View Full Version : Neon | Plymouth Neon
Pages :
1 2 [ 3]
4 5 6 7 8 9 10
- Which manual is better?
- Good Or Bad?
- neon cd-changer help
- If there were recalls, which would you want?
- no balls off the line ?
- 103,000 -PM suggestions, High Milers
- track times
- New Alternator makes a ton of noise
- Struts for lowering NEON help??
- Hids
- haha
- What do you think?
- AWD srt-4
- Just wondering.........
- Stereo system in Neons.
- 05 SRT-4 New $15,499
- exaust size?
- Gas!
- need help
- Neon Service Manual
- Annoying Squeak in Wheel Well
- would not start
- JET Power Control Unit
- Looking for exhaust sound clips.....
- I just bought.....
- Lost
- Wrong oil
- Electrical Problems?
- Projector Healights?
- locked keys in
- New Suspension!!
- Faster Neon
- Door speaker replacement????
- New Front End Conversion
- thermostat
- Cam sensor seal replacement-Help
- HELP..car wont start!!
- What does 3-2 Kickdown Runaway
- ignition wires
- Clutch Noise
- this is a joke
- throttle body
- Neon gets replaced
- exhaust idea
- Foglights
- why no 2nd gen DOHC?
- changing engines
- small upgrades?
- Neon Overheating....
- Hign Idle
- Car won't start
- turbocharged!
- Starter
- ahhh
- Important Parts
- misfire and running rich????? plz help
- e-brake light goes on under hard acceleration
- Bent Motor Mount
- oil filter location
- tranny swap
- v-tec dodge neon lol
- I jut sucked water through the intake
- Original Alarm not working
- Oil Leak
- oil pressure sensor leaking?
- Exhaust Suggestions?
- How do you adjust the clutch pedal cable, on a MTX 2000 neon???
- knocking
- cd player
- will 1gen 3.94 tranny fit on 2000 neon???
- Where do you add transmission Fluid?????
- oil problems HELP
- What car to buy.
- LEAKING HEAD that wont stop!!!
- Help please, Code P1299
- More help with engine codes...
- NE ONE NEED 1G parts??
- bad clutch??
- confused about headlight options
- Whats a better auto repair manual.....
- Email Notifications
- Neon body kits
- what can it handle?
- Any suggestions on how to repair?
- Fenderwell intake VS cold air intake
- Help ME! My car has been accelarating on its own!
- fuel delivery?
- stock srt-4 parts for sale
- muffler bearings!!!!!!lol
- stupid question...........
- Help brake lights and turn signals dont work
- srt-4 for sale
- SRT-4 brand new Pricing help??
- bov and mbc for sale
- Skipping problem
- oil leak
- 1998 Dodge Neon Sport FOR SALE! / 2 door / excellent condition! In Michigan
- Gas milage gone wrong
- key dance
- neon being discontinued
- My Clutch Is out........I Think.
- neon stops after 15 miles
- Shifting problem
- What's the BEST oil and filter?
- Wiper Problem
- BodyKit Fitting...
- magnum intake manifold
- warranty question
- Shift cable is getting stuck
- need help
- cold air intake
- Turbo Kit & WW Body Kit FS
- Fuel Leak
- What do these codes mean?
- Multiple probz with Neon
- Compressor question
- help with removing parts
- cd changer help
- bov
- back passenger side
- Water Leak
- electronic superchargers
- flashed key three times and got code 11 "no dist. reference signal on 99 neon ..help"
- About to pull the trigger...
- transmission
- IAC Valve Inquiry
- ALL SRT4's!!! LOOKING FOR HOTCHKIS SWAYBARS FOR CHEAP?
- Huge Problem With Smog
- Info on SRT-4
- Head Gasket - Runs, still oil leak - CAULK???
- front lower control arm
- Blowoff valve
- how much do solid mounts stop wheel hop?
- neon code Po601
- srt kicker w/amp
- Beautiful Engine Bay!!!
- Noisey lifter/rocker... TEXSRT4 help?
- Timing Belt - Interference Engine 97 Neon SOC?
- Moonroof?
- Brake Noise?
- fuel system lean??
- Srt-4 for sale!
- Buying an SRT-4
- Neon - noise on start up
- Engine Knocking help please.
- possible fuel problem?
- diagnostic codes question
- cylinders not firing
- Viper chip
- Extior Modifications
- rim/tire size
- looking for performance parts in canada
- bracket question
- transmision trouble
- custom turbo setup
- neon engine swap
- Stage 1 / 2
- help with engine codes
- stupid a$$ question
- no bus?
- my car keeps acting like it wants to stall out!!! please help
- Neon Interior Question
- Need Help On "Check Engine" Light!!!
- Neon stalling at stoplights
- Please Help!!!!
- What doors fit what years ?
- Custom Fiberglass subwoofer boxes 2000 neon
- New cluster?
- neon aftermarket suppliers
- battery or alternator problems ????
- I'm such an idiot!!! - Booster cable misshap...
- Vote! EVERYONE! (Spark plugs)
- Turbo kit
- Dome light turning itself on and off
- got udp and have a question
- axles, tranny problem needs assistant??
- car alarm install help???
- electrical problem
- My Modded Neon
- Neon falling apart
- Wiring harness locks
- fuse box diagram
- how much?
- Daytime Lights
- horn location
- starter issues
- should i even bother
- anyone from tampa area
- piston question
- READ THIS! Important ignition system fact
- modular and non modular clutch
- rough starts
- Q's about Cam sensor, trans. fluid, other sensors.
- Oil Filter Location
- Tranny has problem shifting
- omg hondas
- problem: hesitation
- megasquirt 2
- Major oil leak!!!
- fuel problem
- Brakes
- help me with my 02 neon
- Notchy shifter
- Code 54 means I need a New Cam Pos. Sensor??
- Fuel Problem ???
- gettin ready to build
- repair cost
- 5 Doors Only!? Ugh!
- turbo help
- Srt-4 Ok car but Chrysler is a joke!
- got a question bout pistons
- WTF is this sensor???
- neonik freakish car
- tranny ques.
- Auto Trans Help Needed ASAP
- Yellow cloudy headlights - no more! Read this!
- and another question as well
- problematic audio system
- pics available of 95 neon 4dr with blown head gasket for sale as is, $400
- Simple stock speaker question
- srt-4 with profec E-01 haveing problems
- Neon Factory Colors
- Goodbye Neon
- need working minds
- Possible W/ Forced Induction?
- Performance cat?
- Daytime running lights
- Fuses, wiring, grounding...
- Interesting Problem
- Need for Speed?
- Stratus rims on a neon?
- Will DOHC head work on a 95 SOHC block?
- Unconventional Neon
- srt-4/02 neon r/t engine swap help please!
- Help please
- How to replace rear drum breaks 97 neon?
- Remove and replace transmission governor
- Sunroof Problems
- Does a 2.0 liter SOHC 96 Neon have a non-interference engine?
- Price Ok?
- engine blowback?
- Cable for the Trans
- springs
- brake problem
- i want better mpg
- For how much I can sell my car ?
- Repeating "humming" sound
- I need help!
- very confused
- More Problems
