View Full Version : '83 - '90
  1. 1988 jetta fuel leak below injector
  2. For sale
  3. can this 1988 Jetta 5 speed transmission be fixed? Or better to replace?
  4. 1986 vw jetta overheating too quickly and shuts off.
  5. Rear movable window replacement '88 Jetta
  6. 90 Jetta - won't start, sometimes
  7. 1990 Jetta Carat engine's rpms fluctuate between low and high rpms
  8. 85 jetta gl: clutch, linkages, or transmission?
  9. 1990 jetta spits and sputters
  10. 89 Diesel Jetta Electric Loss
  11. 89 Diesel Jetta Electric Loss
  12. 1989 Vw Jetta gas comming out cylenders
  13. 85 jetta 1.8 idle control motor question
  14. Fuel gauge troubleshooting
  15. intermittent low power on 91 gli 16v
  16. 87 Jetta GL Wolfsburg
  17. 88 gli
  18. 88 Jetta starts, idles rough, but no accelerator response
  19. 87 Jetta hesitation on acceleration
  20. Spark Problem
  21. 86 jetta diesel
  22. 1985 VW Jetta oil problem
  23. I Have Problem..Won,t start when is Hot
  24. OBD plug location
  25. a/c recharge
  26. Idle And Start problem
  27. ignition switch change
  28. Hall Effect Switch Testing?
  29. '90 Jetta Carat Wolfsburg Edetion Sensor?
  30. Jetta won't start
  31. Oil Alarm
  32. 89 jetta starts hard sometimes
  33. short vs long shifter
  34. Jetta '89 random power loss
  35. i need diagram for a jetta 87 hose vacum sistem
  36. 88 Jetta not getting fuel
  37. 88 Jetta not getting fuel
  38. wipers don't work
  39. timing gear cover
  40. 87jettawork
  41. 89 jetta rpms drop
  42. Jetta just turns off O.o
  43. 1986 VW Jetta GL 5 speed, Starts then Stalls
  44. Leaky dipstick
  45. Help! 85 Vw Jetta!
  46. 86 diesel jetta The car runs strong, but has an idle problem ( ok if the glo-plug is
  47. slight problem
  48. 90 Fuel pump gone bad
  49. replacing the clutch
  50. 86 jetta reverse problem and more
  51. Pimp my Jetta?!
  52. My stupid blinkers.....
  53. '88 Jetta Slalom
  54. Over-heating Engine
  55. 1990 Jetta losing power
  56. jetta diagram
  57. 88 jetta, overheating
  58. body kit questions
  59. 83 Jetta Alternator problem!!
  60. dashboard removal
  61. outside door handle question
  62. help! Shift linkage
  63. 85 VW JEtta Turbo Diesel For sale
  64. Water Pump???
  65. Brother got an 87 Wolfsburg Jetta...trouble starting
  66. I need help
  67. 87 Jetta Won't Start
  68. 1986 Jetta Very High Idle
  69. Confused and frustrated with my 85 Jetta
  70. 1990 Jetta 4000 rpms at 70 mph
  71. starting problems
  72. air conditioning
  73. i need help with my 90 jetta
  74. Help Identifying Part, Please
  75. 1990 jetta issue
  76. 85 jetta wont idle
  77. 85 turbocharged jetta won't run
  78. 1989 vw jetta not turning over
  79. 1985 jetta fuel problem
  80. 88 GLI possible engine lock
  81. timing belt change intervals
  82. Maybe a unique problem:
  83. Horn Goes Off on My 88 VW Jetta GLI
  84. Can I swap an 87 trans to a 89 engine????
  85. Seats for '89 Jetta?
  86. 90 Jetta blows oil out the dipstick tube
  87. 89 jetta huge problem ?
  88. 88 Jetta parts
  89. 1990 jetta won't start
  90. 87 Jetta interior door panel needs to come off
  91. computer wiring for sandrail
  92. tune up parts for sale
  93. Help Radio won't work
  94. Burning oil
  95. 90 Jetta GLI Idle?
  96. I Need Help
  97. diesel
  98. cannot select right gears on my '88 Jetta
  99. 1990 Jetta 1.8 Ltr. Overheating in Rain
  100. Parts for sale, MK2 - g60/8v
  101. Alternator Pulley Alignment
  102. 1986 VW gli wont turnover
  103. '89 Jetta manual transmission problem
  104. Rear door stuck/locked shut
  105. want a mk2
  106. 85 jetta won't start
  107. 1986 jetta problem need help!!!!
  108. Engine Swap
  109. '85 Diesel Jetta with White smoke
  110. 1987 Jetta cranks but won't start
  111. Jetta Brake Problems
  112. 86 jetta gli O2 sensor light
  113. 1987 jetta gl steering wheel movement
  114. supposed oil pressure problem
  115. 1987 jetta gl speedometer / odometer not working
  116. Help! My new (old) Jetta died!
  117. oil pressure sending unit....
  118. 1983 jetta 1.6l tdi blinker hazard reverse light prob
  119. 86 GL bucks and kicks
  120. 89 Jetta idling at 3000rpm
  121. what seats fit????
  122. 86 jetta GL turbo diesel, timing belt/oil pump?
  123. 86 jetta door panel
  124. oil spewing out and lots of smoke
  125. 86 jetta gli "dying"
  126. missing piece 1984 jetta
  127. fuel problems with a 89 jetta
  128. 90 1.8 L Gl
  129. chugging, stalling and clicking, please help!
  130. '85 jetta running VERY rough!!
  131. 89 Jetta noisy when changing gears
  132. My Car Won't Startup without a Jump
  133. Fuel Problem
  134. fuel distribuitor question
  135. Jetta Engine Codes
  136. 89 gli wont start sometimes
  137. seat belt lock-out
  138. Diesel Or Turbo Diesel?
  139. 88 jetta, no reverse, all else works fine
  140. trunk leaks
  141. Help! 1989 Jetta won't start!
  142. 85 Jetta modifying
  143. starter interchangeable??
  144. What colour should we paint our '86 Jettas?
  145. 87 Jetta Electrical problem
  146. 85 Diesel Jetta wont start all of sudden in cold
  147. 89 diesel hard starting
  148. 1990 Jetta sqeaky belt problem.. HELP!!
  149. 86 Jetta Carat Defrost Problem
  150. Technical questions, troubleshooting etc.
  151. Parting 90 JETTA!!!!!!
  152. 85 Jetta Diesel Starting Problem (Electrical?)
  153. 1988 Gli 16v
  154. Timing specs on 1990 Jetta, help!
  155. 90 Jetta doesn't like the rain
  156. 89 Jetta GLI Question
  157. 1989 Jetta Diagnostic Codes?
  158. My 89 2 Door Jetta
  159. Clutch problems 87 Jetta
  160. 1988 Jetta
  161. 1988 Jetta Door Hinge
  162. front spoiler for 85 jetta
  163. 88 VW Jetta GLI - starting problems
  164. grill conversions for an 85 jetta
  165. 88 Jetta GL for sale.
  166. 90 jetta dying when i press on clutch!
  167. 90 jetta gli intermittent problem
  168. 90 Jetta intermittent problem
  169. Want to Rebuild Seats in 89 Jetta
  170. 86 Jetta engine temp problem
  171. Running problem with 89 GLI
  172. 1987 VW Jetta GLI
  173. 86 Diesel Jetta Fuel Pump Location
  174. 86 turbo diesel wont start
  175. '89 Jetta
  176. 1988 Jetta fuel pump noise ,stalling
  177. 1989 5 sp trans fluid change question
  178. NEED 84 jetta gti front stock springs
  179. 84 Porsche 911 firing problem
  180. where do i get a chip for a 1985 jetta
  181. Help!!! 87 Jetta Starting Problems
  182. 90 VW Jetta Power windows
  183. need 1986 GTi Cylinder Head
  184. 1988 Jetta no spark
  185. Silver 88 VW Convertible For Sale
  186. Is a 88 Jetta worth modifying?
  187. 1990 jetta wont run
  188. 90 Jetta low oil light/buzzer
  189. 1988 Jetta - Leaking windows
  190. 90 Jetta 1.8L rough idle
  191. My '90 cranks but won't start
  192. wut to do for mass hp for a 1985 jetta with 100hp
  193. 88 jetta no fuel
  194. 1989 Jetta running problems
  195. love my car. 85 jetta, needs work, have some questions
  196. 88 Vw jetta with manual window problems
  197. 1990 jetta radio problem
  198. 1988 Jetta cold start
  199. 88 jetta engine rattle
  200. 1990 Jetta mysterious rattle
  201. vr6 into 89 jetta
  202. 1990 jetta overheating
  203. 1987 Jetta low speed hesitation and bucking
  204. 1989 Jetta - Reading Engine Codes
  205. 87 jetta gl fuel dis
  206. 85 Turbo Diesel starting problems
  207. high revs out of 88 1.8L
  208. 89 Jetta Parts and Accessories
  209. 1990 Jetta axle noise problem.. please help.
  210. 89 Jetta Woflsburg - Starting Trouble
  211. 86 jetta bucks like a wild horse then dies!!!
  212. 89 Jetta jerks & misses -air flow sensor?
  213. 90 Jetta engine
  214. # of 86 Jetta GL Fuel Pumps
  215. 86 Jetta GL - Fuel Pump Relay Purpose?
  216. Fuel Pump Relay 'crackling', 88' GLI 16v
  217. 87 jetta loping idle in drive
  218. 89 diesel pressurizing coolant resevoir
  219. 85 jetta dying
  220. 85 Jetta pings
  221. Help deciding clutch for 88 GLi
  222. 1990 Jetta I just bought.
  223. 84 Jetta GLi dash wiring
  224. 1987 Jetta Radiator Fan Runs
  225. 84 Gli
  226. My 86' Jetta Wont Start. It will turn over but wont catch.
  227. 90 jetta stalling when clutch is in
  228. 84 jetta
  229. 89 jetta Prob.
  230. vr6 engine swap for '87 GLI 16v...possible?
  231. 1989 wolfsburg editon jetta 1.8t
