Dodge
> Neon | Plymouth Neon
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
brake shoe help
no fuel to the engine
electric problem with dogde neon 1995
Idk what the problem is...
No Clutch Pressure
Accelerates slightly on its own
'96 Plymouth Neon Oil Pressure Light
broken alt belt leads to no start!
2000 Neon Power Steering Fluid
Call 570-815-4697 For Help With Your Neon
2000 Dodge Neon Sick Wit It
98 neon fuel accumulator????
Tach swap out
2000 Neon blowing fuse?
Please help me neon wont start in cold weather?
97 Neon- Hard start and stalls
2000 Neon no heat
99 neon r/t gets 9 miles a gallon need help
FOR SALE - First Gen Aftermarket Muffler
96 neon acceleration problem
help 99 neon r/t wont hold an idle
Oil Leak
Key Fob Question
Radio Install ?
bad vibrations
NEON squeaks while in reverse
Plymouth Neon 00 "oil pressure switch"
Airbag, brake lights on !!! Help !!!
wanna buy a neon
neon coolant possible thermastat?
installing passenger side mirror on 96 base neon
Heater Freezing
neon 2000 help
crate motors
97 neon headlight replacement
96 dodge neon want to convert SOHC to DOHC
Need help w/cd changer
Starter Problem???
Wont Start in Park Will Start in Drive
New Tires Wow
Obdii Trouble Code Po123
weird electrical problems
weird SCREEEECH noises.
Bad to pull a trailer and quad with my Neon u think?
Dented Door
2000 neon automatic adjuster lever!
Neon Clutch Replacement - Hard or Easy?
98 Dodge Neon idle little rough when park on Red light.
Fuel Tank Filler Pipe Broken!
FS: BRAND NEW AXIS REVERBS with BRAND NEW TIRES
bashing a neon
03 se 4 sale
sunroof help
plastic headlight covers any ideas on how to clean them
oil leak need help to identify where
im having some engine problems
2004 R/T Clutch hydraulic issue
what side does the larger cooling fan mount on a 1997 dodge neon?
What's wrong with my a/c
can anyone help identify leaking unit?
Neon runs rough then shuts down
Screeching from backend
Car thinks is overheating....Help!!!
buying a 2000 neon
Buying a Neon...
Keeps Shuting Down
need a little help
code 25
Fuel Air Metering Code P1193
Rough Idle
Can anyone help me?
Impossible to move shift selector
wheel size
F Car
Back Drivers side wheel won't move
Anyone giving up ther stock spoilers, the SXT type (2000&up)
Is high idle OK ?
tachometer
Engine oil in the coolant
Need help with rims/tires!!!!!!!
Where can i find a body kit for a 1988-89 Lancer?
More specifically: What's the best oil VISCOSITY for your Neon?
I almost died!!
tires
No bass in new after market stereo
heat!!
alternator not working?
Question about rims??
98 neon vacuum lines
Spark Plug Problems
rim size ?
cracking sound? cracked axel??
Neon Wont Run Even with gear In!!!
My brakes suddenly stopped working...o.0
Getting a neon
buy them i want them GONE
Help!!!
For Sale 99 Neon Sport. 2.0 Dohc
Re-attaching a car door.
Lets Talk about yellow fog lamps??
quick question
1st Gen to 2nd gen Front clip swap.
Unmovable lower alternator pivot bolt.
Please give me some clue..Help!
Bumper Side Marker Lights fuse
Neon sub-forums
thinking of buying one
1995 Neon for sale-East Arkansas
Need help on a buy
need help
WTB: ACR, R/T, or Sports Coupe
Squeelling when turning
evo neon
i need some parts
theft detterent
My Neon runs rough when you first start it
Neon Seats and Door Panel
melting battery cable connector
champion vs. bosch+4
engine code 52
CAI Question
I'm missing a bushing on front stablizer bar
Shaking when I ingage the clutch
Car Power Strip
Question about Torque
going crazy
How much can i get for my neon?
no key...
The first SRT-4, I believe..
97 neon DOHC for sale
Have you installed a manual-to-power door lock kit?
next project
for sale parts dirt cheap
V8 Neons!!!
what to do to fix hole in metal under car?
ughh remind me to not do it again
runs rough
Nice Burnout Pic's
looks like we are 1 step closer to making the hornet a reality...
SRT-4 Deck Lid
cat backs?
removing shift knob
Odd starting problem
how reliable are neons
Neon burout
Funny vid about this guy and his civic
kinda, yeah, maybe
Which year is Better?
Turbo for sale
Ignition electrical issue
ready to put in turbo
Engine Knocking
neon turbo manifiold
dont think this is good
Almost Busted.
oil sandwitch plates
Modification
Local Street Races!
Trans Help
Neon wasn't replaced...
Using quart of oil every 2 weeks.
Door lock linkage
lowering springs????
I did a piston soak
i need help
Please Help
what is the number on a o2?
Strange Problem
injector size?
window tinting
intercooler Qs?
I need je pistons and eagle rods!
testing waters
Rear-mounted turbo?
blow off vaulve on a auto
destroyed SRT-4
Car 4 Sale
Fuel Sending unit
misfire
remove air box -filter
code 171
Neon help?
Stored for winter... now won't start
Brakes
help with codes
Tapping sound from motor
need pics
Turbo????
serious problem
Need Help With Tachometer....
Outside Mirrors
resinator question
intake manifold Q?
skunk 2 lowering springs for sale
Alternator bolt
under body neon
Paint
Exhaust System?
Speed
squeking power steering belt!!
Interior Designing
head gasket for a bored engine
Car for sale
Hp
Interior
Z3 fenders
Help Please
Taillights
neon chip
High speed skip?
transmission swap?
Needin some help
New
Turbo Question
resistor chip
chewing sound from driver's side when steering to left ONLY.
oil leaking
Ticking noise
struts and springs
Air compressor
Weird Noise Under The Car
Audio question....
ripped off?
Shaking neon =(
alternator
SRT-4 front bumper...
Horses don't make good passengers
clutch question
For you 2nd gen owners
stay away from whater
DRL Module
WTB: black rear bumper
valves
Lighted Rearview Mirror and Wire harness - 2000 Neon
Random maybe dumb question...
Hello and question
WTB: 95 neon engine
do ya think it help the looks any?
Question
Oil
TRC-2 Crane
Oil on spark plugs
fuel tank and fuel injector ?'s
Starting system? Electrical? I don't know!!!
fan problems
help please
WTT:89 Civic Sedan
Oil Leak! Sensor or switch?
Modification for an R/T...
