View Full Version : Cherokee
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21
  1. Stock 89' Radio Wiring
  2. Converting a 4 Cyl. to a 6 Cyl??
  3. Rear Suspension??
  4. Water pump replacement
  5. Oil Pressure
  6. dash lights come on dim when brake is applied
  7. Dull headlights
  8. Removing engine fan-adding electric
  9. 1993 Cherokee-"NEW" ENGINE WON'T START
  10. newbie with tranny question
  11. 4.0L not running right, sensors/computer??
  12. interior lights wont go out
  13. 91 Cherokee still won't start, please help!
  14. '91 Cherokee for sale
  15. throttle body
  16. Oil pump replacement?
  17. all time 4x
  18. forced air
  19. A/C to Air Compressor conversion
  20. Ford Fuel Injectors
  21. Need to cool off a little
  22. More horses for my 4.0
  23. fuse box
  24. crazy flex?
  25. Looking for a 4.0L 242cu engine for my 88 Jeep
  26. 1900 Jeep Cherokee Laredo Cooling Issue
  27. Power window trouble
  28. 2001 Cherokee Sport 2WD 4door misc?
  29. 1999 Cherokee Classic stalls while on highway!
  30. Puzzled on Bolt
  31. Idel Motor Sensoer problem
  32. 1994 4.0 Cherokee Will Not Start!
  33. Tough starts--cold and hot
  34. 1996 Cherokee Sport For Sale !!!
  35. tow hitches
  36. 2000 cherokee engine into a 1987 body...
  37. Replacing CV Halfshaft
  38. Positive Valve Cover Pressure-->How Much?
  39. Ok let the laughing start
  40. 1994 Jeep Cherokee transmission fluid coming out of dipstick
  41. Oil Filter Mount
  42. Gear Ratio help
  43. abs braking system
  44. '91 Cherokee Trans
  45. Mystery Leak
  46. Squeak-squeak
  47. cruise control
  48. 88' some questions
  49. #26 injectors
  50. 4x4 vacuum modulator????
  51. Changing to 4X4 Full time??
  52. Another idle issue thread 1991 Sport 4.0
  53. 90 Jeep Laredo Factory Radio Removal
  54. Color fading on plastic over wheel well.
  55. Desperatly need 02 accord digital clock
  56. Blow-By Problem
  57. Rear door lifts question
  58. 93 Cherokee Low spark
  59. "limp mode" on 93 intrepid
  60. "limp mode"
  61. 91 Cherokee fuel pump relay clicks on then off
  62. 94 Grand Cherokee misfires above 2000 RPM
  63. oil pan gasket
  64. Newbie repair questions from a new Jeep owner
  65. Replacing a 89 Cherokee Radiator
  66. vibration , noise? 2000 cherokee
  67. Fuel Injector
  68. Front Seats Upholstery
  69. wont start
  70. 4wd/2wd shifter fork (front axle)
  71. Momentary rough idle???.
  72. i smell like gas
  73. Rear Bearings
  74. 94 Cherokee A/C whining
  75. vibration cant figure out why
  76. 99 XJ 4.0L Electric Fan won't shut off
  77. start/stall/no start
  78. leaking coolant all over the ground....
  79. GC Seats in a Cherokee?
  80. 1987 jeep Cherokee dashboard symbols
  81. Best Oil Filter
  82. Headlight relay
  83. 2Fast2Furious?
  84. check engine codes
  85. PurgingAir From Water (Coolant) Jacket Post Water Pump Change
  86. If your hood release cable breaks
  87. Oil leaks from main seal again?
  88. Look out below!
  89. 89 Cherokee low rpm hesitation
  90. waterpump 2001 cherokee
  91. Overhead Console
  92. cherokee tranny problem
  93. lifting my 92 cherokee
  94. Chrysler or AMC ?
  95. Non blinking turn signal-94 Cherokee Sport
  96. Shocks
  97. rear main seal
  98. 94 Grand Cherokee wont start
  99. 2000 Cherokee Sport equipment question
  100. 99 cherokee won't idle..........
  101. knocking sound after spark wire mixup
  102. sudden kills
  103. Bad headlight switch??
  104. Fuses blowing, wierd electrical
  105. No Start, no Insterment panel gages work?
  106. Hot To TROT
  107. Vacuum Lines
  108. automatic transmission fluid change
  109. light switch on a 94 jeep cherokee country?
  110. Neep Help ASAP Please
  111. Post-traffic engine quiver
  112. radio and dome light
  113. missed the guys here!!!
  114. a picture for all you jeep guys
  115. 97 Country Problem!
  116. factory wiring harness in 98 Cherokee?
  117. How to lift it
  118. battery power problems
  119. OEM rear window dust deflector- 98 Cherokee
  120. No night driving for me...
  121. liftgate won't open...
  122. lower ball joint grease fitting
  123. 95 cherokee trans/tranfer swap with 98
  124. Difference between 99 and 00 and 01 engines
  125. Engine Removal With T-case?
  126. VIN definitions
  127. Fouled Plugs
  128. electric fan override
  129. head lights won't turn on
  130. 87 Cherokee braking problems
  131. Replacing alternator 92 cherokee
  132. Need Advice!
  133. fuel filter location 91 jeep cherokee
  134. 1990 jeep cherokee limited specs?
  135. Factory Service Manuals (fsm)
  136. no pressure in clutch pedal
  137. About neutral safety switch
  138. 92 cherokee stalling problem
  139. 1988 jeep pionner parting out
  140. No compression in 1 cylinder
  141. lights
  142. Vaccum diagram and "part time"
  143. 89 Cherokee no fuel.
  144. Anyone Needs These?
  145. jeep 4.0 engine parts
  146. My jeep is leaking water whenever it rains!!!
  147. front axel (left side) leaking diff. oil
  148. tail,parking,and intrument pannel lights
  149. Reverse Lights not working on 1996 Cherokee Country
  150. 2000 Cherokee Sport won't start
  151. Intermintent Overheating
  152. 4x4 and fuel gauge problem
  153. Flat or Roller Lifters on a 2000 4.0?
  154. No Power to Ingnition switch
  155. Rear Wiper Question
  156. cherokee + turbo = whp?
  157. 93 cherokee low spark
  158. problem with ignition/transmission?
  159. tranny fluid change?
  160. Cherokee Sport Hesitating
  161. Freeze plugs?
  162. clicking valves?
  163. Tire size and rim question
  164. convert command trac to selec tracl??
  165. not enough heat
  166. rough idle
  167. Will it fit?
  168. head light problem
  169. stalls on left turns????
  170. $120. good price?(rear shocks/mounting)
  171. a/c and electric issue
  172. 1989 cherokee no spark?
  173. MY 1990 quit while cruising on the highway
  174. changing oils
  175. factory stereo
  176. Injectors question
  177. 2000 Cherokee Sport fan switch
  178. front axels
  179. 94 stereo wiring problem
  180. intermittant wipers
  181. 94 jeep grand cheokee ran out of gas
  182. 1989 Jeep Cherokee won't start
  183. FS: 1990 Lifted XJ - South Jersey
  184. Stalling jeep!
  185. Help,4x4 is making a clicking noise
  186. 89 cherokee won't stay running!
  187. Lift kits- what do I need?
  188. Hitch Needed 1989 Cherokee Pioneer 4X4
  189. Front Differential
  190. Difference between '00 and '01 XJ
  191. steering wheel picture
  192. New Rocker Panels
  193. Check Engine Light on
  194. 1990 Jeep Cherokee 4.0 5-speed SOMETIMES won’t start.
  195. steering bump
  196. throttle body vs multiport
  197. tire size differences?
  198. Need Vaccum Diagram
  199. lifted, coils on front still compressed?
  200. Tow hitch
  201. Forum questions
  202. 1994 Transfer Case Shift Sequence
  203. 89 Cherokee Not Starting
  204. for the woodys
  205. 1989 Emmiss Maint Light @ 50K
  206. right rear power window won't go up
  207. Knocking Lifter
  208. fog light install
  209. 86 Cherokee
  210. Coolant Block Drain Plug
  211. valve cover gasket
  212. Blown Engine?
  213. 2001 XJ Service Manual?
  214. Part-time light on, but no 4WD...removed
  215. AutoTransmission Fluid Change 1989 4.0L
  216. 1998 rear hatch lock Jeep Cherokee Sport
  217. Pulling my hair out
  218. Computer Chip in Keys
  219. can I use 6 1/2 speaker
  220. HELP Wiring Diagram for Cherokee 97 TD sport 2,5
  221. $$... is it going to cost alot?
  222. synthetic oil
  223. Special Edition??
  224. parts
  225. 2 or 3 inch lift?
  226. does motor need to be rebuilt
  227. Rear Wiper Bezel removal
  228. power windows problem...
  229. Cherokee Country Bearings
  230. Exhaust manifold replacement
  231. How to recognize command trac from select trac?
  232. my heat is broken and im really cold
  233. Emission light stays on...UGGHHH!!
  234. Is it possible to clean my injectors?
  235. Selling my 86' XJ
  236. 1999 Jeep Cherokee Gas Gauge Stopped Working
  237. need help on water pump
  238. Factory Jeep Tech-service manual; 2 books 1990
  239. "Dying turkey" sound in 01' Limited engine
  240. CPS questions
  241. just bought 93 Cherokee
  242. Brake line screw rusted into wheel cylinder
  243. 1996 jeep cherokee wont start
  244. 1990 jeep cherokee limited making humming noise
  245. 4wd
  246. Stalled 1998
  247. Cherokee Freedom edition????
  248. Transmission Fluid Leak
  249. Selling XJ
  250. need help... Front Hub assemblies and U-joints
