2001 impala starts fine won't take fuel
chevyman1965
02-24-2014, 06:26 PM
have a 2001 chevy impala, starts fine, won't take fuel. has fuel pressure up to fuel injectors, won't accelerate. anyone else have this problem??? if so...where do I need to look???
maxwedge
02-24-2014, 07:20 PM
And the fuel pressure at the rail is?
Blue Bowtie
02-24-2014, 07:36 PM
At the risk of imitating a broken record, any error codes/MIL?
chevyman1965
02-24-2014, 08:12 PM
fuel pressure is 40 lbs
chevyman1965
02-24-2014, 08:14 PM
didn't see any error codes...
Tech II
02-24-2014, 09:02 PM
3.4 or 3.8?
I would be checking back pressure, for a possible cat problem.......
If a 3.8, disconnect the MAF and see if it runs better....also check the vac line to the f/p reg. for fuel....
Last time fuel filter replaced?
Is this misfiring at idle?
la1
02-27-2014, 10:31 AM
if you think its a clogged cat try removing the ox sensor on the manifold, see if it accelerates. HFT has a really inexpensive back pressure tester. What does your air filter look like ? when was the last time you changed your fuel filter ?
