View Full Version : Older Pickups
- 1993 Nissan Pickup will not start
- 1987 4x4 hardbody VG30I Oil Pressure Switch Location
- 95 nissan pickup 6cyl
- timing marks?
- Changing Rim Sizes? 14" or 15" ? oem?
- trans problem
- 84 Pickup No Sound No Start
- Crank angle sensor
- no oil pressure in 95 nissan pickup?? Help!
- 97 Nissan Pickup wierd problem....
- 89 pickup acts like out of gas
- Tranny?
- will chevy 6 lug wheels fit my pickup
- 95 nissan hardbody truck fuel pump not coming on.
- 96 nissan pickup brake lights are on high
- vibration
- 95 Hardbody radio error
- Water pump replacement
- Gonna swap 5-sp. tranny... searched archives...
- 79 dat. trans swap
- Crazy starting problem ???
- gas mileage
- Seat Replacement Recommendations
- Timing Belt or Timing Chain?
- 91 hard body sr20det swap
- 95' hardbody won't move
- Only starts on second key turn???
- nissan pickup motor
- Need help/tips for bleeding clutch
- Flexplate/Flywheel for 1988 pickup
- 87 D21 Z24 4cyl Ignition Problem
- 1986 Nissan PU, new head gasket, no power
- 1995 nissan P/U fuel temp sensor?
- i need a massair flow harness 89 nissian V6 4x4
- need massairflow harness for 89 v6
- Looking for a tailgate
- 1993 Door Handle Removal
- nissan carburetor conversion
- suggestions on suspension kits
- 86 HB pickup won't start- no fire
- Ring gear [for reverse] missing tooth? Replace Transmission?
- nissan truck body parts
- 1995 2.4L engine--Very High Idle
- 95 hardbody brakes
- 95 hardbody lighting not working
- 95 hardbody 2.4l running rough at high revs
- 84 4X4 2.0L dies under load
- rough ideling on 82 datsun/nissan 720
- 95 engine in a ??? body?
- Well guys, the rust comes.
- 1986 hardbody 4x4 no fire
- 1983 720 z24 temp sender
- Z24 Oil Baffle
- 86 nissan tire toes in!
- pick up wanted- any condition
- 95 Nismo 4x4 waterpump
- 1992 Nissan Hardbody Tranny rebuild?
- 1995 Nissan hardbody XE Truck
- 1995 Nissan 4x4 Axle Assembly Replacement
- engine swap
- my 85 720 no fuel replaced relay
- 1993 Nissan Truck blows the meter fuse
- 1993 Pickup driveshaft question
- heres another 1993 p/u wont start
- How many amps is too much?
- Filipino Pickup Owners
- Can I Bench Test My Starter?
- Belt squeal or AC Compressor bearing..?
- Carburetor Noise
- 1987 toyota pickup
- 1886 carburator motor
- Shifting out of park auto
- check engine light
- 94 4x4 pickup reverse just quit
- OBD-II with no cat conv?
- bad gas milage
- Sliding Timing Chain and Sprocket Back on Cam
- Need help with electrical (lights)
- FICHE found... funny sound...
- Z24 Motor Not Mounting To Motor Mounts Same Type Engine As Previous
- what is the Boost sensor on the Rear of a 97 HB
- bad vibration
- Mystery parts...? go Fiche?
- 89 4X4 No Power But Runs
- Idle changes
- 93 HB timing chain replacement
- Air suspension
- what does fuel temp sensor do?
- '93 Hardbody: Temperature Guage reading?
- '90 V6 power loss when damp
- '84 720 tk series, 2.4 L T-Chain Probs
- 96 hardbody head problem
- 86.5 Hardbody Pickup needs motor
- Changing starter on 94 pick up 4 cyl.
- Catalytic Converter for 93 Nissan Short Bed Pickup 4 cyl.
- 93 engine swap with a 96 engine
- 1993 Pickup Stumbling
- New exhaust on a '93 p/u
- 93' SE P/U is it worth it
- Tips for rebuilding '93 four cylinder?
- another 1994 Nissan Pickup won't start
- 86 720 Z24 idles bad.
- 1985 nissan 720 pickup
- Spare tire help.
- looking for 2 wheel drive lift kit
- escalade wheels on a 96 pickup help
- 1986 running bad
- Charging Woes
- 91 Nissan TD27 (diesel)
- losing clutch fluid
- 98 frontier P1148 code help
- '95 King Cab needs frame work
- fuel pump
- 1994 Pickup underhood to 87 body
- oil weight
- 3.0 v6 Ignition and ECU available
- Lookin for body
- 84 parts swap!
- 1987 Pickup (is it fixable)
- Swapping to a Holley 2300, What vacuum do I really need?
- 1993 Nissan Pick-up wont start!!
- 1995 Nissan Pick-Up won't start
- WTB Hardbody Z24i Transmission
- Fuel Temp & IAT sensor locations
- 95 Pickup intermitten clutch slipping
- 83 Nissan truck Z24 needs new carb
- Reading codes how to
- 4cyl suddenly died...stolen cat conv!
- Need some direction
- v6 in hardbody the same as v6 in 300zx??
- Did I total my truck?
- 1984 Nissan failed Co2 Emissions (barely)
- 96 Nissan Pickup XE fuel problem?
- 94 nissan pickup loses all power and shuts down...
- Replacing U-joints in 93 4x4 p/u?
- 1995 kA24E engine (nissan pick up)
- '86 Tranny problems
- 1988 Z24 has uneven idle
- Need help with lighting for instrument cluster
- air conditioning problem
- wont start no spark.
- my 86 720 pickup truck
- 88 pickup 2wd Stereo ?
- neeeddd heeelppp!!!!!
- MAF sensor 1995 xe pick up KA24E Nissan
- radio
- 92 4cyc stumbles
- 1995 kA24E check engine light
- 87 nissan windshield
- 1987 nissan pickup parts
- v6 swap
- turn signals help!!!
- 1988 4x4 making noise HELP!
- turn signal
- Carrier bearing/U joints - do it myself???
- MAF/throttle body swap?
- 89 Problem
- 93 hardbody fuel leak
- 95 nissan 3.0 v6 newbie
- Parts for sale
- bags?
- 4th alternator 97 pup
- no power to tbi @6 pin connector plug.
- 86 hardbody stalling
- Help!
- 87 2.4 early over rev cant figure out
- 94 Nissan Hardbody Fuel Filter Location
- 91 p\u needs rear shaft any other parts fit?
- 85 Nissan Truck (no fuel)
- Nissan 95 loosing power
- No Break Lights ,Signal lights,
- GAS mileage went down HELP HELP
- 95 Nissan Hard Body Truck
- problem with cab heat & fluctuating temp gauge
- noob needs help!!!!!
- s13 trans in a hardbody???
- Phantom, Info?
- Transmission needed
- What other head fits on 2.4l a nissan pickup
- 97 4x4 pickup ABS/Brake lamps on ???
- 89 Nissan pickup fuel pump
- nissan wannabe
- 89 rust problem????
- Have Fuel Have Fire But No Start 95 truck
- Help
- 96 pickup
- changing carpet
- Blinker/Signal problem. any ideas?
- 1991 Nissan 2.4L 2wd Auto Transmission on ebay for cheap,Listing ends in a few hours!
- adjustable thermostat, 1987 Nissan p.u. hardbody/Z24 engine
- 95 XE pickup horn problem
- 94 Nissan P/U Manual Trans Fluid
- 94 Truck Blower Motor Relay Location
- Nissan Truck Instrument Panel
- 97 xe Check Engine light
- 1995 4x4 pickup
- ECU problems
- swapage
- 94 D21 Body kit
- 90 nissan pickup wont start
- need a camper shell for 86 Nissan 4x4
- 96 center support bearing
- 95 auto no reverse?
- Engine miss/shaking when engine is started
- Radeator's (spelling idc right now)
- 1988 door removal
- Need some help PLEASE!
- wild tachometer
- 1984 Pickup/manual Steering To Power Steering Conversion!!!!!
- Engine Mount's
- Need help with head gaskett...
- 1993 power steering pressure hose
- 1991 Nissan crank but will not start sometimes
- Manual transmission question?
- Big tires on hardbody?
- Nissan Pickup Distributor FOR SALE
- 86 power train schematic?
- sr20ve
- truck worth the work?
- 1991 Maxima
- 1991 Nissan pickup alternator
- 92 nissan p/u truck parts
- '96 Nissan XE-V6 Timing Mark
- timing problem
- 240sx in a 1985 720 pickup
- 97 4x4 exhaust bolts broke off,help please
- '95 4X4 gas saver?
- Engine Model Number
- 1993 2.4 High Idle
- audio wiring diagram
- 1992 Nissan 4x4 truck problem
- no dim lights on my 88 pick-up
- Used motor?
- navigator rims
- 93 pickup with antifreeze in the oil
- engine swap info please help?
- barely "turns over" then starts - what is it?
- 87 4x4 questions
- for sale cheap!!
- 94 2x Manual Transmission Grinding in 2nd & 3rd
- Parking Brake
- First Time Nissan Owner
- fuel gage problem
- HELP!!! Motor swap??
- 87 nissan pick up
- 96 Nissan pickup has problem with water
- 94 V6 Pickup, Need New Engine, Best Place to Buy?
- 94 Pickup, Rear End Clunk
| Quality Real Meat Nutrition for Dogs: Best Air Dried Dog Food | Real Beef Dog Food | Best Beef Dog Food
