View Full Version : '88 - '91 Civic | CRX | Wagon | Shuttlee
  1. Whining from Clutch?
  2. mpfi swap
  3. Update 56k Beware!!!!
  4. 89 civic d16 swap
  5. z3 metal fenders?
  6. Updated taillights pic...
  7. Updated interior....
  8. Shocks/ Struts
  9. Update: 88 and 91 crx pics, 56k NO NO!!!
  10. b16 check eng. light comes on when warms up
  11. EE8-EE9 VT/VTi Parts?
  12. Custom Interior
  13. acceleration: Tappets or Gearbox?
  14. Knocking Noise..oh god..
  15. sohc
  16. bushing compatibility
  17. My head is Back from the Machine Shop (pics inside, 56k ok)
  18. windshield
  19. shift linkage
  20. What tranny fluid should i use??
  21. whats the deal SI?
  22. zc engines
  23. code 8
  24. goodbye dear Si transmission... (#5)
  25. Fast and Furious 3
  26. Civic Geeks speaker pods. Pics
  27. Looking for the name of an Air Intake
  28. ? About Rear Cargo Space
  29. help!!!
  30. turbod d16 or all motor b16
  31. 02 simulator for b16, do you need one?
  32. no more pullys no more lag
  33. having trouble water temp
  34. b18 swap shift linkage
  35. Short update and quick Q...
  36. chrome trim adhesive removal
  37. Making A CRX Fast...
  38. b16a idle help?? plug??
  39. How easy is it to replace the lower ball joints?
  40. Need Wiring Diagram... OBD0--> OBD1
  41. Engine Build... Updates...
  42. suspension questions...
  43. my crx si swap
  44. B16 questions
  45. obd 0 - obd 1 conversion....
  46. Rear Sway bar
  47. B18C into civic or crx
  48. About D16Z6 & D16ZC
  49. Did PGM-FI Swap & Now I have temp gauge flux?
  50. where are the fuel lines routed?
  51. Ignittion lock cylinder
  52. Engine swapped into civic/crx
  53. 1989 Honda CRX Si VS 1985 Porsche 944 non-turbo
  54. Damm exhaust
  55. CRX tank size?
  56. unorthodox racing pulleys?
  57. CRX hf mpg
  58. Wiring questions (pics included)
  59. Looking at replacing the hatch hydros
  60. 4-dr project idea
  61. Help Me Please
  62. i need to move out!!!!
  63. crx swap to a d15b 1.5L VTEC
  64. please help!
  65. spongy brake pedal?
  66. rear discs
  67. racing chips
  68. Anyone with an LS swap, need ECU code
  69. Idle Problem...NEED HELP!!!!!
  70. B18 Swap Not Running Right! Need Help!!!!
  71. how do you remove driver side window trim? (metal black pieces outside)
  72. door compatibility
  73. A/C with DOHC engine?
  74. 90 dx wont start anymore
  75. Switching to Synthetic..bad?
  76. no more crx
  77. 90-91 civic bumper lens
  78. Need help with alarm with starter disable
  79. fuel pump
  80. Part number needed!
  81. 89 Civic leaks feul
  82. b16 check eng lite on, stumbles on acceleration
  83. rally rex
  84. auto no drive in D normal from 2nd
  85. 2g (90-91) Crx Common Problems and Price of Repairs
  86. '88 Civic sometimes won't start...throws CEL...today it apparently worsened :(
  87. rear spring swap for hatch
  88. B16a1 Code 22
  89. Help! '90 Civic w/ electrical starting probs!
  90. MAP sensor problems
  91. i messed up
  92. rear bumper fit??
  93. low mpg
  94. Dpfi to Mpfi expense and difficulty
  95. CF Hood >CTK
  96. crx engine swap
  97. Pretty sure I saw one of you today...
  98. b16 help! sounds like its running on three cylinders, no power
  99. Resistor Box Prices?
  100. Pwo Ecu Fs:
  101. Engine temperature gage goes up and down.
  102. I want a new front bumper
  103. 90-93 teg or 92-95 civic radiator????
  104. Back from paint
  105. B16a Butcher Job
  106. Do vavle breathers work?
  107. Oil light
  108. DPFi to MPFI - No Reverse Lights!
  109. How long to break in a cluch?
  110. Lighted door Mirrors.
  111. all i need is a running engine!!!
  112. Finally Got My Bumper Lights To Light!!!!
  113. pics of my new 89 CRX Si JDM B16a
  114. b20b problems!!
  115. b16 swap questions
  116. D15b8 and d16a6 heads
  117. headgasket replacement
  118. Loud BANG! now have low oil
  119. How do you remove the fuel pump??
  120. HELP..filling transmission.
  121. suspension trouble
  122. Link to the manual?
  123. B16 question for Oz Civic Owners?
  124. CAN You use an OBD0 Altenater on an OBD-1 Engine?
  125. 02 Si rear seats
  126. hatchback seat mounts
  127. B18 SWAP Done BUT NOT RUNNING RIGHT??
  128. Bumper spoiler
  129. roll pin b16, can't get out
  130. single wiper
  131. Harnesses
  132. Check out this 4dr
  133. Turbo
  134. Please help me
  135. 4th gen lips
  136. My lip
  137. know any reliable engine importers?
  138. canadian and american civic swaps
  139. got a new beater! (its not an EF)
  140. 1.6 zc crank im 1.5
  141. Pics of my project 4door
  142. 1988-91 Civic Si Parting-out
  143. Over size valve for zc? form si? dx? witch can i use?
  144. Brakes??? Fluid???
  145. P30 pistons
  146. lexar
  147. Whats under your hood?!?!
  148. Turbo Question
  149. fuel pressure ....
  150. How to release stock radio....
  151. chopped top civic??
  152. What kind of oil would you use?
  153. what size slicks
  154. my next car, bit exspensive but worth it!
  155. CLUTCH Engagment Problem!! HELP!!
  156. looking to buy crx...good deal?
  157. oxygen senser wire
  158. LOCAL 4th GENS!!!
  159. b16>>>>Ls mount???????
  160. went to the track sunday
  161. What brake pads to get?
  162. Another 4th gen
  163. dx vs accord lx
  164. AWD in my b20 lude.
  165. b16 help! sparking/popping noise when trying to start
  166. BMW Wheels (pictures, 56k ok)
  167. 89 and 90 harness differences
  168. finally got the turno kit knstalled!!!! (pics inside)
  169. HELP!!! B18 wont run over 2K RPMS!!!
  170. Speedometer gear in trans out (fix?)
  171. Rear Disc Shuffle (1.5mb of pictures)
  172. Car won't start when hot...help!?!?!
  173. want to know the pin locations for the vtec harness for b16a swap in '91 si
  174. installing sunroof
  175. help with finding fenders please
  176. Check out what just fell in my lap!
  177. 1.5 auto non vtec too jspec 1.5vtec 5-speed?
  178. carbon fiber rims
  179. b16 head swap
  180. why isnt this done more
  181. dirt oval track racing
  182. mpfi swap
  183. 90 Honda Civic Intermitten No start
  184. 91 dx hatch won't start whens its hott
  185. 1.5 bored to a 1.8? HELP
  186. port and polish hp gains?!
  187. i need help with pulley info?
  188. Bad Gas??
  189. Lighted door mirrors
  190. Lighted door mirrors
  191. Anyone seen the Apexi WS Exhaust on a Hatch ?
  192. umm... yea.. just read and watch (Kumho Tires)
  193. 88 si head swap
  194. 91 crx si rims 14 inch
  195. 1990 civic b16 swap (no fuel pump power)
  196. B18 SWAP Not Starting
  197. Converting CRX to CRX HF help please
  198. Crap Apex
  199. New Pics with Coilovers installed (56K beware!!)
  200. New pics of my project
  201. aftermarket Bumper Lips for 88 civic hb
  202. Integra at the junk yard
  203. Mirror Lights
  204. body work... welding
  205. Head gasket ?'s
  206. b16 torque rod bushings
  207. Strut Bar Question
  208. X on head lights?
  209. b18a/b vs b20b??
  210. CRX Rear Seat
  211. Finally!! b20b pics..
  212. ball joint woes
  213. how to put pics in here??
  214. how do you pop off the rear seat?
  215. B20b crx project update: soon to be boosted!
  216. new suspension help
  217. Tranny Question
  218. Hydraulic Tranny?
  219. Great News
  220. quick question b18a1
  221. Repalcing side marker lights 91 Civic
  222. Spark plugs soaked in oil???
  223. How to test a Car stereo without a car?
  224. JDM vs USDM b16a internals? same?
  225. TEIN springs
  226. Van doors on a compact
  227. problems with car....unknown
  228. Coilovers
  229. Interesting ebay auction, jdm subwoofers?
  230. 90-93 integra cluster swap for 91 civic hb!
  231. Fiberglassing.
  232. 4 dr seats in my hatch? y or n?
  233. I need help on memory wire!!!!!!
  234. ecu wire list and diagrams
  235. code 8
  236. need new radiator best place??
  237. Wire colors?
  238. Leaking Oil!!
  239. JDM d15b swap?
  240. D15B swap
  241. Chicago/IL civic/crx meet during HIN
  242. Leather Interior. *pic*
  243. discrepencies on dx to si wiring
  244. question
  245. How to tell if Tranny has an LSD
  246. hydro tranny in rex
  247. I need some 17" wheel advice
  248. distributor problems
  249. R.i.p
  250. New comer to the civic family
