. MKIV NonTurbo Tranny on a 2JZGTE motor
  163. 2jz engine swap
  164. intercooler CFM flow rate
  165. Exhaust Types
  166. intence racing mod chip, wheres the IAT?
  167. emmisions removal questions
  168. ARP Headbolt replacement questions and performance advice needed...
  169. New...few questions
  170. 7mge turbo faster than a 7mgte turbo?
  171. water injection systems
  172. megasquirt work on 7mgte
  173. Fuel Cut Defencer schematics
  174. cams??
  175. 7mgte 1jz 2jz manafold
  176. need advice for my MKIII 89 n/a supra
  177. tranny?
  178. 7MGTE bottome end...
  179. Engine Swaps
  180. intake problems
  181. Auto or stick?
  182. 2jzge turbo project
  183. bad on gas help
  184. Electric Super chargers for MKIII?
  185. is my 7m worth it?
  186. clutch CHATTERING
  187. GE to GTE swap
  188. supra hp at 15 psi
  189. motor swap
  190. 5mge fuel injectors
  191. 7mgte vs. 1jzgte
  192. 1989 turbo head gasket replacement.
  193. internal differences-TT and N/A
  194. 88' N/A Being made into a Turbo
  195. required sensors ecu help
  196. power sterring
  197. Shorter Struts Needed?
  198. Blow off valve change MKlll
  199. engine swap
  200. 7m-gte turbos.. which ones are good to run?
  201. Supra N/A Performance?
  202. 1jz swap
  203. Turbo 400 Tranny
  204. 84 Supra V8 engine swap
  205. valve springs
  206. sp74hq turbo???
  207. pulleys
  208. Exhaust Question
  209. main harnes help
  210. 7mgte Info
  211. Can 83 supra's take newer diffs?
  212. MAP or MAF
  213. mkIII internal mods
  214. many questions for 7m-gte
  215. 2jz-gte turbo upgrade?
  216. 7mge intakes
  217. Aww the good ole days
  218. parts for 1jzgte?
  219. HP#'s
  220. converting an NA
  221. turbine a/r
  222. twin turbo on an mkiii
  223. manual turbo boost controller
  224. When to replace turbos, mechanical..
  225. hey all
  226. 7M-GE performance
  227. MKIII's best bods?
  228. ls400 upgrade
  229. oil return line Supra NA
  230. 1984 5mge-7mgte swap questions
  231. Engine Swap
  232. jdm 7mgte swap
  233. 93-98 supra curb weight reduction questions
  234. stock times
  235. SuperCharged
  236. Stiffen up my topless ride?
  237. Turbo or Supercharge 2JZ NA which is best option
  238. GT500 Supra Suspension
  239. brick wall @ 6psi
  240. 2jz question
  241. turboing a 2jz n/a
  242. 87 turbo exhaust mods
  243. 7mge vs 7mgte question
  244. Max boost for stock mk3 supra
  245. Help with 1J2GTTE swap??
  246. Reputable JDM Engines
  247. Drivetrain ?
  248. 91 Toyota Supra
  249. b.o.v
  250. 2 jz
