Subaru
> Legacy / Liberty / Baja
View Full Version :
Pages :
1
2
3
4
Trans fluid
Legacy/WRX transmission swap?
91 Legacy, Flashing power light after starting car
Aftermarket Rims
wheel hop?
help! car is ticking when you turn only
92 legacy parts?
lights, lights, lights
91 legacy
Overfilled Trans
92 Idle problems
The old check engine light ?
1990 Legacy LS needs your help PLEASE
1998 legacy changing fron seal ???Please Help
Subaru Advice Please
93 Legacy L Engine wont start in the cold
Quick Question
2 wheel drive
AWD Solenoid problem
Resetting keyless entry
Any info would be great
Brake Free Play Adjustment
93 legacy, suspect fuel system problem
seat hearters in 97 legacy wagon
Anyone know about wiring a CD player to my 1995 legacy?
Cam Position Sensor help
2001 Subaru Legacy alternator replacement
95 legacy wagon help needed!
90 legacy sedan stock looking for upgrades
97' Legacy GT Replaced USDM with JDM EJ25
what to do with Mom's clunker
Swapping STi parts into 92 Legacy
1990 Legacy GT Engine Issues
Lights flashing after new battery installed.
Engine Surges in cold weather
Little Black Button
what parts arecompatable between the EJ22 and the EJ25?
Subaru Legacy Wagon '94
1991 awd legacy turbo kit?
Quality mechanic search?
'96 Outback Shocks
2006 Subaru 2.5 GT spec.B
99 Legacy wagon stereo upgrade
96 wagon noise in rear cargo
NZ Insurance Questions...
1991 Subaru Legacy engine light stays on
Need some parts
The new girl nextdoor w/ a subaru baja
reverse lights
93 legacy water pump question.
Electrical System
95 Legacy stuck in park won't start
Ocassional Starting Problem
Interior Lights
Elctrical problem
'90 Legacy Timing Belt trouble
Help!
during hard acceleration engine light come on
Transmission Not Enagaging - Intermittant
1991 engine stalling - any ideas?
can ya help a girl out?
mirror replacement
90-93 legacy auto to 5spd swap ?'s
Oil leak / burning
occasional kiss firing in #4 cylinder
NON-CIRCULATING RADIATOR blowing cold air
High Idle
Need 1997 Legacy Engine
91 legacy tranny
electrical problem?
Legacy power windows
92 Legacy wagon (4wd)
ej22 turbo
2006 Legacy 2.5GT
Great deal on tires for 2001 Legacy or not?
Brake Problem - 96 Subaru Legacy Outback 4-W/D
Overheats after EXACTLY 12 miles every time
ecutek legacy remap resulting in check engine light
Legacy GT Twin Turbo
Not very quick??
99 Legacy misfire
2005 Subaru Baja Sport Turbo Five Speed
Accessories for a 2003 Liberty (Legacy)
Dies, hard to start
What is it ?? 1996 GTB
Purchase of a vehicle
92 Halfshafts
Check Engine light
problems with under 98 octane fuel on jdm legacy
anybody wanna buy b4 sti
i have a gravel like noise after 5500rpm in my b4
1993 Legacy Tailights
1996 to 2001 Legacy's, Any Chronic problems ?
Two timing belt engine help - '89 1.8 Soob
Will you treat your new Subaru with Simoniz System 5?
Poll - Do you purchase xtended warranty on your new Subaru?
2005 2.5i question
HELP!! smoke coming from left hand side of engine bay
1990 Legacy, Wierd Starting Problem
VSS 1 and 2
Air Flow Meter Compatibility
92 legacy, won't start
boost?
2000 Legacy Brakes - service manual needed
1992 engine in 1990 legacy
Lighted Shifter Knob that Lights up With the beat of the music
Check Engine Light - '97 legacy
FS: '99 Legacy GT in NY...needs work
adding keyless entry to 98 legacy
Does the Baja use the same keyless entry remote as the Legacy?
engine swap
Legacy engine transplant
turbo on 99 impreza?
Replacement tires for '03 GT Sedan?
HELP! Intense "thumping" while accelerating
Race question
2.2 vs 2.5
Engine Swap
97 Legacy GT...... Brake issue
i got me a 91 legacy sports turbo sedan with not air con
Can someone help me out?
'92 Legacy Motor Install Help
Legacy Convertible
97 GTB Airbag Light
Wanted: 1999 Legacy Transmission 5spd Manual
turbo?
96 legacy head gasket seepage
1990 Legacy tachometer quits working
Custom Turbo Instructions???
Looking at buying a '93 Legacy LSi Wagon
TD05 on 1990 legacy
car won't start after hot
Battery change, ticking sound...
Impreza bumper kit on a Legacy?
FS: '98 Legacy L Wagon $3,000!!
Air conditioner STINKS
to race or not to race
95 legacy LS
92 Legacy Auto Transmission Problem
Starting Problems
93 subaru legacy
check engine light
Gas float
Traction Control System
Spoiler lights on 95 legacy
cd player legacy 2005 awd
Changing legacy belts
Cold Air System on my 1997 Legacy GT
Help--intermittent stalling problem
"Check Engine" light on-really a problem?
oil in my radiator
Need Head Gasket - What Else Should I do?
'97 2.2 upgrades? MSD/intake/shifter/SS-lines?
new ings+1 Aero Kit
97 keyless programming
99 wagon speedometer works when it wants to, HELP
Mysterious Engine Revving on my 97 GT - Help
98 Motor into 90 Legacy? HELP!
Socal: Looking for a 05-06 Legacy for testing, will pay $200.
97 Legacy GT - Why is there oil in my water?
wiring for a motor swap
Sheet metal rattling noise
93 legacy squealing
05 legacy gt mods
brakes
ABS Problem-ideas?
2000 Legacy Idle Control System Malfunction
motor swap
A/C cycling 92 legacy
Subaru Legacy NY Meeting
Wheel Offset for my '97 GT
96 Gt check engine light
94 Legacy doesnt want to shift
Car audio pro's
legacy gt 0-60 performance
1996 Legacy-been sitting, will not start now
2000 wagon cd player
Changing fuel filter
Speedometer not working
2004 Legacy Air Box
trans problem
89 Legacy wont start after jump
Boost gauge
Change timing belt
cv axle problem
Interesting story
2001 Legacy wagon clutch shudder
Aftermarket CD deck for '05 Legacy?
sti parts in '05 Legacy GT?
Malfunction codes
anti lock brakes skid
occasional transmission problem
body swap
Brullen equal length header
lock tight was used on harmonic balancer bolt...
my new car...
EJ 20 Coils
90 leagacy not starting
transmission rear seal
Dash light change
transmission issue
ForSale: BD Legacy w/ over 5k in upgrades
97 subaru legacy RS twin turbo
hEATER CORE
'92 Legacy Wagon w/ Air Ride Suspension
turbo help
Do you have to replace all four tires when one blows
wrx engine
Electronic height adjustable suspension
Need 97 Legacy GT Engine
14 seconds is all?
1998 Subaru 250T: looking for a model description
Old worn out clutch
how to remove vehicle speed sensor?? 91 L FWD
1991 Subaru Legacy Problems
Legacy GT to B4/s401 conversion
Buzzing sound from back of 92 wagon
Engine swap and tranny question.
Hard 1-2 shift?
check engine light 97 legacy GT
Difference between Legacy GT/GTB?
96 Liberty 2.2L GX - putting/low idle (Australia)
Subaru engine vibration / shake
1994 Legacy cold starting problems
96 subaru legacy mis fire!!!
93 Legacy Body kit...
Changing engine fluids Legacy 1996 GTB
Cooling fans
Egg smell + check engine light
JDM lighting for 1990 Legacy Wagon???????
Engine swaps for 97 legacy
Help questions on 97 legacy
96 Legacy Outback (2.5L) ticking
Problem 93 Legacy Alternator or Battery or?
Legacy wagon electrical problems
1991 Legacy doesn't move anymore
Engine coolant temperature sensor
Legacy 1995 stuck in park
1998 engine misfire code
1998 Legacy startijng problem
help me find inexpensive stock exhaust
91 Legacy Tranny jerking
MAF Bypass
Diff probs
95 legacy AWD not working
93 Legacy will not start
morette headlights
Warning light
05 legacy gt
