View Full Version : Integra
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. Searching for first car... I'm interested in a gsr in my area... Have some questions.
  2. For the love of God help me!
  3. abs light
  4. Integra Reliabilty
  5. engine swap
  6. Need help
  7. A/C compressor replacement help
  8. Windshield & Window Rattling
  9. Couple Questions
  10. swap question
  11. 91 w/ AT wont shift properly
  12. cruise control
  13. distrubitor
  14. 97 integra wiring
  15. Cheap place to buy an CAI?
  16. 1999 acura integra
  17. Just bought a 93 da with b20 block b16 head - have some problems!!
  18. Integra Sucks anti-freeze.
  19. 2000 integra - what to do?????????????
  20. Car does not like the heat?
  21. need a tip
  22. Peformance meter and OBDII diagnostic gauge.
  23. need better fuel economy for 89 teg
  24. Acura integra gsr models
  25. Helllp
  26. just sold my turbo eclipse, now going back to acura
  27. Project DA6 Photo Update.
  28. Major Problem
  29. Just got 92 integra and have a tranny ??
  30. Better Head?
  31. wierd problem
  32. new 2 this car but loves it
  33. 89 Integra engine puttering.
  34. Boosting a 98 Ls Integra
  35. questions help plz
  36. so many heads to choose from
  37. What alternator for my swap
  38. Do you smoke, and have window regulator issues?
  39. 2nd G1 Integra California Meet
  40. question about fuel injectors!
  41. jdm halo headlight wiring please help
  42. Help with door
  43. 86-89
  44. modifications
  45. 90 distributor differences at/mt
  46. Please Help Me!
  47. moroso valve cover
  48. "New-To-Me" 93 Integra, A couple Q's
  49. Tough problem here!
  50. Help!
  51. b18 motor problem, HELP!
  52. front end conversion
  53. b16a on my integra?
  54. OBD what?
  55. ls-vtec purchase possibility
  56. Brake Goes Soft while pressing it
  57. f20b in my 96 integra
  58. Integra = Good Daily Driver?
  59. buying integra
  60. Wires are Fun, Fun, Fun
  61. looking at a 91
  62. 91 Integra Auto Tranny Help
  63. 05 integra idle goes up and down alot while warming up
  64. Clutch pedal softens over night???
  65. Why is this so cheap?
  66. Open hood without release cable????
  67. Please Help
  68. Please Help
  69. Please Help
  70. i need an opinion
  71. integra question
  72. Acura LS mesh rims????
  73. do you know how to pull a front axel hub from an integra?
  74. high ideal
  75. Type R (ITR) rear calipers listed on Ebay
  76. Bench bleeding new master cylinder
  77. RPM questions for Integra
  78. 91 Teg. Will a performance header from a B18 fit on a B16?
  79. Temp gauge stays all way to right, even when off, when cold
  80. B18A1 vs. B18B1 vs. B18C1
  81. ball joint poped out while driving. no grease
  82. Click...click...no Crank???
  83. Teg Radiator ???
  84. Multiple electrical problems
  85. all motor or NOS
  86. what factory radios will fit an 1989 Integra
  87. 91 acura intregra with b16a swap
  88. My center electrode tip broke off
  89. true power pulleys
  90. Cigarette lighter socket
  91. Why
  92. acura integ keeps dyin help?
  93. Petrol Tank
  94. Mysterious water leak into interior
  95. spark
  96. right way to remove power stearing and A/C?
  97. 96 teg rs ... RADIO ????
  98. 92 gsr b17a1
  99. Project DA6.
  100. Looking to buy...
  101. center console question
  102. Smoked Speedo Head!
  103. help skunk2 intake manifold carb eo number
  104. Ls/vtec on 92 teg???
  105. SRS light on 95 integra ls obd1 ecu
  106. ls/vtec
  107. Going abroad
  108. Type R tranny or a b 16 tranny
  109. 90-93 teg spoiler questions
  110. Dash lights HELP!
  111. Oil leak at head
  112. Size of bolt for extracting brake rotors
  113. air conditioning belt installation??? how to tighten belt?
  114. integra brakes making noise brand new brakes
  115. Just bought a 91 Teg w\Xsi Swap.
  116. Window Tint
  117. replacing my power window controller i cant get it off
  118. Deal? Or not?
  119. WTK: ITR MT tranny in a teg
  120. 94 gsr acting up
  121. How do i make my gsr vtec hit hard?HELP me
  122. ZC/D16A8 running too rich
  123. Power Sear Belt Problem
  124. How can i tell if i have a integra gsr and so on
  125. SIR Cams
  126. No Spark
  127. help with seat belt
  128. Obd2
  129. 2001 Acura Integra?
  130. ls tuboor or gsr with mods?
  131. Antena
  132. polishing the heads
  133. turboing question
  134. Looking for attainable HP/TQ numbers on a b18c1 motor.
  135. looking for new engine
  136. 8 puck stage 3 clutch?
  137. 91 teg runs rough when hot
  138. 1989 Integra - Motor runs after turning
  139. difference between 1st and 2nd gen tegs
  140. HELP! my studs broke off the hub, and i can't pound them out!
  141. could someone help me with a carfax report
  142. ABS light on
  143. Engine + JRSC
  144. High Flow Cat for 95 GSR
  145. where can i get parts for my 88 teg????
  146. gauges just quit
  147. Integra GSR +98
  148. is this arm rest rare?
  149. R cams on GSR
  150. Gears Sticking?
  151. starter cranks slow at first
  152. 93 Integra possible clutch/trans problem
  153. To part or not to part.
  154. ecu code 15 ignition output signal
  155. need help, 94 ls integra
  156. All Clear Integra Taillights!!
  157. Battery light Help please
  158. spring
  159. 92 shuts off when it warm up
  160. NSX sidevents on an Integra?
  161. suspension help
  162. Another ls/vtec ?
  163. Zc ???
  164. Subframe
  165. Integra or Civic
  166. rim bolt patter???????
  167. 96 ls or 99 gs
  168. GSR fuel rail
  169. Gsr CrankShaft
  170. Looking to Buy Integra
  171. Looking to Buy Integra
  172. Looking to Buy Integra
  173. Cylinder Hear ID Code #'s
  174. Valve cover differences?
  175. Pacesetter Header w/ Ceramic Coating!
  176. DA headlights :(
  177. turbo integra!
  178. 96 ls low 15 1/4
  179. 96 integra LS DIY?
  180. 91 Acura LS Wiper, Cruise and Defog problems
  181. Freon issues
  182. b18 to b20
  183. Acura Integra Distributor
  184. Gsr Headers
  185. Spark Pulg Gap For 94 Acura Ls
  186. 90 Integra
  187. Acura Integra B18B1 wont start
  188. help please!! my moonroof of my 1996 integra
  189. ZX motor swap
  190. Tune Up
  191. Steering wheel horn
  192. have to wait 5 min to start???
  193. Skunk 2
  194. Setup For Road Racing?
  195. Help! - Loss of power off line
  196. 92 gs tail/dash light
  197. 95 gsr
  198. ls/vtec best head?
  199. b18a vtec conversion?
  200. Adding gauges to A-Pillar help
  201. Please help - 91 teg won't start :(
  202. e-turbo??
  203. Rear Wide Body Fenders . . . (4PIX)
  204. Medium gray leather color name
  205. broken cruise control on 93...
  206. body parts
  207. Ls/Vtec. Posible or not????
  208. integra faq?
  209. Srs?
  210. 1992 teg won't start help please
  211. starting problem 1992 acura integra
  212. 97 integra ls
  213. 90' integra ls
  214. Please Help Me
  215. cam gear
  216. 90 Integra engine problem!!!!!
  217. No Dash Lights
  218. 1993 Acura Integra Transmission Overheated?
  219. turbo kit on ebay
  220. S15 Conversion Questions
  221. motor options
  222. 2000 Integra making noises at high RPMs
  223. Type R Spoiler
  224. street legal mufflers
  225. 92 integra gs window question
  226. No replacement for displacement
  227. no ignition spark
  228. '92 Integra 140K, 2600$ Should I ???
  229. Questions about a 93 Teg
  230. Water getting in under trunk. Help please!!!
  231. 93 integra wont start
  232. Couple simple questions need simple answers
  233. nitrous
  234. Fast Idle Thermo Valve
  235. Heat shield
  236. Greddy sp2 or skunk 2
  237. you guys think this suspension set-up would work?
  238. Just a quick question.
  239. Rubbing Tires
  240. Automatic transmission dipstick -- FOUND!
  241. Big plans for DA
  242. DA exhaust
  243. Rubber Flap?
  244. Electrical prob
  245. Starter???
  246. radiator
  247. clutch break in period???
  248. timing belt
  249. Water Dripping In Car
  250. Help please 91 integra wont start
