Automotive Forums Car Chat
Honda
Civic | CRX
> '88 - '91 Civic | CRX | Wagon | Shuttlee
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
psi on cylinders
Is flushing the transmission oil harmful?
i need an idea
honda ecu
b18c1 swap into a 89 rex?
glass scratch
smoking
Tranny Question
pop out windows?
tach gone stupid
need honda help!!!!!!!!!!!!!!!!!!!!!!!!!
Will a b18c1 manifold fit my cAr?
Help!!! Can't Find A T-belt For Zc Dohc
d16a9 problems
olive drab or flat back
Serious waste of time and money, but what if???
Yesterday and today.
B16 exhaust manifold clearance
wont turn over after it stalls
Finally got pics of my 91
a comeback
injector replacements
Multi-Point Injection
Tachometer Problem
Civic won't start! is it the ignitor?
really stumped on this one
me again with my carbon fiber questions.
new halo projector lights.
whats this worth?
Traded 4dr
F**K! Forgot where the hose goes!?
ZC not sparking
Videos from Philly @ Ripken combined.
Need Help ASAP
Oil
auto paint help
b16 ecu?
door beeping help
car was stolen
obd0 to obd1 questions
resonator?
EF Civic raping a skyline
major moisture/leaking problem in hatch
idle surge
tangerine
b16 trouble code
fixing my crx
Gauges only work in reverse
windshield undone
justgot wingswest 6pc bodykit
please help me with my 91 crx
radio
b16 VTEC shuts off while racing through gears
Short video of my car
A dumb question
oxygen sensor wire
Got My LS motor
Engine Start button
converted to r134 but problems arose
new rims need help
Where can i buy new side moldings for my hatch?
painting interior
It's Alive ! (pics to follow)
5th gen front end swap on a 4th gen???
Rough starts
B16 or B18 that is the question
Rim's ?
Looking for pictures of turbo kit with a/c left on!
b16 build with itr parts....
boggin out b16
Motor Swap
N11 Pics
gauge clusters
zc problem
What are the best ways to lower your civic?
Need Some Help With Pick A Motor
idle problem
what block do u recommend..
turnsignals, clock, temp gauge, fuel gauge, and rpm guage dont work! why?
ZC with LSD?
ECU Fuse Blowing
chipped ecu
What clutch?
D16Y8 help
Speeker Box Issues
cleaned IACV and...
goes up and down at idle...
uh oh....
90-93 integra dash in a civic
Torque Settings?
Mini-me swap
New Stereo Project Started
heat vs my crx
Dizzy problems
clutch master cylinder
do you have to swap
aluminum crank pulley
water pump out?
Revving Up When Warmed Up-lifting Pedal Helps??
Headgasket Problems/Engine Problems
Hondata S200 Kit ... Anyone used it ?
spindle nut wont budge
can this pose a future problem?
a few dohc ZC questions.....
Story about timing belt today
Ebay turbo
stupid oil plug
hey code 10 on ecu???
89 Civic Hatch DX
RE: Oil covered sparks plugs????
Odd noise
pm7 vs pg7
Back on the track
I Need Help With Iac Sensor!!!!
hi, newbie ?s
stupid fuel injector
The latest ebay impulse buy
Peak power RPM for shift points
so i beat that 98 eclipse GS :)
Pinging even though it's timed right
Cat options
Drop it 2" on standard strurs?
spoiler wrapped in carbon fiber?
Got my parts...Next will I begin the motor build.
swap info?
temp gauge and gas gauge
Thermal R&D purchase?
AC help!!!
d16z6 170hp without fi?
Relay?
mini-me swap question
Way to ID limited slip trans. ??
Cant Stop - Loosing Brake Presure
Can't find them anywhere
SOHC ZC Questions
B16a bucks when i drive it
what times sould i be running?
My new custom CF fenders....
tinkering with broken transmission 90 civic 4door
dose any one know how to wire up a o2 sensor
buying 1988 Honda Civic
Wheels
how do you reset ECU?
swap
89 Civic H/B swap
The best Kill I have ever had!!!
gasket question
I Win !
High Idle
pics of my ride
does your engine perform better with, or without the O2 sensor??
HELP. Cooling Fan does not work
coilover! were do i start?
conversion
Front suspension crossmember?
what do you think of this
do i have to remove the alternator to lift out a 1.6?
hood pins?
What is the easiest swap for my 91 HB SI?
What plug goes to the IAC Sensor?
Thoughts on new paint job
help me out please
struts
No power to ecu
What is the CYP sensor?
Updated pics of my car....
gas tank question....
shaved doors ect
this is unusual huh? video
Tech Problems
i know i ask alot of dumb shit but heres some more
E-Brake light staying on...
best cam for a z6?
What do you guys think of these lights
I Love my Honda
Pictures Of motor Build (56k no no)
92 b18 into 91 civic?
The tri-state area
Top Speed
pictures of car...finally got new ones on here
Zc Motor ?'s
B18b vs b16a1 or a2
backfire and sputters
Aftermarket Tach
90 Hatchback DX
idle issues
Safc Ii
taillights and running lights
I want my baby back, baby back, baby back..
Greddy Pipe
Lowerd SI
b18c in 4 gen civic
wat other clusters ARENT VSS
Free Strut Bar For 88-91 Civic Si/CRX
Quick Q - "LS" tranny
1991 SI Starting problem, ecu light flash every second
civic dx
turbo kits for ls swap
ENGINE SWAP PICS *56K I dunno*
need some help guys (parts wise)
I little help?
his will fit
g2 integra seats into my 90 DX
Electric Problem (89 Civic Si - ED7)
this is just a little thanks
Current Pictures
89 civic seat bracket help!
need help with a 4 wire o2
CRX HF Interior ?
Help! longest lasting problem ever!
major problems help!!!!
Instrument Cluster swap on '91 civic dx
b16 engine shuts off at 7100 rpms?
what springs out of the 3 should i get?
Project Taking Shape.
Gas Mileage w/B16a swap - HELP!?
Boiling battery acid...
painting interior in my civic
Need advice on swap
front disc upgrade
down pipe bolt
91' CRX hf replace clutch
who has a turbo b16 and what setup do you run?
intresting D16 info from T.O.O.
Anyone know a good source to buy an LSD tranny?
Video from Philly event at Northhampton Community College.
silver motegi mr7's on a black crx?
RPM Surging
Are all D-series Blocks the same?
PG7 troubles
b16 02 sensors not hooked up still runs the same
alternator fried after a week
Car running but not moving????
Cheap way to get 250 hp from a civic?
quick question
civic vti 3stage
b16 head???
Head Lights -> Smoking gauges
fuel delivery issue?
auto to manual - is it worth it?
ls swap help
how to convert from d15b2 to d15b7!!! HELP
vtec's FINALLY hooked up (temporarirly ghetto rigged), one last question though
get go smoke
woeua[rjfas'ldkf
Fiberglass 101 - Tutorial
What color is the RPM signal??
why do people relocate their battery?
HowdoI remove black on lower hatchback window?
No fuel or spark...
Quality Real Meat Nutrition for Dogs:
Best Air Dried Dog Food
Real Beef Dog Food
Best Beef Dog Food
