View Full Version : Impala / Impala SS
Pages :
[ 1]
2 3 4 5 6 7 8 9 10 11 12
- cooling fans not turning on.....
- Headrest removal 08 Impala
- Terrible Front End Noise
- 06 with key stuck in ignition
- random misfire
- p0741 and p0742!!!
- 2001 Dash lights not working
- Help! Please
- 07 Impala remote start not working
- Battery issue / Battery light flashing
- 06 - 3.5L Head Gasket - 77k
- 2006-2009 Power Drop
- 05 impala hard start when cold only
- Cooling System Problem - 04 Impala
- Blower Motor Probs
- trans swap help
- no heat on driver side, any ideas?
- 04 Impala not starting
- Pull Engine and Trans together???
- need 2 small hoses for coolant bypass to intake, any ideas
- LIM leak? swaped 4 felpro set but mist coming from back of engine?
- 06 Door panel
- 1995 Impala SS - Total Suspension Upgrade - Your Thoughts?
- 2005 impala has no heat after LIM gasket/themostat
- Help! O6 impala
- 2002 Impala LS Radio Light Out
- changing out the steering wheel
- 2005 impala with hole in fuel tank
- clunk?
- Leaks after LIM gasket project
- high Idle
- 2003 Impala - Driver's Side Water Leak
- ticking engine noise
- Word of caution on Splash guard
- 04 Impala 3.4 traction control kicks in when turning
- ok guys and gals i need some help.......
- More ?'s about 2003 trans slipping
- 2001 Impala - misfires under load / uphill chugging - finally FIXED!
- Radio/Battery?
- 2007 Impala A/C and Rear Defrost - Is this working right?
- Does bad Pcs afect reverse gear too.
- intermittant turn signals
- Before i replace my intermediate with a new one I have
- 3.8 water pump removal
- Drive Axle Replacement - Questions
- power door lock ?
- 06 Impala loses power during shift
- Pressure Control Solenoid or what???
- need help removing a window 2002 impala
- 2002 impala LS stalls
- Minimum Rotor Thickness for 2007 Impala?
- 2006 3.9L Head Gasket
- What Happened???
- 2006 Impala Rear Defogger
- Loud clicking sound
- Front o2 Sensor Location 2000 Impala 3.8
- 1995 Impala SS - Fuel Fumes
- AC/Blower resistor on 02 LS
- 2003 9c1 heated, power seat install
- Where is tensioner pully?
- Pinout for 2003 heated seat connector
- Loud Turning Signals
- GM has cut the impala ss from the lineup
- Tech2
- 2000 impala ac compressor leak
- Any issues with 2007 LTZ's?
- trying to get every think in good stats
- Serpentine Belt.
- 03 impala catalytic converter
- i hope someone can help me
- 95 impala ss wiring harness
- 01 Impala 3.4L Cooling and Trans. issues..Need Help!
- 2008 or 2009 impala
- P0336 Code
- 2006 Impala Windows Not Working
- 3.4 or 3.8L engine
- check engine light
- RPM range for tranny to shift
- New ignition cylinder, security light still on, now what??
- Change radiator hoses?
- 01 Impala air bag removal.
- 2000 Impala In and Out of OD constantly
- Location of the Camshaft Position Sensor...?
- Tighten gas cap????
- 1996 Impala SS belt squealing
- Unlock RDS radio -?
- 4T65E Trans question
- Loose spark plugs
- 06 Impala Camber Issue
- clock spring replacement
- '02 Impala 3.4: Broken Wire Under Driver's Seat
- AC/Heat fan not working
- Problems
- Front Tires will not rotate clockwise!
- Replacing blower motor resistor did not help
- 96 Impala SS - Odometer went blank
- Only starts on occasion?
- Tire noise? 08 SS
- Another Weird AC problem
- Denso/NGK Iridum Pugs - Your opinion and/or experience?
- 06 SS issue
- Air Conditioning will not come on
- Impala Tire Rod/ Coolant Leak
- 1995 Impala SS - Oil Issues
- 2000 impala dies going down the road
- 2005 Impala climate control malfunction
- New BCM, Dead Battery
- BCM memory
- serpentine belt
- 2005 Impala Horn Replacement
- hi
- A/C & Temp Gauge glitch for a few minutes...
- Windshield wiper intermittent function not working
- Pass key fault is on
- crunching in front when i put brake on
- CAR STARTS BUT DIES IN ABOUT 5sec.
- chevy impala 03 transmission slipping
- "service brake assist"
- Replacing Intake Plenum and catalytic converter
- Ignition switch or Key?
- Transmission Issue
- too much tranny fluid
- Vehicle not starting
- Wheel Bearing Problems 2001 LS
- 2003 3.4 chevy impala
- front axle noise?
- 2001 impala ABS light
- 1995 Impala SS A/C not working
- click and crack in my steering 05 impala,just started 3 days ago
- no start passlock
- 01 Impala will not shift into 2nd gear
- Radiator and Cooling Fan Issue
- 03 impala, overheating problem, mystery cracked hose
- Spotlight Hole Repair Help (retired cop car)
- 2001 impala ls a/c leak
- 03 Impala Blower
- what is the best timing degree
- I need A grill and headlight bezzels
- 2002 Impala LS Light Show (BCM)
- swishing & swirling noise in my 05 impala
- Swissing & swirling noise in my steering when turning left and right
- Too much plastic 06!!!!
- 03 impala power loss - UPDATE
- 03 IMPALA Transmission only can go 3mph
- Headlights on most of time
- 2000 LS Struts
- 1995 Impala SS - Transmission Shifting Hard
- Oil filter whoopsie
- Low Tire Pressure Light
- coolant leak
- code question.
- How to disconnect panic button
- Engine Whistle
- heater fan works when it wants to.
- Restoring Old Impala To Show Car
- Anyone installed Aftermarket radio in 06 up?
- Transmission
- UIM and LIM replacement...take 2
- 06 ac problem
- Synthetic oil and STP
- Problem starting
- 2003 Instrument Panel Lights
- 2002 Impala LS Power Problem
- 2008 Impala Royal Purple ATF
- 03 Impala power loss
- Turn signal intermittent problems
- Misfire problems
- Ground Wire Hookup?
- Nees help with gm starter wire's(color codes).
- running rough after intake replacement
- '02 3.4 120K: Front End Vibration Diagnosis
- tune up
- Accessory power disconnects when parked overnight
- 2007 Impala LT question
- power steering fluid leaked all out
- Help me please!!!!!!
- ok i give up!!!!!
- 02 LS intake swap problems
- upgraded ss cluster
- Warped Dashboard
- Evap System 03 Impala
- Oil pressure switch blew
- Service Traction System
- radio replacement.
- need a serpentine belt diagram for a 2001 impala
- Life expectancy question
- Please someone help
- catalytic converter Help
- 07 impala airbag installation question
- new head gasket?
- Welding Impala SS frame
- performance parts
- Tune-up frequency for 96 Impala SS
- programming new remote control for 96 Impala SS
- does it require premium gas???
- A bit of insanity struck me
- 2004 Impala 9C1 - Wheel Bearing
- Strange 2007 Impala LT Keyless problem
- billet grill
- rain guards
- Replace carbon fuel canister 2006 impala
- Check engine light on
- location of 02 impala vss
- Factory Radio Question
- Fuel Trim Lean
- Starter "Dragging"
- transmission leak what should i do....
- Fuel Guage
- Polar Start Car Starter
- 2007 Impala SS
- air bag light
- 2004 CEL on after Jiffy Lube Oil Change/Tranny Flush
- Fuel gauge part name
- royal purple synthetic oil
- 01 impala ac blower
- 07 Impala Windshield Washers
- Engine Cooling Fan fault, 2000 Impala LS
- Buying an Impala
- Cold Air Intake
- sick turn signal
- has anyone had to have hoses replaced?
- 06 SS issues
- Another List of problems... 02 Shitpala LS
- Ls bumper
- 04 impala ss bypass actuator
- ventvisors
- Transmission shift/pressure solenoids
- my bumper
- 06 SS engine light
- I bought an 2001 chevy impala Monday, and this happened
- 02 impala
- '02 impala, 3.8 slow crank, cut off ghost
- Thermostat & oil pressure switch location '01 Impala +
- '04 Impala LS 3.8L sounds doggy-low fuel mileage
- Evolution brake pads
- 2002 Impala LS Removing the center console
- Engine Miss - EGR Valve problem??
- Cause of the turning noise
- 2005 4t45e which is the return cooler line
- 2001 Chev.Impala SOUND while making turns
- terminology?
- cartuning turbo kit.
- 2001 Impala Overheating Issues
- Can I reprogram theft lock on a new stereo for 2002 impala
- What could that grinding noise be??
- 2000 Impala, Grinding Noise while turning
- 2000 Chevy Impala headlight aiming?
- 06 Noisy Cluster?
- 02 Impala SS???
- 2006 3.9l engine thoughts
