View Full Version : '88 - '91 Civic | CRX | Wagon | Shuttlee
  1. Trading My 1990 CRX SiR....Fast!...anyone interested?
  2. bent frame
  3. curb weight of civic hatchback
  4. Question for people w/camber kits
  5. Hybrid springs
  6. Teg hood on hatch...
  7. 2nd Gen CRX with B16 $2000 good deal?
  8. Where can i get Nylon plastic welding rod?
  9. Location of PCV valve?
  10. new car i found for 650 obo
  11. Sold my civic....onto my next car
  12. anyone ever mounted 6x9's in crx rear?
  13. seat conversion
  14. CRX meet pics(100) 56k no-no
  15. dizzy question
  16. D15B2 DPFI to JDM D15B2 VTEC MPFI on an 88 crx...i need some help!
  17. the most BASIC question you've ever read!!!
  18. What would be a worthy successer to our 4g's?
  19. Are outside door handles the same on CRX and Civics?
  20. Can hit 5,000k or above
  21. In california need to buy a car for 1500.00 or less and in pay ments plsese
  22. crx 91 dpfi to mpfi won't start PLEASE HELP!!
  23. car won't start Help!!!!
  24. vacuum lines
  25. 90-91 & 88-89 clear bumper lenses same?
  26. H22 into a 89 hatchback civic
  27. Peformance and Mileage 90 CRX dx
  28. quick
  29. Fan Problem causing smoking?
  30. timing belt covers/valve covers
  31. What color should I do???
  32. New seat material?
  33. quick question. help!!
  34. new exhaust! what size?
  35. 2nd B16 O2 sensor
  36. having problems with my 88 rex
  37. Integra Console into 91 Civic LX
  38. Aiintake System
  39. What is this green one?
  40. New
  41. Burnouts!!
  42. 200,000 miles! (and counting!)
  43. Storing REX for winter...any tips?
  44. Got hit from behind...few ??'s
  45. Pig Rich
  46. trans
  47. DOHC ZC Valve specs
  48. D16A1 block w/ a Y8 head?
  49. B18A1 in '89 Civic
  50. hf manifold good enough for turbo??
  51. Sad day in Hondaland... got pics...
  52. Anyone got carfax?
  53. Best Engine Importer????
  54. I need an amp QUICK?????
  55. Eratic Idle
  56. Here's An Update on our last Civic
  57. std to zc swap, making sure
  58. Second Thoughts..
  59. b16 crx
  60. Electrical problem
  61. HELP Exhaust System fell out
  62. Underdash Fuse Panel Cover Clips?
  63. msd ignition
  64. will this engine and this tranny work?
  65. Will a baby seat fit on the rear JDM seat in a CRX?
  66. k24 in a crx
  67. dyno-run
  68. I found a ZC block 15 minutes from where I live
  69. fair trade for my hatch?
  70. Bad news about my ZC
  71. 02 Sensor???
  72. bodykit...
  73. $300 for an LS with tranny
  74. is it too big?
  75. Appreciative noob here
  76. Cruise Control........
  77. Dim tail lamps
  78. wow.. i've never seen this steering wheel before..
  79. ecu question
  80. Read This
  81. Fact/myth? injector
  82. pictures
  83. RE: Possible CV Joints AGAIN???
  84. Compatible Prelude parts for 3g accord??
  85. upper u joints question
  86. rear lights
  87. Here is the $500 teg, for my ls swap on my civic
  88. code 8
  89. chip
  90. anyway to tell if the main relay has been replaced?
  91. Turbo Intalled And Smoking Something Awful
  92. Finally a perfect exhaust for the DOHC ZC
  93. Damned Cluster
  94. Carfax Request
  95. How To remove the rear motor mount on a 91 hf?
  96. ? about the 2 in a 4-2-1 header
  97. clutch safety switch
  98. Upper Control Arm Can't Remove
  99. Which Aftermarket Igniter
  100. Back windshield..wtf
  101. Re-apolstering
  102. Sedan Euro/Clear Tails?
  103. A few questions..(1990 crx)
  104. 900 dollar rex
  105. Rear defroster help
  106. Anybody tried this?
  107. 4seed to a 5 speed
  108. SI Tran
  109. The End Is Ineviable...
  110. i want to drop my crx more.can someone help?
  111. help...
  112. dizzy problems
  113. Installing ES bushing kit
  114. H22a in 91 crx
  115. how much whould this cost
  116. o2 sensor question
  117. First eswap experiences MKII
  118. How did your first eswap go???
  119. help guys!! my car wont start!!
  120. CRX.Workshop.Manual & Vtec Supplement
  121. Difference between Release and Throwout Bearing?
  122. I hate o2 sensors!!!!!!!!
  123. Diff Exploding
  124. HeHe.. Alright!
  125. dx doors
  126. need sidemarker help
  127. How to clean and/or check o2 sensor?
  128. rebuilding the carb
  129. Steaming battery at 14 volts
  130. Turn Signals Not working :(
  131. tranny question, need answer asap
  132. my hatch, back from the dead (pics) 56k? eh..
  133. dang it!
  134. 90-91 Civic Hatch Guage cluster in CRX?
  135. Dashpot on MPFI
  136. Pics of the NEW $100 Civic..
  137. bound to happen!
  138. B16 + Turbos
  139. JDM Motors NOW legal in California
  140. Getting the damn insert in the back mount?
  141. stuck in eswap limbo
  142. New Carpet
  143. how to tell civic jdm and usdm clocks apart?
  144. Jack and Jack stand height?
  145. Just wondering
  146. civic crx ignition
  147. fun things to do with an extra d15b2
  148. Check Eng
  149. Im new To this..HELLLLP MEEEEEE
  150. new mods, PICS
  151. HELP! Distributor..
  152. hf vs dx
  153. 2 Days of bad luck, need a little help.
  154. injector question
  155. 91 civic hatchback
  156. to cold for cold air??
  157. Blitz Turbo Timer How Do I Install It
  158. No start.......Timing belt was just touched...need help
  159. Wing installation help plz
  160. printout gauges
  161. b16 turbo question
  162. Headers
  163. Just swapped cluster
  164. Need a timing gear & pully
  165. Can some carfax this for me :)
  166. Si really worth it?
  167. Spoon Ecu Chip??
  168. NEED SOME HELP (wierd stuff happening when i put the petal down)
  169. how to install a new speedo cable?
  170. snapped cam cover bolt
  171. Where's the !*$ Vacuum Leak
  172. Mill the head?
  173. ZC crankshaft same as any other D16???
  174. Beastie2k
  175. Noob! Just bought 88 hatch..lots of questions
  176. Clicking? Clunking?
  177. Clutch Troubles
  178. Moneys Tight, Motor Help
  179. help with seats
  180. B16 is in! Couple of Q's tho
  181. Prelude injectors
  182. 89 wont start and its getting spark and fuel
  183. back to the track
  184. clutch questions
  185. Alternator whistling???
  186. shifter question
  187. pm6?
  188. Control Arms Bushings: Can I get them out?
  189. 10-30-2004 florida crx meet
  190. pressure regulator?!?!?!?
  191. filtration system for interior?
  192. window wiper motor out?
  193. Alternator Rebuild
  194. civic coupe steering wheel mod!?
  195. engine swap???
  196. fuel injectors
  197. Parts on ebay
  198. smoke
  199. zc stock iron sleeves
  200. Anybody have MSD with those focken rev pills if so looky
  201. Cold Air Extension fell off today!
  202. DAMN TACH!! i need help..please!!
  203. jdm d15b specs?
  204. Dash Swap / only for the knowledged
  205. What do you want for your car?
  206. rev limit
  207. front end conversion
  208. Shop name POLL (only 48hrs so please vote)
  209. Check this out, thought it was funny...
  210. Head Studs For ZC
  211. engine swap advice needed
  212. Pictures of my CRX w/Old and New rims!
  213. My cars back to life :)
  214. I need some help
  215. interferance motor?
  216. Holy h$%&!
  217. A few Q's
  218. Is a 91 teg worth $500 for a swap???
  219. Need to be pushed in the right direction
  220. Anyone Have Pics of Air Ride?
  221. difficulty of cable to hydro tranny change out?
  222. back seat
  223. Someone tell me what you think of these valve springs...
  224. My detent rod broke
  225. Contest on who's the closest #
  226. Master Tech Question???
  227. piston ring replacement
  228. Building B18C1 Turbo - have Q's
  229. Just curious....
  230. Need help, block swap.
  231. cople Qs
  232. Fuel problems
  233. i might be geting a old 91 crx
  234. New battery dead in a week
  235. vacuum lines...intake manifold
  236. New Gauge Install Boost, Oil pres, and A/F
  237. aftermarket fuel rail
  238. mpfi swap done...pics
  239. DPFI to VTEC conv
  240. Swap info(ya'll love me right?)
  241. CRX console switch-a-roo!
  242. Motor Selection help
  243. Wheels sagging in the back......Very akward
  244. lower ball joint help
  245. quick question about front lips
  246. Battery terminals
  247. DH-Racing ripped me off
  248. ...time for a rebuild...or?
  249. People Need To Learn To Drive
  250. Having problems
