Honda
> Integra
View Full Version :
Integra
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
87 integra "misses" at rpm
92 Integra Ignition Switch + Door Locks + Key
stroker ls vtec prices
who's faster?
starting problem
98 integra 1.8L non vtec 4speed auto
B16a or B18a???
ls nitrous time slips
starts in all gears
will my tranny bolt up to my new engine???
hondata help
Turbo?
Street Legal?
type R
crower 62402T-2 cams
Please Help!!
collecter header size?
vtec heads?
lugs nuts
Type R Tranny install pics...sorta...56K NO WAY!
new clucht help
wiring new guages?
Insurance Talk
VIN Check Please!!! Plan to buy tomorrow...
93 acura integra problem
b16a2 ls/vtec
GSR slow?
lost in my engine
engine coolant gauge
Vtec engagement
Car Running Lean
98-01 front bumper conversion
Where to buy smsp headers?
Recondition or conversion
dumb question but what tranny does a obdo integra have hydro or cable?
ls/vtec and nitrous
integra with an automatic
cv boot
bolw off valve
what my performance gauges read...
HID problems
which is better
90 integra
ls/vtec qustion
Air conditioner works, but isn't cold
Wireing up my air/fuel gauge to ecu?
Tranny question please help
New seats
Is my clutch bad?
j's racing intake
Exhaust piping diameter
compatable gearboxes
90 Ls Teg Engine Wiring
tranny fluid dipstick?
whats the difference
piggy-backing the ecu?
k&n cleaner on AEM short ram intake filter ok??
N/a Ls
trouble code help
VTEC problems?
b16a2 JDM wire harness
Sell or Rebuild?
1/4 mile
clucth install in philly?
Ive got a no hot start question
1991 TEG LS B16 swap questions
two-tone paint job
Itr Pistions In An Ls?
Please help
integra LS 98: does it have idler pulley
GSR tranny
must get more power !!!!!
starting...oddities
vafc and vortec fmu
screw the leak
custom turbo help
integra ls's chances
Bodykit Mystery...
Swap Options LS/92
Is the b18a1 harn. same for auto/5speed?
96 gsr HELP
nitrous good idea or bad??
can any one help me out???
opinions please.
valves on a 1995 GS-R
Power antenna
GSR speakers.....
Which Trbo Kit Keeps the A/C & p/s?
91 4-door Body kits
COmpression?
Head Gasket
1st gen info...
turbo kits for an LS
Does anyone know anything about these exhausts
reflashing
stock clutch / lightened flywheel?
how many washers on diy rear camber?
Rain Water+Cai
90 integra gs transmission problem
****stereo Code****
How do you put on a Head Gasket?
20w-50 oil
pics of my setup
going turbo
big advantage??
what to do with my car?
New Coil
LS Special Edition
Aem V2???
Problem w/ my GSR????
GSR speaker sizes
Noise from clutch
what do you motor head think
91 Integra for sale
Best oil for integra gsr
need help
install help again
cold air intake hp?
strange noise
FS: Acura IntegraB18BLS 4-door 5-speed
new toys
making an offering on a car
Swapping out auto tranny
Front tranny mount bolt
Fuel Pressure ASAP!!!!!
b18c5 prices
rev an ls to 8000
STRANGE GRINDING NOISE, help plz
vtec "kick"?
help
Freakin fuel leak... help
96 integra LS hatchback?
b18b project
2 Piston Calipers?
honda motor desicion
1995 Integra LS
DIY ground wires? anyone?
ITR Valve springs
cardomain.com?
who would win
know any reliable engine importers?
Shift Boot
Hard Time Getting Timing Belt On
Seattle Tegs Unite
My Maint Reqd light is on... what could be the problem?
Make-A-Wish Cae
honda s2k topend
Radiator
Rim Question
difference
what intake mainfolds
Revive an Integra
deeper problems than just windows
Piston-Valve clearance problems?
does a 98-01 integra front bumper fit a 94 .?
Quick Question
90-93 with a b18c5
93 integra for sale
2005 type r
wondering about a broken steering lock
Buying a 2000 gsr
Rear Brake Light
Integra cool
ls/vtec
OEM prices?
I have a Bad Wire harness
Does anyone here have a turbo LS?
p28 turns into ak47!!!!
exhaust
turbo kits
94-97 & 98-01 difference
How difficult radiator replacement 92 Integra?
Hesitation
90-93 integra hks exhaust
headlight grounding
Ebay parts??
LS? or GSR?
Going turbo
greddy turbo, 5zigen exhaust??
98 front bumper conversion???
ABS Light won't turn off
Lights
always blowing heat
roll cage
Help with engine block/head identification
Timing belt basic questions
Where is the crank angle position sensor ?
Rear Seat Nightmare
Unstable idle
help with starting my 95 teg LS
battle
help on engine swap
will someone please help me on this one?
Honda Parts to Australia
TPS Trouble
00 si tranny good?
what air intake works for hybrid?
automatic seatbelts wont return
Which one 2 buy
AEM cam gear help.
turbonetics???
cylinder sensors (CYP)
Traction Problems
Cant keep caliper sliders from freezing
Whats the best year for the GS-R?
need to know fast
Rotor & Caliper Upgrades?
obd2 gsr bad for HP??
what to replace to make new???
Need some help
GSR running lean
LS,GS...are they fun even tho no VTEC?
generations?
integra fuse box help
jrsc headers,exhaust
aem cam gears
Check engine light??
integra sir-g ???? what the?
ecu ecu ecu i see you
Short Throw Shifter
Eibach pro-kit 1.3 drop
my car shut off at 140mph
thinking of trading my car
GSR cams
95 Integra GSR 4 door
please help!! aftermarket performance gauges question
buzzing noise?
front end conversion?
Seat removal
aem cam gears
Whistling noise and problem starting
h22/h23
No spark!!!
the best place to start?
installing aftermarket gauges volts/oil psi/airfuel
stage 1 cams vs stage 2 cams
engine code p1457 evap system leak detected
engine codes
suggestions please
H-Brace, Pillar Bar?
Questions About my Integra Weird?????
hang on tight wooooooooooooooooo!
install help
legal RHD integra to US? hard?
How many of us name our cars?
HELP!! Driver side door won't unlock!!
Audio in Integra GS-R
Got pics of my new GS-R.........
wheel size
Use Tsudo Anyone?
