Our Community is 662,000 Strong. Join Us.
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Chevrolet
> Cavalier
View Full Version :
Cavalier
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
90 cavalier to z24 dash
dcdennyy
Hub and bearing assembly replacement
2.2L Oil Pressure Sensor
1997 cavalier 2.2 transmission wont shift right.
3 timing chains in less then a year
Driving into the ground..
1998 ets off problem
Bad Intermittent Vibration
reverse gear gone
Advice on replacing my steering gear
2004 chevy cavilier not running
DRLs not working 98 2.2
Broke off old crank sensor trying to get out on 97
1996 Cavalier - Dead Transmission?
03 Cavi E brake cable Won't Tighten....
99 Cavalier 2.2L oil leak behind engine
Front Wheel Drive?
Cavalier AC blows cold while accelerating but is warm when Idle
I am the biggest LOSER: Fell asleep in my z24 and she overheated.
2002 Chevrolet Cavalier no start
Operating Temp
Electrical Prob?? Dash lights stay on? car wont shut off?
Headlight Bulb Question
96 Cavelier Lights not working correctly
Returning to Chevy Family?
My wife's vehicle pulls to the right or left
Buying a used car for our 18yr old
af news video: 2
Bolt Pattern-diagram for Head Cylinder bolts 2200 (1999 Cav)
99 cavalier...loose head bolts
Could ABS Brake System cause noise sliding on snow?
96 cavalier messed up again
starter motor types: Type PMGR, PG260D vs PG260F1 design?
Swapping in Electric steering from Cobalt looks like a NO-GO...
97 Cav does it have 2 O2 sensors?
02 with random misfire
EVA and couple other codes what does it mean
lower front re-enforcement bars for k-frame?
Can I swap in this rear beam axle from G5-G6?
2.2 L engine same as a Saturn?
toe in, camber, and handling?
97 rear brakes stop on and off and car lifts too
how u diagnois Anti Theft if Key Trick didnt work?
Just replaced K-Frame: (1999) noticed missing stabilizer-bar!
91 3.1 Reman Throttle Body?
2 cars and cant use ODB2 Code scanner
1999 Cavalier Starting Issue
Electrical problems
1999 Cavalier: DOT3 or DOT4?
2002 Cavalier Stopped Running
Cavalier/Sunfire Engine Swap
data connection plug
Cavalier 2005 LS
1998 cavalier transmission capacity?
Anyone want to help me with an experiment? Have a 1997 1998 or 1999 Cavalier/Sunfire?
Ripped off By Chevy Dealer Service Dept?
Wow....brake pad job so easy.
Does it matter what engine oil I use?
steering column swap, 02 cavilier
2001 Cavalier instrument cluster lights
100 Octane gas?
97 cavi questions need input quick please!
Cavalier turbo
Possible 3.4 litre drop in the Z24?
Transmission Fluid Capacity??...
Cam Sensor Diagram for a 2000 Cavalier?
LED lighting on a 2001 Cavalier?
***rwd***
98 cavalier engine cradle bolts
98 cavalier subframe?
p0496 problem
inspection place?
04 Cavliar wanna remove Headrests
Front Suspension Support
Cavalier Trunk Accident (and other problems)
2004 Cavalier radio
Radio question
Replace Dash
So like..
Cold Air Intake 2.3l?2.4l?
97 z24 aem short ram intake issue!
Better gas mileage
99 Cavalier Transmission
Mate Engine to Trans
Engine swap?
fuel injectors
1996 tires
engines
Please help me i need the answer to continue..
1996 2.2 transmission
what type of bulb is in the 2003 cavy instrument cluster?
2.4 engine
my cavalier
'94 Cavalier aftermarket stereo
How to: Water pump on 98 and similar Cavalier Z24
speaker help
91-92 cavalier parts interchange
New Exhaust Help!!!!
2000 Cavalier LS Sedan questions
price on motor
Replacing for with other doors?
which delco radio is non rds
Cavalier RWD conversion kits HELP
My new car
hub adapter for sale ..momo
Exotic Billet Ac/Heat knobs & Tilt
Upgrading to a.....
cavalier Engine Value
engine swap base to z24
1998 Cavalier parts
body kits and
Where can I find the pedal dance sequence?
Stereo Wiring help
dash
Exhaust System
What's the name of this body part? 92 Cavalier
2000 chevy Cavalier Key Fab
Alternate way to check engine codes
1999 Z24 Cavalier
New here with a quick q on maintenance
1998 Cavalier Z24 2.4 Quad 4 Head Swap / Interchange help.
Brembo Caliper Covers
wheel diameter prob
02 2.2 cavelier turbo question
2004 chevy cavilier
need 89 cavalier interior
Best Spark Plugs for 97' 2.2L LN2
1999 Cav - Replacing Stereo and Speakers
Chevy Cavalier Racing!! WICKED FAST!
What is the best exhaust & Why
VIN 4 Engine removal
Spark plugs
Update on my cavy...if anyone cares lol
headliner replacement
2.2 performance lol??
98 z24. 2.4 octane?
Research on cavalier.
95 cavalier and 98 cavalier... help?
Hey everyone, what's new?!
Fuel Cell
2002 chevy cavalier ?'s
New transaxle?
Dash Bezel removal
Bumper Cover
1998 cavalier
gas mileage?
Price on a 1996 Cavalier?
1988 cavilier station wagon
Gearshift knob
170 km/h
General Question
I need help unlocking my cavalier cd player
R/R alternator bearings
How much do you like your Cavalier/Sunfire?
Front wheel bearing R/R where is seal?
Hello
The basics of how electricity works and why you need to solder wires together
Buying a Cavalier... what year?
Car pollution
My New Lights!!!
Tenzo R Rally Seats
98 Cavalier RS Maintenance
What to do next?!
97 Cavalier fr spring identify 22132807
Hood Scoop
factory alarm
Check your ecotec!
160 degree thermostat
Questions
website
2003 Cavalier battery drain?
Throttle body peice missing
2.4 head on 2.2 block?
Clean your oil pump pick up screen without removing the pan!
Problems with Webpage
04 cavalier tapping inside dash
Grounding Wire Kit 2.2l
Check Engine Codes
fuel control
'03 cavalier brake light
Dash Light?
93 z24 3400 swap
1999 cavalier manuel trans question
04 Cavalier windshield washer jet removal.
2002 rear trianle window
Engine Hose Diameters
Parts interchangeability?
Any '94 Cavalier performance exhaust systems????
2005 Cavalier tuning shops?
99 cavalier key fob programming
cracked head new motor maby?
2 questions about manual transaxles
help?????????????
cavalier bumper swap
Hey
Suspension Question
heater will not blow any air
my new car!
00-02 Stock Amp?
cavalier air bag
cd player
02 cavalier cornering light help
tranny swap 2000 cavlier to grand am?
2.4 cavalier avg. fuel mileage
2005 Cavalier Tire Pressure
looking for some engine advice
safety feature or what?
Cobalt motor
2000 Cavalier Automatic Transmission won't shift from 2nd to 3rd
cavalier 2000 won't start
installing an aftermatket tach in a 1991 cavalier
How to install a Volt Meter
Oil viscosity?
Still around.
Cavi Parts
98 Cavalier - Engine Cooling Sensor Location
98 Z24 Oil Leak
1992 cavi wagon
Speedometer not working
Water in oil filler tube!
Body damage repair question
92' cavalier turned race car, Cylinode problems
Help!
broken windshield washer hose
2000 z24 engine swap????? w 97 sunfire :S
Fuel pump question, need ASAP!
99 CAVALIER starter
2000 Cavalier Hesitation
Coolant issues and blinker issues
Bye Bye Cavi.
96 cavalier idle problems
95 Cavalier rear speakers wont work
Friend just got one, what should she know?
02 Z24 engine swap Manual/Automatic transmission
v6 swap
105 MPH Cut-Off?
More Power in 02 Cavalier auto.
help to remove interior rear panel
The answer to the oil requirements to the 95 cavalier A/C System
Tire size correction?
No longer your J-body advisor...
2001 cavalier ~z24 for sale~
2002 Cav. driver seat...replacement?
Painted my Sunfire's back panel.
Cavalier Performance Goods!
Boredom and a shit ton of parts leads too....
I got another new Toy.
Rims and Tires..ENKEI RS5
15 or 16 inch wheels?
Automotive Network, Inc., Copyright ©2012
