which intake would be better??
ford460bigblock
06-06-2005, 08:40 PM
which one should i go with
http://www.turbotechracing.com/productcart/pc/viewPrd.asp?idcategory=371&idproduct=756
http://www.turbotechracing.com/productcart/pc/viewPrd.asp?idcategory=371&idproduct=750
http://www.turbotechracing.com/productcart/pc/viewPrd.asp?idcategory=371&idproduct=1159
http://www.jbodyperformance.com/new/PartDetails.php?partId=202&catId=202&catName=JP0202
http://www.jbodyperformance.com/new/PartDetails.php?partId=553&catId=553&catName=JP0553
i know that they all probly will give me no more then 10hps if i am luck . but i just want to know if anyone has these or if u know that there good
Classicrocjunkie
06-06-2005, 11:21 PM
http://www.rdfabs.com/22noneco_caint.asp
Stainless steel and not aluminium.
OverAllComa
http://www.gravanatuning.com/applications/1997_Chevrolet_Cavalier_Coupe_2.2.aspx/2/52/_Air_Intake_Injen_Polished_Aluminum_Air_Intake
Or my personal favorite for the 2.2...
http://www.cavalierextreme.com/performance.html
2.2L Stage 3 Turbo
Mod'd_Cav
06-07-2005, 09:20 AM
it wouldnt really matter what brand you buy for the intake cuz it does the same job as every other one..for stuff like suspension and wheels and internals i can see...but for intakes its just a pipe with a filter on the end..and its the air that does all the moving..but if you want a good intake and i mean a really quaranteed working one..buy whichever one you want from the ones you listed...and buy a ram air hood insert or add on (whatever you want to call it) and install it so where the air goes in is right over the filter...you would have to cut the hood...but if you want a real power gain..thats what i did..the one that CRJ put in works..but thats for ppl who dont want to mess around with the hood..it does work..but it has to hit alot more bends and its spends more time in the pipe so its more susceptible to heating up on its way to the TB...but if you want for sure power gains with an intake i would cut the hood...install a ram air hood right over the filter..now thats cold air..
peace
ford460bigblock
06-07-2005, 08:44 PM
also would a foam filter be better then a paper filter
Classicrocjunkie
06-07-2005, 08:52 PM
^^ Stick with K&N... good for life!
ford460bigblock
06-07-2005, 08:59 PM
also whats better Stainless steel and not aluminium
is it true that stainless turns gold when it gets hott
OverAllComa
06-07-2005, 09:00 PM
All steel changes color depending upon its temp and what's burning it.
ford460bigblock
06-07-2005, 09:11 PM
i am thinking about the http://www.rdfabs.com/22noneco_caint.asp intake is there good hood clearness
ford460bigblock
06-07-2005, 09:13 PM
also if anyone has it does it sound good and about how far under the batteri does it go
ford460bigblock
06-07-2005, 09:20 PM
also in the pics it looks like it goes from small pipe to bigger pipeing is this true or am i seeing things
