Pontiac
> Montana/Montana SV6
View Full Version :
Montana/Montana SV6
Pages :
1
2
3
4
5
6
7
8
Front End Knocking Noise
Steering wheel audio controls
Vibration
strut replacement - reusable parts.
My A/C went out suddenly
2008 Montana SV6 - Windshield Wipers problem...
Sport Suspension - what's different?
remote start
Steering wheel controls and horn not working!
Driver Seat Won't Recline
'99 Montana Overheating
Power door lock not unlocking - '06
Problem replacing rear shocks - '06 SV6/Uplander
2006 montana seating please help
2001 montana wipers
2002 Montana power seats
Misc. Montana issues
2001 Pontiac Montana Van
Towing Montana Van - four wheels down?
A/C high pressure service port
01' Montana and phantom crotch rocket....
Power sliding door won't open.
Don
2000 Montana rear ac evap lines
2000 Montana rear AC lines
Popping when backing up
Help Please
02 montana quit running
Upgrade Rear (and front) Wiper Blades for Pontiac Montana
2005 Montana
2000 Montana AC Leak Detection
'06 Rear Brake Pads
1998 Pontiac Trans Sport radiator fans only work when the AC is turned on
Engine Overheating - Kind Of
passenger window
Removing 2nd row chairs with airbags
2002 Pontiac Montana AC does not blow real cold
02 Montana wont let me read codes
2002 Montana Engine swap now have 2 codes
Shifts Hard
2001 Pontiac Montana 110k miles
Which kit for replacing LIM/Headgasket
phone not availabe
Intermitten speedometer
2002 Montana fuel door won't stay closed
Pontiac Montana SV6 Extended 2005 Remote problem
Where is the OnStar module located on an 05 SV6
00 Montana tranny question
2003 montana pk3
One year after....
2006 Montana V6 power steering power loss in drive mode
radio & key
Help with tranny cooler install
2002 Montana fuel guage quit working
Multiple problems with my 99 Montana
SV6 wheel hub bearing assemblies?
'06 SV6 starts then stalls sometimes.
Remote Start upgrade done!
cranks but won't start
wacko instrument cluster gas gauge tachometer speedometer 2004
Electrical demon
2001 montana will not crank
01 Montana Overheating *sigh*
1999 Montana Overheating
Trans shifting late
Low Coolant Light - Very Odd - HELP PLEASE
99 pontiac montana cooling problems
2002 pontiac montana coolant temp
Annoying chime alert with no DIC message.
Gear shift light works intermittently
Anyone have more misfires after replacing plugs?
From a squeak to a CLUNK!
MY 99 Montana won't rev past 3000 rpm's
Re PK3 key(American or Canadian)
2003 montana automatic won't engage in "D"
Sliding doors opening...
PK3 key
entrance lights not coming-on Montana 2003
Heat / AC Flapper
help o2 sensor
Changing SV6 Parking Light Lamp
Steering Wheel Radio Button Lights
Wiper Arms
Hoses, Coolant, Thermostat and Sensor replaced. Now get Service Engine Soon light
2006 SV6 ABS/Traction Lights
Head gasket or intake gasket?
Temporary Transmission Trouble on VACATION!
2001 montana digital odometer driver information display problem
Extra rear lights....
my small list
heater door
Normal - Temperature reading????
'02 Montana; accelerator sticking HELP!
99 Pontiac Montana Tranny problems?
keyless entry
traction control coming on for no reason?
Aftermarket Gauges
Wrong wiper mechanism pause position.
Abs & traction control light
EGR Flow Insufficient
2000 Montana Brakes
Front suspension squeak
Winter rims for 03 Montana
2001 Montana no rear heat
Rear window wiper parts
2001 Montana - Heater problem
2006 montana sv6 pulsating lights
Montana 2003 radiator cap questions
2000 Pontiac Montana 3.4 Liter Overheating
EGR Valve
Transmission shifting
Buying 2003 Montana in Montreal
2004 Montana Dash Lights Not Working
Transmission lines leaking
Winter preparation tasks???
2001 Montana- Interior lights do not come on
TPS (Tire Pressure System) - new discovery....
Rust protection, oil spray or "leave as is"???
Transmission Clunk!
Which winter "rubber" to pick???
CV joint leaking and front end noise
Crazy Draincock!!
99 Montana Blower Won't shut off.
Do check your Onstar system yourself...
Serpentine belt help
1998 montana recirc door motor noisy
Do check external light covers.....
Wish my new van luck.
Cylinder Numbers and Coil Pack
brake light on
low coolant light flashing
EGR Valve
Power Sliding door on drivers sider
2000 montana tension pully
rear wiper
questions on Montana
Auxiliary power AWOL
Water tep gage reads low
Vibration
Need help with AC, 2005 Saturn Relay
Where do I get a Haynes manual for 2006 Montana?
2004 o2 Sensor needs replacing AGAIN!!!
Wierd AC Issue
Passenger sliding door won't lock open
What MY Rear Disk Brakes
Use H9 instead of H11 SS-Ultru bulbs???
2000 Montana Misfire
tappit noise source
mantana intake gasket..
please help
Headlight Haze
2001 Montana wheel bearing??
2005 SV6 and up
temperture gauge does not work , and hesitates on acceleration
stalls when pulling away/bucks
2001 montana torque converter
Please helpme people !
Catalytic converter efficiency
98 Montana wiring - fuel pump
Installing Tranny cooler advice ?
Rear Heater Access
1999 Montana won't start
starter replacement 2000 montana
can i put in any 4t65e transmisson?
Power door closes then opens back up... annoying
Driver's side window - not going up
Loud rubbing noise in front end
Transmission Shift Kit - Part II
Help: Brake Control Connector 2002 Montana
99 Monatana Water Pump
99 Montana AC Issues.
Parasitic drain - no start after 4 days...
Intake Gasket Warranty??
anti-freeze leak
Inspecting a Used 2003
Programming PCM
Air Compressor - Auto Load Leveling
head gaskets installed now runs rich and stalls
Rear Blower
Program old keyfob 2006 Montana SV6???
Is the Brake Fluid Cap supposed to be a little loose?
transaxle line
So what needs replaced after airbag deployment?
changed pcm now I have a problem.
I have an electrical problem I think, HELP!!!
Quarter Window and Rear wiper
Turn Signal Lamp
98 Montana passenger carpet wet
Front wheel bearing???
oil pressure trouble
Headlights turn on when it rains during day light...
99 montana will not start after sitting for 6 months
What Temp doe Radiator fan kick in?
Drum Brake Adjustment
airbag light
2001 Montana Cooling Fan Troubleshooting
Adding factory remote start to 2006 Montana SV6
TPS losing 5v reference.
99 montana #5 misfire
And Now This: GM faces Massive Recall
Trailer Hitch Install videos...
Getting codes 0300 and 0128
Service Vehicle Soon Light on an 06 Montana SV6
OBD2 Scanner "LINK ERROR"
Oil Pressure Light on Left Turn
2001 Montana with 97k 3.4 hard to start when warm
bought it - will obtain next week...
Airbag light question.
Fan only runs on settings 3-4-5
1999 montana inner cv joint?
Montana Front End Clunk Pictures
How To: Remove Door Panel
Load leveling system
With our without Towing Package???
aftermarket front coil springs?
Lifter Noisy 3.4
WTB Montana...question on 2nd row seating
'99 Montana broken camshaft
What is their differences???
A/C switch
cooling fans run as soon as you start the van and do not cycle off
2001 Montana Electrical & Computer Problems
serpentine belt change
$1519.00 Sliding Door Repair ?
put venture 15" tires on uplander 2005 possible?
05 Montana SV6 3.5 LITRE HARD START WHEN WARM
2004 Montana wheel Bearings what is the torque?
Turn signal mania
2002 Pontiac Montana Running Rough at Idle
2002 Montana Water Pump
Issue installing new plugs in '03
Oxygen Sensor - Bank One Sensor One
Power lock problems.
High-pitched squeal from engine
Can roof racks carry a canoe?
2000 Montana
Heated mirrors
2001 Montana totally freaking out! Lights in dash etc.
Wipers not Working
B0022 where to start?
loose output shaft on tranny
Steering Q after having head gasket replaced
Got my "Class Action" cheque from GM !!
Manual Sliding Door will not lock/unlock
Gas filler neck leak
2000 surging!@#$
family stranded
