Our Community is 662,000 Strong. Join Us.
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Chevrolet
> Nova
View Full Version :
Nova
Pages :
1
2
3
4
cant find drum brakes for 62 nova
L6 250 new carb set-up questions
1978 Nova Overheating
Blow by on motor
fuel dumping
88 nova hard to start when warm
trans question
86 Nova occasional idle issue
I'm helping a friend with his 1977 Nova
Anyone know where I can find a '62 Chevy II pitman arm?
76 Nova Rear Tire Width
68 Nova Master Cylinder Problems
New 1975 Nova Race Car
gm heads
hood hinge adjustments
Trans swap & Driveshaft length
looking for a new project
350 heads
How to remove oil pan?
Will this posi unit work in my Nova?
How can I be sure I bought a posi diff.?
how to build a 800 horse power 383 stroker for a chevy nova?
looking for a 75-79 th350 crossmember and 2" drop spindles
Looking for 73-74 Nova parts & cowl hood
Hood weather strip
Wonderin about these roller rockers on my vortecs
71 nova disc brake conversion
vortec heads with flattops,compression problems?
1971 nova
Too much compression with vortec heads?
1970 Yenko info needed
Really need set of beehive valvesprings for vortec heads
How much miles per gallon should I be getting?
what carb for 350 vortec head swap
New Project - Help Needed
Help appreciated! 1974 nova
fixin up an 86 Nova?
Hard starts after Warmed up
would vortec heads be a good idea?
dual point excel to electronic ignition swap
Looking into buying
Fuel tank return lines
need a bigger carb
is it worth putting in serpentine system?
ideas for more horsepower?
66 nova engine swap...????
Distributor issue
1973 nova custom
oil pump for 66 nova...
1972 SS or not?
Still need help with my headliner!
Will 68-72 headliner bows and clips work for 73-74?
New guy with old problems...
74 nova headliner bows interchangable?
63 Nova with a Ford 9"
valves
1968 Chevy II / Nova Leaf springs
Oil filter
Nova frame mounts
New gaskets now no start
305 to 350 swap?
77 nova 2dr question..
1962 Chevy II exhaust manifold (4 cyl.)
76 Nova
Brake Lights 76'
wtb 66 nova ss title,tag & vin
Transmission help
Exhaust manifolds
The Dream Nova
Oil Pan Question
327 sbc interchangable parts...
66/67 nova experts
Dang shifter........
Hello everyone...
Looking for Nova interior sheetmetal parts
My Nova story
1970 350 oil pan leak please help!!
Frame woes
Gas Mileage 305
Lowering ??
1968 vs 1969-72 Headlight bezel.
converting a 77 nova
70 Nova overheating problems!!!
1977 Nova Coupe Front Window screen
74 Nova/Omega Engine Mounts
Anyone know about sheetmetal?
1963 Chevy II Wagon ???
looking for a answer about shifter
Need '87 front side marker assembly (driver's side)
1965 Chevy II nova sedan
no spark on an 87 nova
Driveshaft Length Question
Looking and need some answers
Stuck Lifters
74 Nova front end swap to a 72 front end
63 Nove rear end swap
Question regarding an "ignition key activated 12 volt source"
74 nova with 250 What Air Cleaner???
74 Nova 4 Door Interior Parts Needed PLEASE!!!
700r4 tranny wiring
Found my RPO codes!!
woot!!!Just purchased 76 2 door nova
need interior trim for 75 hatchback plz help
Fuel Tank Rust - Please help
Engine help
77 Nova Electrical Issues
Want to build 70 Yenko Duece clone....
74 Nova bumpers
70nova title weights
72 Nova best ever!
1969 nova info needed
Couple Quick Questions!
74 nova with 1967 corvette 327
Your Opinion Is NEEDED on how custom i can go
Matching the right gear ratio to the tires
66 nova wagon project
73 rear seat
73 Heater doesen't work
73 Blower Motor
WANTED: 67-73 Nova Project Car
Box Nova Q's
tires/rims
newer engine to 72 nova swap
enigne
75 nova motor mount inserts
How much is it worth?
75 350 starter
how to tell if its a 305 or 350
smog pump
need bucket seat parts for my 68
In need of drive shaft
subframe value????
How much is my 78 nova worth? in IOWA:(
nove buildup question
75 nova trunk
How much is too much (trunk rust)
1974 nova wiring problem (ground?)
1973/74 quarter panel wanted
questions about motor
1970 Restoration
Missing Heirloom
1970 Restoration
lash adjusting
Help
Wanted 70-72 2dr Front/Rear Window divider moulding
Rack and Pinion steering going in my 70 SS
power steering mounting bracket?
Help with 78 Nova idle problems
tires
Vacuum advance
:( water in my cylinder
Chevy 350 required torque for turn over???
HELP, 1974 Nova in dash tach. problem.
brake conversion??
78 NOva 6 cylinder to V8
gas tank/line info
73 nova wiper blades
turbo charged
74 Nova Disk brakes
72nova suspension questions
Easiest Way
1963SS rearend swap
Rebuildin...Need some opinions
Looking for parts
Urgent!! I Can't Brake Right Away!!
I am running 4 grand at 65mph?????
Nova rear end conversion
Looking for fenders 77' nova
74 nova circuit gauge
230 Carb
MY 1977 nova 2door
Waking from it's nap!
front end
brake conversion
Carb Qustion ????
Throttle linkage differences between 1969 and 1970
Rear end conversion
the drive gear spins to driven gear inside the tranny, correct?
relocated battery to trunk
73 nova transmisson leak
Brake conversion
IF the battery cables or hot...
77 nova fiberglass hood no cowl!
1978 Nova acceleration problems
78 nova sedan doors
78 Chevy Nova seats
what to name my car?
CAR BROKEN INTO! Please help fix it!!
Do they make small block freezers
looking for my 77 nova i had in IL, has anyone had or seen it ?
Disk brakes on my '71 Nova?
1973 Nova Plastic Interior Parts
75-79 nova parts for sale
Whats my '78 Nova worth?
nova hoods
Stock block or Not?
75-79 new NOVA fender
87 nova problems
new nova!!
defogger
hood for a 76
68 Nova Wagons!!!!
Nova Power Steering Boxes
Crate Motor
MSD distributor trouble...
Sons new Nova
69 nova what is the factory torqued for body bushings?
Best Rear Gears For a 502
Big Block throttle linkage
How does this nor'easter get HEAT
need 1967 radio faceplate
2.73 rear end
Roof
73 nova bench seats...
1967 nova interior door lock knobs
firing order
glasspacks
back seats
car won't start...no spark!
76' Nova 355/350/3.73 sale or trade
dash lights
posi???
ReCalibrating a Speedometer...
washington
shock question
77 nova tranny modulator?
69 Nova Oil Pan Replacement
why can't I find a 76 SS?
Stock Motors
oil pans
gear vendors overdrive
Engine and Trans Swap
how much estimated hp
Urgent: Need Advice On 454BBC Headers For My 71
72 Purchase
1986 Nova 4Cyl
Valve tapping
1/4 opinions
Rear end change
Need Clock for 70-74 dash with knob
73 Nova Exhaust Headers?
neutral safety switch wiring
Rear Axle Gear Ratio
whats a good raditor
72 nova with reverse problems?
Looking for opinions on brakes
My 70 Nova does not have reverse???
is chevy 250 tranny interchangeable with 350
I Need Help
backspacing on wheels
Automotive Network, Inc., Copyright ©2012
