Our Community is 662,000 Strong. Join Us.
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Honda
Civic | CRX
> '88 - '91 Civic | CRX | Wagon | Shuttlee
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
Cabed civic mods
lower control arms crx
How To Bolt On Chargespeed Wing?
Fuel line repair
Steering is tight
Which intake manifold fits?
Peanut Butter...
swaping seats
D15B1 block D16Y7 head swap ?
I'm Back
88 Civic stalling problem
New EF civic!!!
Best way to remove interior side panels?
New Header for swap?
B18A1 Power Steering Question
Opinions on OEM vs aftermarket timing belts
I Need Help Fast !!!!
replacing my D15-- budget swap for daily driver
Error code 20 for my 1989 honda civic
Whats it worth
Buying the MPFI kit
Crx Dx: A Couple Questions
CV Axle - Replace or Re-Boot
To swap or not (Tranny that is)
Service manuals, Parts lists, Carfax
mpg help
89 Prelude seats in 89 Civic HB?
f20c1 swap
16" steelies for s 89 hatch?
Got my new DX..Im in FE mode!!
obd0 to obd1 swap trouble
Lightest Gutted Hondas.
Civic Cold Start issue
Whats Wrong?????
need help with crx
D15B7 head on a D15B2 will it work?
anyone in the New Jersey area
fuel rail and injectors
CRX Carpet
Seatbelt Squeal
Goodbye to the Honda world!
Seat question quick?
head ?????
Which distributor and where to get it
Hello Again
tps sensor question
tires
Ignition Key - Won't Come out - More info- Help needed.
Engine Swap
Identify a Rim model
DAYUM there are so many deals here..
Just purchased 91 CRX DX need some advice!!
crx si 91
91 Civic Hatchback...Distributor
Installing ignition lock cylinder
obd1 question
Emergency Lights
Fender Bender
New to Crx
Car Wont Start!!!
Civic std rear wiper.
91 Civic Hatchback...Turns over..Wont start.
Body repair
solenoid valve where?
Ignition Key won't come out sometimes
Konig wheels
specs
anyone kno how to replace a fuel pump
Rear Hard Brake Lines - Size?
Cylinder head welding
Connecting rods
HF dash
just want to say thanks
91 Civic Hatchback
jdm rear crx seats
stock intake ?
O2 sensor and ECU
broken cam
civic prop valve vs si one.
y8 throttle body
Are there any unmod'd 91 Civics left out there?
cam specs
dpfi to mpfi swap questions
need help..
running rough
91 SI won't idle when warm
heater quit working..
Coilovers
Compression
Where to buy a throttle body
surging engine
89 crx brake help.
90 Civic LX Rear Seat Bottom Removal
Switch to PR4 or stick w/ PM6?
Ok, so I decided against rear discs for now
CRX front bumper on a Civic?
problem!!!
dash question
pcv ?
rough stops
Spoilers
D16A1 Into a 91 Si Hatchback - Need Help!!
Si Tranny
No ReVerSE!~!
Civic Dieing
crx engine..help new
Fix it or not?
Help 90 Honda Civic Overheating
What would cause my car not to start when it's raining?? Is it electrical? or other?
Brake booster replacement 88 1500 DX 4 dr
RIP my 1.6i-VT
Interior questions
Tranny Leak HELP!!!!
Speedometer is boggling my mind.
Pics, as promised, and if you're on dial-up, get your coffee while this loads..
so yeah...
alternator plug conversion?
Normal Oil Pressure Levels
Would code 7 cause this?
So I guess home depot sells lips :) 56k not a chance.
cam specs
90 civic with zc HELP FAST
Upgraded myself to baller status in the shop....
two questions...need help
Confirmed New Crx
Ignition Switch? Heat?
Parts sites
D series R'active header..
Main Relay
91 Honda Civic...License Plate Lights..
master brake cylinder ?
5500 RPM limit?!?!?
vtec problem
found hf crx what do i take
90 crx W/b16 axle question
91 Civic Dx...License Plate light replacement
91 Civic HatchBack
brake question
91 Civic Dx Manual 5 Speed...What motor can I swap ??
ZC Stumble
engine help
cluster ?
91 Honda Civic DX....cv axel needs replacing
Diff's between A1 and ZC
found older si civic
head question
cooling
No Start (Fuel Pump Question...)
tranny prob
How much Power can a Stock Internal D15B2 Handle?
Swap ?
Front brake rust problem
89 Civic dual-point FI to mpi
Trailing arm Bushing question
89CivicDX - Question on header and fuel
Swap Idea
Opinions please!
Problems Problems ...
Car won't start!! Immediate AID!! Please!
Brake lights messed up/stuck in park
CRX seat belts
stock air intake question.
now that i got the trans in i have more trouble
What color?
HID's in my CRX
90 Civic Hood Types
rear disc brake lines
Hallelueah!!!- Niagra Falls is dry!!!
turbo ?
91' light short
tranny PROBLEMS?
HELP! a/c comp. blowing fuses-crx
90 Civic dual-point FI: Best place to Check Fuel Sys Pressure?
Window problems
glass question
speedo lights wont come on
Dash/Console swap
axle question
Possible to clean the ignition switch?
b18b in a 91 EF-Fan Problem
91 crx Si speedometer swap....
'91 Civic Won't Start
B18A1 Problems
aftermarket tachometer
alternator question.
crx wont start.
Back!
17yr. old body seams = Niagra Falls
what seat brackets will work for my car?
CRX sunroof problem
2nd Annual Maple Grove PA Honda Meet OCT 21st!
B16A2 w/Hydro into 89 ef sedan HELP
Omg...what's Wrong??? Please Help W/ My Si Civic
Help! How bad is it?
light connection
on to a darker side
91 cx with 1.6?
corner light blub help please!
Car wobbling
Hesitation and backfire
took some pics of my EF
Help!
Updated pics finally. Been working on her for over a decade....
Password jdm hood dampers.
help
Messing around with LEDs
fuel filter question.
Removing Seats...
PLS HELP!!! 1990 Honda Civic CRX
Replacing Radiator....auto tranny
crx
Recently acquired civic
type r lip
Need some help
zc dohc help
The day is finally arriving!
1990 civic DX HB - clutch problem (manual transm.)
What Dizzy should my 1990 HF have.
skunk2 d16 intake manifolds
NOOB 101; Where do you go to buy engines/ trannies for swaps etc...
Crx Problem..need Help Fast
Just bought, what to do?
no vaccum?
My pics of the crx
need help fast
01 D17 Crank pulley on Z6
Tampa Where you at????
D15 to B18???
Help :(
Flywheel Help Plz!!
<b> I Need Help !!!!!
89 crx hf with ls b18a1 and 4 wheel ls disk breaks for sale!
So I got another EF...new winter beater/daily driver
'91 Civic questions
cowl hoods
zc problems
aftermarket head gaskets
rattle car :)
temp gauge and fuel pump?
Ecm
she died on me today :(
tranny refill help.
Need expert's help: 91 1.5 TBI Doesn't start well when hot
p1 front lip
valve/cam timing
Battery Light??
aftermarket header
i need help any 1 please !!!
I Need Help Badly!!!!
Clicking from brake
Automotive Network, Inc., Copyright ©2012
