View Full Version : Malibu
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12
  1. cv joints
  2. Do all malibus have rear tire wear problems?
  3. 98 malibu wont get out of park
  4. gas meter gauge problem
  5. Sudden Overflow from the coolant reservoir
  6. heater blower
  7. Wiring code for 99 Chevy Malibu?
  8. Add transmission fluid 03 malibu
  9. Key & Remote Locking & Unlocking Problem
  10. How to replace drivers side power mirror on 2004 Classic/Malibu
  11. 2004 Malibu Trunk Release
  12. 98 Malibu 3.1...Difficulty finding source of noise
  13. '05 Malibu seat belt warning light
  14. 05 ecotec
  15. 97 Malibu V6 3.1L Cruise Control Not Working
  16. 97 Malibu V6 3.1L Audio Receiver Replacement
  17. 97 Malibu V6 3.1L Remote Keyless Entry
  18. 1996 malibu,wont go into overdrive
  19. What temp do fans turn on? Don't think mine work
  20. 2004 Chevy Classic ECOTEC where are spark plugs?
  21. 2004 Classic ecotec where are spark plugs?
  22. programming 04 malibu key fob
  23. 97 Malibu V6 3.1L Belt Noise
  24. 97 Malibu V6 3.1L Fuel Milage and Acceleration Become Poor
  25. Bolt Torque
  26. 97 Malibu V6 3.1L ABS Light Always On
  27. 98 malibu won't crank
  28. Brake lights arent going on....
  29. 97 Malibu V6 3.1L Noisy when speed up
  30. 98 malibu 3.1 p0341 cam sensor code
  31. 98 malibu wont crank
  32. 98 Chevy Malibu
  33. 99 Malibu - Intake Manifold Gasket
  34. Fuel Pump
  35. The dreaded P0410 code
  36. Check engine light
  37. bong- bong chime but no lights or indication
  38. Can I put a 05 malibu eng in an 03?
  39. 02 Malibu losing coolant
  40. 98 Malibu Keyless Entry Programming
  41. Wanted manual for 2006 Chevrolet Malibu Maxx
  42. Check Engine Light
  43. Replaced Fuel Filter, now won't start
  44. can you figure this out?
  45. engine
  46. gas meter gauge problem
  47. Owner's Manuals - PDF versions
  48. '99 Malibu - low coolant
  49. A/C seals?
  50. 2003 Malibu stalled and won't restart
  51. MIL light threw a P0410 code.
  52. 4cyl or the 6cyl Malibu-What's your opinion?
  53. After market Caliper bolts..1999malibou
  54. Is there a better Evap Diagram? 98 3.1L
  55. what order do the front three spark plugs wire 1997 Malibu
  56. 2005 Malibu radio resets by itself
  57. Is this caused by a faulty fuel cap?
  58. #3 cyl misfire
  59. 98 Malibu operating temp on gauge
  60. headgasket coolant leak
  61. under dash lights
  62. Proper Scanner-freeze Data For Po44o Code
  63. Gas Cap blows off
  64. Adjusting headlights
  65. 05 Malibu heater blows cold air
  66. catalytic converter/hesitation
  67. Timing chain tensioner installation
  68. Tire reccomendation Malibu Maxx
  69. Running Amp wire
  70. where is the ac recharge
  71. replacing a/c control
  72. radiaotor overheating/watering coming through cap
  73. Cruise control '03 malibu won't engage
  74. machine rotors
  75. Finding 03 Malibu 3.1L Power Programmer?
  76. issue with malibu horn system and coolent
  77. tie rod end
  78. 2003 Malibu Governor HELP!
  79. misfire cyl. 1
  80. 2002 Malibu: A/C, Gauges, Criuse, Radio
  81. 2004 Chevy Malibu Maxx Broken Power Seat
  82. Car turning off while driving
  83. 1997 Malibu overheating radiator
  84. Hard start when cold, fine after that
  85. ABS light
  86. 1997 Malibu left tail-lights wont work
  87. electrical problem on 03 malibu
  88. 05 Power Steering Loss
  89. Fuel Economy mods.
  90. Heater Problem
  91. 2002 malibu power window won't close
  92. Changing A Starter on a 1997 Malibu
  93. Lower Control Arm Replacement
  94. Oil Pn Removal - 1998 Malibu
  95. 1999 Malibu fuel gauge and A/C trouble
  96. adjusting brake light switch
  97. 2005 Malibu Radio and RDS?
  98. 99 Malibu - ctr brake light works, other 2 don't
  99. Front brake pads
  100. Engine Swap
  101. 2005 "classic"
  102. upper engine noise under load
  103. fuil filter
  104. junk fuel level sensor
  105. Malibu 2003 heating problem
  106. 2000 malibu weird smell when changing temp
  107. brakes seizing?
  108. Remote Starter & PassLock II issues
  109. wind noise
  110. 2008 Malibu tire pressure.
  111. transmission fluid level
  112. '05 Malibu Electrical Issue(s)
  113. abs light and stutter at high speeds
  114. 2003 Malibu...does it have alarm? How to arm/disarm?
  115. 99 Malibu spits & sputters & dies
  116. 2004 malibu fuel and temp guage problems
  117. How change steering rack&pinion?
  118. 1997 Malibu Won't start
  119. 2006 Chevrolet Malibu LT
  120. Need help with sensor problem in 1999 chevy malibu
  121. funny noises
  122. Transmission fluid all over the place....
  123. 1997 Malibu over-heating and oil-water coming out of the tail pipe, now wont start
  124. Rough start
  125. 2006 Chevy Malibu, Bad Alternator within first two years
  126. Re: A/C Compressor
  127. Need Help With My Car
  128. need help on reseting theft system on my 03 Malibu
  129. 2001 malibu problems
  130. Reuse lower intake gasket?
  131. Head gasket, Which way up??
  132. 2003 Malibu Won't Start
  133. 2006 malibu bulbs and autoshift
  134. can't open rear door
  135. 3100 Upper plenum doent sit flat on lower
  136. just installed new rear pads and rotors
  137. Malibu Brake Pedal
  138. no spark
  139. Wheel cover rattles 2005 Malibu
  140. 99 Malibu radio display PCB
  141. 2000 Malibu left tail light problems
  142. theft light on when driving
  143. theft light on when driving
  144. power steering...!
  145. 98 Malibu Rough Idle
  146. malibu 05 keyfob to unlock doors not working, locking does
  147. replacement keyless entry remotes!
  148. Unhook the Antenna in a 06 Malibu Maxx
  149. Unhook the Antenna in a 06 Malibu Maxx
  150. help me out!!!
  151. Help 97 Malibu Is Overheating After New Thermostat
  152. 2003 Malibu hub nut spec
  153. 2003 Malibu Air Condition
  154. How to stop the CAR to start?
  155. 05 Malibu Classic performance
  156. 2000 Malibu fuel gauge & temp gauge inop since lightning strike
  157. '99 Malibu Sputtering & AC Issues
  158. Malibu Maxx 04 XM Radio stopped
  159. Replaced Intake Gasket, Now experincing High Revs
  160. 02 malibu
  161. 98 Malibu 3.1 Howl or Whine noise from rear?
  162. '99 Malibu 3.1 code 0442
  163. Body Control Module (bcm)
  164. Miles per tank & MPG on 99 Malibu
  165. Ignition Cylinder
  166. cabin filter
  167. Malibu High Idle Problem
  168. Check Engine Light
  169. won't start without giving it gas
  170. 2000 malibu brake problems..need help asap...thanks
  171. '99 Malibu fuel filter replacement.....how?
  172. 02 Mailibu Parking Brake Adjust.
  173. need info on Dex-Cool
  174. Tick-tick-tick noise only while driving
  175. aftermarket head and taillights
  176. 2006 Chevy Malibu Stereo - Theftlock Enabled
  177. noise from wheel or front end
  178. Electrical????
  179. 04 Malibu Classic - Front end click/creak/rattle
  180. 2005 Malibu Max Break Lights and Rear Turn Signals Out
  181. 2003 Malibu abs light
  182. 2006 MALIBU FAULTY SES/GAS gauge
  183. won't start
  184. Won't start sometimes after warm
  185. Rear Parking Brake Cable Equalizer Bracket
  186. New Malibu,new scratch!
  187. coolant coming out of over fill tube
  188. Rear driver side power window problems on 97 Malibu
  189. ignition cylinder
  190. Help Identifying This Part With Picure
  191. 2000 Malibu LS Cruise Control Kicks Off
  192. 1997 and 1998 alloy wheels
  193. 2001 Chevy Malibu
  194. AC compressor is not kicking on
  195. 3.1 Litre Oil Pump Shaft O-ring
  196. Bad BCM?
  197. Heater won't work and power windows don't work at time
  198. 00 Malibu Starts then shuts off
  199. Programming Key Fob for 2000 Malibu...Is it possible to do yourself?
  200. 2005 Chevy malibu Shifting issues
  201. 04 malibu maxx steering lock
  202. 2004 Malibu LS remote entry FOB
  203. Are they trying to get me?
  204. Turning Signal Problem
  205. Installing New OEM Factory Radio in 2006 Malibu
  206. Installing Aftermarket Radio?
  207. Installing Aftermarket Radio?
  208. 2002 malibu ac fan speeds
  209. 2001 Malibu Rear Speakers Problem
  210. 05 malibu oil not getting to top of engine
  211. 2001 Malibu Power loss
  212. 1999 Malibu w/ non serviceable transmission
  213. rubbing brakes
  214. Steering and brake noises
  215. 2002 malibu Transmission problem
  216. Job Finished! But not without side effects
  217. Brake Job Problems
  218. 03 malibu 3.1
  219. which repair manual is better?
  220. 2004 Chevrolet Malibu Trunk Release Button
  221. mp3 player
  222. 05 Malibu Maxx Rear bulb replacement
  223. Transmission
  224. When taking off the intake manifold
  225. Need Programming Instructions for 2005 Keyfob Remote
  226. LIM repair, Gasket Warning
  227. 07 malibu maxx 28000 miles SES light
  228. Front end noises
  229. Fuel Filter location on 2004 Malibu Classic
  230. low beams dont work hi beams do
  231. 2002 malibu headlight replacement
  232. 1999 Malibu too many unset (not read) readiness codes(OBDII) inspection failed help ?
  233. 2000 malibu engine light
  234. 2000 Malibu transmission sensors
  235. 2005 malibu battery issue?
  236. 99 Malibu Help????
  237. shaking
  238. key switch removal
  239. What is this warning light!!??
  240. Malibu Problems
  241. Keyless entry not available?
  242. 99 malibu overhting via res tube--how much air to bleed?!
  243. Weird brake lamps problem
  244. Driver door labels missing?
  245. Need help removing KARR system
  246. 97 malibu keyless entry
  247. 2000 Malibu- three problems
  248. 2004 Malibu turn signal intermittent
  249. Abs sinsor needs replaced plz help asap
  250. Oil or Transmission Fluid in Coolant?
