Automotive Forums Car Chat
Chevrolet
Cavalier
> Performance
View Full Version :
Performance
Pages :
1
2
3
4
03 cavalier intake
haters
how do i post pix on here?
How much gain?
how will my short ram intake effect fuel economy?
xhaust
97 cavalier 2.2L swap for Buick Century 3.8L
short ram intake need help
turbo installation
93 cavalier header (exhaust) does anyone make it?
Coil Overs What do i avoid??
what can i do to make my car go faster without forced induction and or internal mods?
bomz intake problems
Nos
Rev Limiter
question on TB swap
A couple of quick mod questions.
2.2l intake
Yes, the elusive governor
'97 2.2 cavalier
94 Z24 PROJECT "UNNATURAL CREATION"
91 air intake or exhaust?
Swapping Engines on my Cavalier.
engine swap
Got Sunroof Issues?
better mileage mods??
94 cavi rs performance
What's your opinion on the turbonator?
what shocks and struts are the best
loking for 98 cavalier performance internals
Rear sway bar '89 cavvy RS coupe?
Cavalier
Rough idle--surging
turboing???
Supercharger or Turbocharger that is the question
2001 2.2 pulleys
struts
Turbo
Intake Suggestions
90 cav mods
Chip
2.4 supercharger kit
'91Turbocharged Z24
Just Bought A 2.4L Turbo KIt
Turbocharging my 2003 2.2L ecotec Cavi
Where to Get 2.3 Performance Parts?
Intake Problem
how much HP with headers on 2005
Suspension
97 Z-24 engine swap to cobalt engine
2nd Generation Aftermarket?
WTF? is this a sign.
please, need help determining engine components.
cheap mods
IS there a way to pull the trolle cable so that the blade opens up all the way faster
Cast your Vote
RK sport exhaust
quick question about pulleys
problem with idle....engine swap???
Engine Swap.. (1991)
1998 Cavalier Z24 (evo?)
question about spark plugs?
2.8 engine gaskets, a question
please help me astray from name brands
does anyone else got 20's on a cavalier
RK Sport vs. Pacesetter
Another pacesetter header ?
upgrades
91 z24 specs
Drop Pics
pre s/c or nitrous
Shift Kit Question
Air Breather
Nitrous
Anyone have a nitrous kit?
Planned upgrades
Kyb Gr-2
Curious bout increasing acceleration?
Question performance
Turbonator
Lowing my car
Struts
exhaust system
5 speed trans for a s/c 3.8L in a 94Z
Question for all u Cavy peeps
Changin Hubs, Need advice...from smart folk.
custom exhaust manifold for turbo
project sleeper
Increase "mileage" performance
03 Ecotec Header options
Need help with oil pressure
B&M Short Shifter
weres the speed grovern
engines??
EcoTech Turbo
best bang for my buck
which intake would be better??
Starting off
Is this car worth modding?
2.4 ignition coil relocation
god damn !!
Who needs an adapter plate for their 2.3 HO Swap?
For you Eco guys. This will make your day.
does the size of a muffler clip matter??
should i get a....
price
head gasket
are all stock cavaliers as slow as mine....
question about down pipe
Motor Swap
Throttle body
96 Z24 2.4L Cold air intake Fit a '95 Z24 2.3L
Atf
weres the map sensor on a 9 cavalier?
IAT sensor
1/4 mile times
94 4dr cavi, swap engine INSANITY
anyone know how much hp i would get if i go from 18pd fuel injecters to 24pd injecter
air/fuel ratio gauge
K&N Typhoon Intake Kit
does anyone know what offset means in terms of mufflers
Performance Question
96 cav
headers and no piping
I lOve My Cavy and its turbo people talk to me
Performance Parts VS. Warranty
94 cavalier 2.2 automatic 4cyl
electric supercharger
trying to supe up my sunfire
does anyone know if a 2 chamber delta force flowmaster muffle will fit on a 96 4 door
Help!!
Supercharger
Turbo sunfire
Did the 2000 Cavalier ever come with sway bars from the factory?
suspension
94 cavalier 2.2 automatic1
going from auto to standard
30 k Maintenance Question
ENGINE SWAP...plz help
hard to find performance
the AIR SILENCER(aka air bong)
problem with shiftkit...
location of pcm?
94 cavalier 4cyl 2.2 Auto
How similar is a 2005 cavalier to previous years?
Apexi S-AFCII
conversion
Hey Im New!!
1994 4 door bodykit
Kyb Gr2?
Will this fit????
AEM wideband
Couple quick questions
where to get a shift kit
Nitrous on a 2.2L?
turbonator
more random performance questions
boost psi
3.1 Litre Z24 EXHAUST
sorry nothing to do with cars
How to add a little horsepower in a cheap way
question about mufflers
Q on pully's
2001 Inertia switch location
rear brakes
tranny boost
coilovers?
Boost psi
cavalier 14 inch tires
will talkking out the cat mes up the O2 sensor
3800 swap
convert your auto to manual
boost gauge install questions
new rods
cavalier performance questions...need help
Turbo kit 2.2 New
Finally, HO Throttle body and Intake Manifold
boost levels
internals
MSD Coil Packs
Performance Issues 99'GT
race fuel
TB Specs
FS: autotrans make your automatic shift faster
garrett turbo
'99 Sunfire Engine Shakes
my new engine tranny
ecotech fule injectors?
Underdrive Pulley install?
What good headers are out there?
Q
Gm S.c
intake or performance muffler?
tubonator supercharger
flashed ECU?
Pacesetter Header Question
Turbo Oil Lines
co2 cold air intake
ecu
Fuel System Boost?
ANOTHER QUESTION! (exhaust)
Intake.
Any Advice or InPut?
NA or FI?
Gasket Match draw backs?
Swap
RE:How to disable the speed governer/limiter?
new engine
mmmm booost!
question on bolt on mods
2005 cavalier simple question
header for 99' z24?
cam help
Crazy
Differences Eco/LD9
Secret Cams
2.4L Performance Plug wires
"Tornado"
Cold air intakes
speed limiter
Does this.... Work?
A turbo question (please give opinions)
Custom hood scoop
quick question for expensive 04 cavi intake
Spark Plugs
3.1L V6 in a 1997 cavalier
Throttle Body Spacer
Looking for a Performance Engine...
89 Cavalier RS
Take a look at this OBX header
Question for performance people
94 Cavalier n Cavalier z24's
Programmer?
G-Tech Pro SS
2.3 Hihg output...?
iat sensor
Pulleys
High Flow Cat
performance parts need for 86 cavi
mad power
question about 04 cavi header
Intake Installation Tutorial?
pcv valve location
Vote Now Or Forever Hold Your Peace. Super Or Turbo
Turbo for 03 cavalier
Short Ram intake Heat shield
block cleaning
Internals upgrade with super or turbo
Which intake should I go with?
Quality Real Meat Nutrition for Dogs:
Best Air Dried Dog Food
Real Beef Dog Food
Best Beef Dog Food
