View Full Version : Jetta/Vento/Bora
- No Heat
- Jetta TDI in cold weather
- VW ( jetta) cruise in new jersey!
- 1997 VW Jetta won't start
- 96 vw jetta windshield wiper transmission case
- 2001 gls battery drain
- Help! No power to tail lights or tail light fuses
- Oil change
- v-dub caln name ideas?
- Headlights
- Will my speakers fit??
- 2011 Jettas
- We beaners got a Special Edition Jetta ;)
- Is the vw passat 1.9 tdi radiator made of plastic?
- Spec breakdown of jetta models
- Der Meister Inc 2508 West Tennessee Street
- are jetta's really that bad?
- O2A vr6 Trans
- Aftermarket Seat in Jetta
- temperature gauge jetta 2002
- sporatic ignition timing
- VW Trouble code P0391
- 98 Jetta - Major Issues!
- 2002 vw jetta starts decellerating
- 2000 jetta
- 2010 Jetta S w/o MFD - changing mph to kph
- 25psi boosted VW Jetta with pix and video!
- New Owner of a 2009 Jetta TDI Diesel
- need help with daily driver a 05 tdi
- a GREAT car modification site!
- Removing the heater core/expansion valve/dryer from an MK2 - 96 Jetta GL
- Grooves on Only One Brake Rotor
- 98 Jetta TDI Alarm beep
- air intake question
- vw jetta TDi block heater
- 91 jetta abnormal spark issue wont start
- 2000 Jetta car alarm
- Jetta Released in India
- 2006 Jetta: rough idle/vibration, code P0343
- 2000 Jetta intermittent starting problem
- 1998 Jetta wondering question
- High Brake light
- Break issues
- Sound in Low Gear
- 95 jetta wont start
- VW Bora ECM power relay location
- Jetta P0501 Speed Sensor
- 96 jetta front wheel hub removal
- 96 Jetta P0715 code
- Error codes for a Jetta 2006
- Jetta and the Bluetec Engine
- What do you folks think about this? (CL ad)
- Day 3 the saga continues no start
- Day 3 The Saga Continues No Start
- 98 Jetta NOTHING HAPPING
- 2000 Jetta immobilizer??
- Noises when cooling
- LCD screen fades to black
- 88 jetta pouring fuel into cylinders
- 2003 1.8T clicking when coasting
- 95 Jetta III fire problem "HELP"
- 90 jetta
- Help!! Poor Jetta!!! plase!!
- Need Trans Control Module match for CLK transmission
- Jetta Starter Cranks but won't start
- 1992 Jetta 1.8 Not starting
- VW Diesel Veggie oil Burner
- 86 turbo diesel head problem
- Solid oil
- cold air intake
- Help!!!!
- Volkswagon vin decoder
- weird idle problem
- 97 Jetta Caliper Mounting
- 2000 Jetta - P0446
- 87 jetta oil leak
- 2003 Volkswagen 03' Jetta 24V VR6 1/4 mile stock???
- 2002 jetta radiator removal
- 94 jetta oil pressure problems
- code 0422
- 02 Jetta TDI Engine Swap
- 1996 Jetta 5 speed Driver side Door Lock
- 2002 Jetta Headlamp Bulb Dimming Mysteriously
- Won't Start
- Factory Alarm Killing Engine/bypass options?
- Break Pad Wear Indicator
- 99 Jetta Wolfsburg For Sale
- FOR SALE: Black/Black 94 Jetta GLX -NNJ, For Parts
- Marker plate bracket
- 99 Jetta OBD2 reader location
- 1996 tansmission filter
- Jetta 98 - stalling when wet
- 96 Jetta Gl 2.0 ltr stalling at stops
- Car alarm Bypass
- 2002 Jetta Wagon rear shock replacement
- struts vs. shocks?
- Improving my '98 Jetta GL
- Replacing 1999 Jetta speakers
- 2.0 Jetta Timing Belt?? Cam Position Sensor code.. And car wont start!! Help!!
- 96 Jetta 2.0L GL WONT STARt. Has Spark Has Fuel Pressure. Just died while idling.
- 6spped transmission
- wipers
- '94 jetta gls III wont run
- Rough Cold Start Idle. O2 Sensor ????
- 97 jetta alarm not arming
- 98 Jetta barke lights stuck
- Trans speed sensor 99 jetta
- Power Steering Leak
- 96 jetta
- Any good mechanics?
- FOR SALE 2002 Jetta 1.8t GLS
- 05 jetta handling
- Power Window Question, 98 Jetta GLS 2.0
- 97 jetta gt e-brake cable replacement.
- Very tall guy needs to modify his Jetta to fit him
- Faulty MLI?
- Unitronic TDi, Oh yeah
- Jetta won't idle
- 2000 Jetta Airbag Light...
- 01 Jetta GL MAF problem
- 2001 jetta 2.0 codes and hard starting
- Window/Lock Buttons haywire
- 01 Jetta check engine PLEASE HELP
- three ways to help you to autowindow via keyfob, which one is the best?
- 2000 Jetta GL 2.0L AEG not starting
- Check Engine Light
- 97 jetta MAF test
- vento 1995, drivers window (manual) jammed shut
- Hood latch black plastic thingy broke off...how to open up hood now????
- keyless control the windows for bora/golf mk4
- TWO OBD codes (P0411 & P0139)
- how to auto windows like this?
- Dear Volkswagen Jetta Owner
- 1999 1/2 Jetta TDI Air Cond question
- 96 jetta fans not on
- Fuel for Jetta 1.8T
- From auto to manual!
- shakes in reverse
- Quick CD player question - Monsoon
- 1994 antifreeze leak
- Future purchase
- seconday air injection pump
- new to this
- 1999 Jetta 2.0 4-cyl: Poor power and acceleration, is this car a lemon?
- Oil Talk - 2002 Jetta......Need Advice!
- '92 Jetta stalls at idle
- In need of advice/troubleshooting
- Vw Vento Cutting Out
- Jetta 1.8T: Shaking in steering wheel at highway speeds
- 00 jetta 2.0 auto trannies & gas mileage
- vr6
- Need Help
- Windshield Wiper Problem (96-Jetta-GL)
- VW Jetta VR6 for sale
- 2000 Jetta Front Wheel Bearing
- Won't Start
- Looking for spoiler
- How to replace front turn and back brake lights for 99 Jetta? Help...
- Jetta 2002 GLS 1.8 liter
- Need your honest opinions
- no tail lights
- 96 jetta P0304 code
- 2001 Jetta Sensor Problems?
- Radio Dead
- Removing Vr6 Tranny
- Need help with a quick survey, just one question
- Code p0501
- 1.8 liter flooding ????
- Weird Electrical problem with brake/signal lights
- 2002 Jetta Blower Motor Out
- Transmission For Sale
- Jetta 00-04 HELP please!!
- Purchasing a Jetta
- You Jetta Start Properly!!
- 2002 1.8t handling
- Rear Doors won't open from outside
- V.W. Jetta Anti Theft Problem
- 1991 Jetta Diesel Alternator
- Anybody have a Blue '02 Jetta/Golf VR6 GLI They Want to Sell?!
- Best Jetta 4 Making HP and TQ ?
- 2000 tdi shaking
- Dropping the clutch
- Inken Cold Air Intake for Sale for 1.8t
- 95 Jetta no cooling fan
- Gli 18" rim swap
- Jetta must go!!!!!!
- 96 Jetta forale(detials and pics inside)
- Fuel Injector Problem? Car Won't Start.
- Wolfsbourg for sale!
- blown head gasket
- need help with the new ride
- 1990 Gl hesitation
- tough decision...
- Bad Fuel consumption
- changing therm. control back light
- Seat belt chime/alarm diconnect
- Rattling noise?
- A.N.S.A silverline
- Engin light
- How Do I get the fault codes out of my Jetta
- 01 Jetta Shift Cover/Temp. Control Light
- torontovolkswagens.com > New site/forum
- Anything to look for when buying a 2002 Jetta GLS Wagon?
- 2001 Wolfsbourg for sale
- Peeling by the window controls
- jetta tie rod or wheel bearing trouble?
- 02 jetta turbo troubles
- oil alarm deactivation please!!!!
- Instument Cluster Removal
- 1999 Jetta (old body) P0506 Fault code
- 1997 Jetta speedometer problem
- loud humming noise
- Milage and Maintainace Q's on Jetta Diesels
- installing air filter
- Locking Fuel Cap Blowing Fuses
- Few pics i just took
- P0506 Fault Code 1999 MK3 Jetta Help!!!!!!
- After Market Alarm install in a 1999 Jetta Help
- where can i find 2005 or 2006 bora spec
- 2001 VW BORA Wire diagram
- Revving high losing power..etc..
- cooling system in VW Jetta 95 4 cyl not working
- 2001 jetta tdi
- `97 Jetta, coolant in the overflow looks like butter
- this is a weird one!! 91 jetta......
- 96 jetta automatic transmission slip
- Just replaced '96 CLK tranny, leaking lots of fluid!!!!!
- Jetta Help..
- 2000 Jetta - A/C Low Pressure Valve
- Fuel Pump For Sale- Its Never Been Opened
- 90 Jetta
- electical short or what?
- looking for gear heads near akron ohio
- 97 jetta iac location
- Purchasing a used 01 Jetta...
- Brake Problems-New Brakes and Rotors
- Aftermarket Navigation System
- 1986 Vw Jetta Gli 1.8 (((overheating!!!)))
- Some is really wrong with my car (97'Jetta GT)
- DRL's
- Melted Crayon smell in TDi
- 98 Jetta stalling problem
- Jetta VW wheel cover: anyone know where I can find one?
- brake and reverse lights
- Diesel Jetta fuel filter
- 2001 jetta stalls
- 98 Wolf: Sloshing Water, Drips onto Pass. Floor
- Who would win?
- 97 jetta 2.0
- 96 jetta GL
Automotive Network, Inc., Copyright ©2012
